rcrh 1 Posted June 2, 2016 Posted June 2, 2016 I'm trying to set up the emby for kodi addon and can't find anywhere to input my path substitution. SMPC 16.3 emby addon 2.2.10 I have playback mode set to native(direct paths). When I first ran the sync it told me it couldn't find /mnt/... (the local path on my server) and that I should set the path substitution. But on the Sunc Option tab there is nowhere to add the substitution info. Do I have to manually edit an XML file somewhere? Does the addon not work with SPMC? Thanks in advance.
xnappo 1611 Posted June 2, 2016 Posted June 2, 2016 Path substitution is done on the server. Settings->Library->Path Substitution (tab at top of library page)
Solution Luke 42242 Posted June 2, 2016 Solution Posted June 2, 2016 And you can learn more about it in our library setup wiki: https://github.com/MediaBrowser/Wiki/wiki/Library%20Setup Let us know if you still have questions. Thanks. 1
rcrh 1 Posted June 2, 2016 Author Posted June 2, 2016 Thanks Luke. It might help to change the message in the kodi addon to say "set the path substitution in your Emby Server". 1
Angelblue05 4132 Posted June 21, 2016 Posted June 21, 2016 Thanks Luke. It might help to change the message in the kodi addon to say "set the path substitution in your Emby Server". Thanks, I have made the adjustments for the next beta.
