Biomorph 6 Posted June 1, 2016 Posted June 1, 2016 When setting a sync job for unwatched content only, if the show in question has a 'Season 0' and this content is unwatched then it is what is cued first for the sync job, but this isn't what I would want to HAVE to watch first before commencing a series. Often these specials will contain spoilers of the show I've yet to watch. Yes I could mark it as watched, but I haven't watched it and so would prefer to have it still listed as unwatched. Can the sync creation have an option for TV jobs to ignore any Specials?
Luke 42245 Posted June 2, 2016 Posted June 2, 2016 Hi, yes this is a very good point, something we need to address. question - if you go to that series and edit the metadata, is the option to display specials within seasons enabled?
Biomorph 6 Posted June 2, 2016 Author Posted June 2, 2016 It is enabled, so I tried again with this disabled and the sync job has till listed S00E1 and S00E2 as the first two unwatched episodes to sync.
Luke 42245 Posted June 2, 2016 Posted June 2, 2016 well it won't change the existing sync job, but if you deleted it and created a new one it might be different. i'm not sure i haven't reviewed it yet.
Biomorph 6 Posted June 2, 2016 Author Posted June 2, 2016 The results were after having removed and recreated the job.
bluemonkey07 590 Posted June 2, 2016 Posted June 2, 2016 Maybe it should only sync specials with airs before/after metadata as episodes with this info should be part of the continuity of the show
