Luke 42237 Posted October 2, 2016 Posted October 2, 2016 Thanks for the info. The changes I mentioned are not yet ready so we decided to do a small bug fix release today, so the new 7300 update that you have does not include the upnp improvements that I mentioned. It does bump the mono runtime up to 4.6 and that release mentioned some performance improvements, so that might be what you're seeing.
Anthony24 2 Posted October 18, 2016 Author Posted October 18, 2016 Haven't been using it in a while until around October 14 from the last update, works great. version: 3.0.8100.0 Logs 5.. shows errors, no shutdown like other times in the past. https://www.dropbox.com/s/094ivrkbtilqghg/logs5.zip?dl=0 Haven't update to 3.0.8200.0 yet, will soon.
Anthony24 2 Posted October 19, 2016 Author Posted October 19, 2016 (edited) 3.0.8100.0 Logs 6 2 Single files >> Shutting Down and Startup before update. (errors on media. haven't played anything yet.) https://www.dropbox.com/s/hqy8eq4j14sdawy/logs%206.zip?dl=0 Edited October 19, 2016 by Anthony24
