Your Paramour 0 Posted June 1, 2016 Posted June 1, 2016 For those who are unsure what the title is suggest, I'm talking about files that have this arrangement: http://i.imgur.com/YlkRVJk.png My setup is I'm using Freenas 9.10 running emby 3.0.5972.0 with ffmpeg 2.8.7 in freenas jail. Everything installed in the jail is compiled from ports with no mixmatch of compiled or installed from pkg. ffmpeg is compiled with the following options: ffmpeg version 2.8.7 Copyright (c) 2000-2016 the FFmpeg developers built with FreeBSD clang version 3.4.1 (tags/RELEASE_34/dot1-final 208032) 20140512 configuration: --prefix=/usr/local --mandir=/usr/local/man --datadir=/usr/local/share/ffmpeg --pkgconfigdir=/usr/local/libdata/pkgconfig --enable-shared --enable-gpl --enable-postproc --enable-avfilter --enable-avresample --enable-pthreads --disable-libstagefright-h264 --disable-libutvideo --disable-libsoxr --cc=cc --extra-cflags='-msse -I/usr/local/include/vorbis -I/usr/local/include' --extra-ldflags='-L/usr/local/lib ' --extra-libs=-lpthread --disable-libaacplus --disable-indev=alsa --disable-outdev=alsa --disable-libopencore-amrnb --disable-libopencore-amrwb --enable-libass --disable-libbs2b --disable-libcaca --disable-libcdio --disable-libcelt --disable-libdc1394 --disable-debug --disable-htmlpages --disable-libfaac --enable-libfdk-aac --disable-ffserver --disable-libflite --enable-fontconfig --enable-libfreetype --disable-frei0r --disable-libfribidi --disable-libgme --disable-libgsm --enable-iconv --disable-libilbc --disable-indev=jack --disable-ladspa --enable-libmp3lame --disable-libbluray --enable-mmx --disable-libmodplug --disable-openal --disable-indev=openal --disable-opencl --disable-libopencv --disable-opengl --disable-libopenh264 --disable-libopenjpeg --enable-libopus --disable-libpulse --disable-indev=pulse --disable-outdev=pulse --disable-libquvi --enable-runtime-cpudetect --disable-librtmp --enable-libschroedinger --disable-ffplay --disable-outdev=sdl --disable-libsmbclient --disable-libsnappy --disable-libspeex --enable-sse --disable-libssh --enable-libtheora --disable-libtwolame --disable-libv4l2 --disable-indev=v4l2 --disable-outdev=v4l2 --disable-vaapi --disable-vdpau --disable-libvidstab --enable-libvorbis --disable-libvo-aacenc --disable-libvo-amrwbenc --enable-libvpx --disable-libwavpack --enable-libwebp --disable-x11grab --enable-libx264 --enable-libx265 --disable-libxcb --enable-libxvid --disable-outdev=xv --disable-libzmq --disable-libzvbi --enable-gnutls --disable-openssl --disable-version3 --enable-nonfree libavutil 54. 31.100 / 54. 31.100 libavcodec 56. 60.100 / 56. 60.100 libavformat 56. 40.101 / 56. 40.101 libavdevice 56. 4.100 / 56. 4.100 libavfilter 5. 40.101 / 5. 40.101 libavresample 2. 1. 0 / 2. 1. 0 libswscale 3. 1.101 / 3. 1.101 libswresample 1. 2.101 / 1. 2.101 libpostproc 53. 3.100 / 53. 3.100 Hyper fast Audio and Video encoder usage: ffmpeg [options] [[infile options] -i infile]... {[outfile options] outfile}... Use -h to get full help or, even better, run 'man ffmpeg' For extra info here is the output from pkg info. ImageMagick-6.9.4.3,1 Image processing tools (legacy version) apr-1.5.2.1.5.4 Apache Portability Library autoconf-2.69 Automatically configure source code on many Un*x platforms autoconf-wrapper-20131203 Wrapper script for GNU autoconf automake-1.15_1 GNU Standards-compliant Makefile generator automake-wrapper-20131203 Wrapper script for GNU automake avahi-app-0.6.31_5 Service discovery on a local network bash-4.3.42_1 The GNU Project's Bourne Again SHell bdftopcf-1.0.5 Convert X font from BDF to PCF bigreqsproto-1.1.2 BigReqs extension headers binutils-2.25.1_2,1 GNU binary tools bison-2.7.1,1 Parser generator from FSF, (mostly) compatible with Yacc boehm-gc-7.4.2_5 Garbage collection and memory leak detection for C and C++ ca_root_nss-3.22.2 Root certificate bundle from the Mozilla Project cairo-1.14.6,2 Vector graphics library with cross-device output support cmake-3.5.2_1 Cross-platform Makefile generator cmake-modules-3.5.2 Modules and Templates for CMake cups-2.1.3_2 Common UNIX Printing System curl-7.49.0 Non-interactive tool to get files from FTP, GOPHER, HTTP(S) servers cvsps-2.1_1 Create patchset information from CVS damageproto-1.2.1 Damage extension