shilep 1 Posted June 1, 2016 Posted June 1, 2016 I just updated to version 3.0.5972.0 on a Windows 8.1 desktop. Had a little trouble with the update, which involved uninstalling the server and hiccups with installing 3.0.5972.0. But finally got the update installed after adjustments to Norton. However, the contents of my library is no longer visible. I haven't changed anything in the library. I see the library folder, but there is absolutely nothing listed in it. Not sure how to troubleshoot this. Any suggestions/help will be greatly appreciated.
Solution Luke 42186 Posted June 1, 2016 Solution Posted June 1, 2016 Also have you tried running a library scan? 1
