carnage9270 7 Posted January 3, 2014 Posted January 3, 2014 Really loved this feature in MB2. I would usually set it to posterwall and adjust the icons so I had 7 movies horizontally and infinite scrolling down. Made it perfect size so my blind wife could read the titles. If possible, this one can go waaaaaay down at the bottom of the "To Do List". 4
A8HTPC 38 Posted January 8, 2014 Posted January 8, 2014 Same here. Addition to this is able to change the Poster image size and maybe the spacing too like in JRiver Media Center.
cylon 15 Posted January 8, 2014 Posted January 8, 2014 I believe there are multiple developers working on themes for MBT which will be released in the not-too-distant future. Once they are released you can find one that fits your needs most closely and request changes from the respective developer. 1
jespermart 5 Posted January 9, 2014 Posted January 9, 2014 Same here. Addition to this is able to change the Poster image size and maybe the spacing too like in JRiver Media Center. +1
Chest Rockwell 3 Posted January 10, 2014 Posted January 10, 2014 +1 Concur. Frankly, I have a hard time understanding why anyone would want horizontal scrolling. Seems very unnatural, especially since websites scroll vertically in web browsers and documents scroll vertically in word processors. It is also mouse unfriendly as the scroll wheel either does not work or is non-intuitive.
bigjohn 754 Posted January 10, 2014 Posted January 10, 2014 I'll add a +1 to this one as well. I use vertical scrolling on everything I can in MB.
carnage9270 7 Posted January 16, 2014 Author Posted January 16, 2014 Wish I knew how to code, sounds like we'll be waiting for a themer to kick this into high gear.
bennymac 47 Posted January 16, 2014 Posted January 16, 2014 (edited) +1 for this I really like this view configured on the subdued them in WMC (called thumb view). Use it pretty much all the time. Edited January 16, 2014 by bennymac
ebr 16331 Posted January 17, 2014 Posted January 17, 2014 I'll let Luke decide what he wants to do here but changing scrolling from horizontal to vertical (or vice versa) presents some real design challenges. The screen is normally laid out so that you can very quickly get to things like settings buttons. When you change the scrolling of the main list, that affects this layout and the ability to get to these things quickly and easily. So, supporting things like this are usually much more complicated than simply throwing a switch.
