gergtreble 0 Posted June 5, 2016 Posted June 5, 2016 I'm seeing errors like this in the logs: 2016-06-05 15:53:05.8417 Error DVBViewer TV Plugin: [Recording Service] - No channel logo found for channel nr: 527 2016-06-05 15:53:05.8417 Error App: Error in Live TV Service Provider *** Error Report *** Version: 3.0.5972.0 Command line: C:\Users\Media Center\AppData\Roaming\Emby-Server\system\MediaBrowser.ServerApplication.exe -service Operating system: Microsoft Windows NT 6.2.9200.0 Processor count: 2 64-Bit OS: True 64-Bit Process: True Program data path: C:\Users\Media Center\AppData\Roaming\Emby-Server Application Path: C:\Users\Media Center\AppData\Roaming\Emby-Server\system\MediaBrowser.ServerApplication.exe Object reference not set to an instance of an object. System.NullReferenceException at MediaBrowser.Plugins.DVBViewer.Services.Proxies.TVServiceProxy.GetChannelLogo(String channelId, CancellationToken cancellationToken) at MediaBrowser.Plugins.DVBViewer.DVBViewerTvService.GetChannelImageAsync(String channelId, CancellationToken cancellationToken) at MediaBrowser.Server.Implementations.LiveTv.ChannelImageProvider.<GetImage>d__3.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Providers.Manager.ItemImageProvider.<RefreshFromProvider>d__13.MoveNext() Emby-Server: Version 3.0.5972.0 DVBviewer Plugin: 0.8.1.0 Windows 10 Any thoughts as to why I am now seeing this. Only real changes were an upgrade of the emby server version last week. From parsing these logs I see an error like above for each channel then the guide refresh process starts again. This is spinning the emby process and its making my server run pretty hot! Can I turn off channel logos or something? Thanks in advance for any input. Logfile attached. server-63600737906.txt.zip
gergtreble 0 Posted June 5, 2016 Author Posted June 5, 2016 Just spotted there has been an update to the DVBviewer recording service so I will install that and report back.
gergtreble 0 Posted June 5, 2016 Author Posted June 5, 2016 Typically 20 mins after posting this topic I have resolved it. Not sure if it was the root cause but I spotted that DVBvier was serving an RSTP server. So I turned that off. I then created an empty (well single channel) channel group and switched to that in the DVBviewer plugin settings. This allowed the guide scan to complete. I then bounced emby. Then switched back to my "master" channel list. The guide scan took a while but eventually completed. The EPC now looks good and my server is running a lot cooler. Hope this helps anyone who has a similar issue.
Nikolaech 32 Posted June 5, 2016 Posted June 5, 2016 This is a problem EmbyServer. To solve it, you need to restart PC.
