Shizuyori 5 Posted June 3, 2016 Posted June 3, 2016 (edited) Hi This is my first post, i love Emby and hope to upgrade in the future. I have stumbled across a weird problem, when i try to play a video on my PS4, most of the videos play except sometimes certain videos fail straight away. i got the following error in my log last night 2016-06-02 21:40:51.5992 Info HttpServer: HTTP Response 200 to 192.168.0.7. Time: 78ms. http://192.168.0.4:8096/dlna/ccee53bebda97b011a0353be6fd1e032/contentdirectory/control 2016-06-02 21:40:56.1667 Info HttpServer: HTTP GET http://192.168.0.4:8096/videos/4176ff0cc98ade60dd47e0b25d766b6d/stream.mp4?Params=d40732b8b534f8c70aadf485d3043882;test;4176ff0cc98ade60dd47e0b25d766b6d;true;;;;;;;;;;;0;;;;;;;;;4176ff0cc98ade60dd47e0b25d766b6d;false;false;;. UserAgent: MediaPlayer/2.00 libhttp/3.50 (PlayStation 4) 2016-06-02 21:40:56.2649 Info HttpServer: HTTP GET http://192.168.0.4:8096/videos/4176ff0cc98ade60dd47e0b25d766b6d/stream.mp4?Params=d40732b8b534f8c70aadf485d3043882;test;4176ff0cc98ade60dd47e0b25d766b6d;true;;;;;;;;;;;0;;;;;;;;;4176ff0cc98ade60dd47e0b25d766b6d;false;false;;. UserAgent: MediaPlayer/2.00 libhttp/3.50 (PlayStation 4) 2016-06-02 21:40:56.2806 Error HttpResultFactory: Error streaming data *** Error Report *** Version: 3.0.5972.0 Command line: C:\Users\Shizuyori\AppData\Roaming\Emby-Server\System\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.2.9200.0 Processor count: 4 64-Bit OS: True 64-Bit Process: True Program data path: C:\Users\Shizuyori\AppData\Roaming\Emby-Server Application Path: C:\Users\Shizuyori\AppData\Roaming\Emby-Server\System\MediaBrowser.ServerApplication.exe Unable to write data to the transport connection: An established connection was aborted by the software in your host machine. System.IO.IOException at System.Net.Sockets.NetworkStream.Write(Byte[] buffer, Int32 offset, Int32 size) at SocketHttpListener.Net.ResponseStream.InternalWrite(Byte[] buffer, Int32 offset, Int32 count) at SocketHttpListener.Net.ResponseStream.Write(Byte[] buffer, Int32 offset, Int32 count) at System.IO.Stream.InternalCopyTo(Stream destination, Int32 bufferSize) at MediaBrowser.Server.Implementations.HttpServer.StreamWriter.WriteToInternal(Stream responseStream) InnerException: System.Net.Sockets.SocketException An established connection was aborted by the software in your host machine at System.Net.Sockets.Socket.Send(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags) at System.Net.Sockets.NetworkStream.Write(Byte[] buffer, Int32 offset, Int32 size) Hopefully this helps, i have tried rescanning my library, renaming folders and adding new libraries, restarting emby and my comp but i can't figure out why some videos fail. Any advice? Thanks [edit] a little search seemed to result in other posts that had been fixed in older releases. [edit 2] it plays through web player on windows fine [edit 3] converting the video to mkv made it work :S Edited June 4, 2016 by Shizuyori
Luke 42186 Posted June 4, 2016 Posted June 4, 2016 Hi there, welcome. Can you please discuss an example, and then provide the server log(s) that are modified during the time of that example? http://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ It could be that we're sending back a media format that the ps4 doesn't like. Thanks.
