mgworek 134 Posted June 6, 2016 Posted June 6, 2016 Running Version 3.0.5972.0 in a docker. My scheduled task for Download missing subtitles is set for 3am but it runs at 11pm every night. Also, when trying to see if I can reproduce the problem with another task I discovered in Safari, when setting a task, it always uses AM. I tried multiple times to put PM in but it always used AM after saving the task.
Luke 42243 Posted June 6, 2016 Posted June 6, 2016 check your docker container and make sure the timezone is set correctly.
mgworek 134 Posted June 6, 2016 Author Posted June 6, 2016 (edited) never knew you could do that. Might explain why my upcoming episodes is a day off. Edited June 6, 2016 by mgworek
mgworek 134 Posted June 6, 2016 Author Posted June 6, 2016 (edited) ok my docker date is correct but Emby itself is showing a different time. docker exec -it 3f62a6976f7b date Mon Jun 6 14:45:54 EDT 2016 Emby shows this in the logs 2016-06-06 18:46:30.4188 Edited June 6, 2016 by mgworek
Luke 42243 Posted June 6, 2016 Posted June 6, 2016 try restarting the server after changing the date in docker, and/or restarting docker. Emby gets the current date and timezone from the system. If the log is not showing the correct time there's not much emby itself can do to correct that.