headers db5-5.3.28_4 Oracle Berkeley DB, revision 5.3 dbus-1.8.20 Message bus system for inter-application communication dbus-glib-0.104 GLib bindings for the D-BUS messaging system dejavu-2.35 Bitstream Vera Fonts clone with a wider range of characters dialog4ports-0.1.5_2 Console Interface to configure ports docbook-1.5 Meta-port for the different versions of the DocBook DTD docbook-sgml-4.5_1 DocBook SGML DTD docbook-xml-5.0_3 DocBook XML DTD docbook-xsl-1.76.1_3 XSL DocBook stylesheets dri2proto-2.8 DRI2 prototype headers eigen-3.2.8 Lightweight library for vector and matrix math emby-server-3.0.5972 Home media server built using mono and other open source technologies encodings-1.0.4_3,1 X.Org Encoding fonts expat-2.1.1 XML 1.0 parser written in C fdk-aac-0.1.4 Port of the Fraunhofer FDK AAC Codec Library ffmpeg-2.8.7_1,1 Realtime audio/video encoder/converter and streaming server fftw3-3.3.3_2 Fast C routines to compute the Discrete Fourier Transform fftw3-float-3.3.3_2 Fast Discrete Fourier Transform (Single Precision C Routines) fixesproto-5.0 Fixes extension headers font-bh-ttf-1.0.3_3 X.Org Bigelow & Holmes TTF font font-misc-ethiopic-1.0.3_3 X.Org miscellaneous Ethiopic font font-misc-meltho-1.0.3_3 X.Org miscellaneous Meltho font font-util-1.3.1 Create an index of X font files in a directory fontconfig-2.11.1_2,1 XML-based font configuration API for X Windows fontsproto-2.1.3,1 Fonts extension headers freetype2-2.6.3 Free and portable TrueType font rendering engine frei0r-1.3_1 Minimalistic plugin API for video effects fribidi-0.19.7 Free Implementation of the Unicode Bidirectional Algorithm gbm-11.1.2 gbm library gdbm-1.12 GNU database manager gdk-pixbuf2-2.32.3_1 Graphic library for GTK+ getopt-1.1.6 Replacement for getopt(1) that supports GNU-style long options gettext-runtime-0.19.7 GNU gettext runtime libraries and programs gettext-tools-0.19.7 GNU gettext development and translation tools ghostscript9-agpl-base-9.16_5 Ghostscript 9.x PostScript interpreter, base part ghostscript9-agpl-x11-9.16_2 Ghostscript 9.x PostScript interpreter, X11 support giflib-5.1.3 Tools and library routines for working with GIF images git-2.8.1 Distributed source code management tool glib-2.46.2 Some useful routines of C programming (current stable version) glproto-1.4.17 GLX extension headers gmake-4.1_2 GNU version of 'make' utility gmake-lite-4.1_1 Minimalist version of gnu make gmp-5.1.3_3 Free library for arbitrary precision arithmetic gnome_subr-1.0 Common startup and shutdown subroutines used by GNOME scripts gnutls-3.4.11 GNU Transport Layer Security library gobject-introspection-1.46.0 Generate interface introspection data for GObject libraries graphite2-1.3.8 Rendering capabilities for complex non-Roman writing systems gsfonts-8.11_6 Standard Fonts for Ghostscript harfbuzz-1.2.3 OpenType text shaping engine help2man-1.43.3_1 Automatically generating simple manual pages from program output icu-55.1 International Components for Unicode (from IBM) indexinfo-0.2.4 Utility to regenerate the GNU info page index inputproto-2.3.1 Input extension headers intltool-0.51.0_1 Tools to internationalize various kinds of data files iso8879-1986_3 Character entity sets from ISO 8879:1986 (SGML) jasper-1.900.1_16 Implementation of the codec specified in the JPEG-2000 standard jbig2dec-0.13 Decoder implementation of the JBIG2 image compression format jbigkit-2.1_1 Lossless compression for bi-level images such as scanned pages, faxes jpeg-turbo-1.4.2 SIMD-accelerated JPEG codec which replaces libjpeg jsoncpp-1.7.2_1 JSON reader and writer library for C++ kbproto-1.0.7 KB extension headers lame-3.99.5_3 Fast MP3 encoder kit lcms2-2.7_2 Accurate, fast, and small-footprint color management engine libEGL-11.1.2 OpenEGL library libGL-11.1.2 OpenGL library that renders using GLX or DRI libICE-1.0.9_1,1 Inter Client Exchange library for X11 libSM-1.2.2_3,1 Session Management library for X11 libX11-1.6.3,1 X11 library libXau-1.0.8_3 Authentication Protocol library for X11 libXdamage-1.1.4_3 X Damage extension library libXdmcp-1.1.2 X Display Manager Control Protocol library libXext-1.3.3_1,1 X11 Extension library libXfixes-5.0.1_3 X Fixes extension library libXfont-1.5.1,2 X font library libXft-2.3.2_1 Client-sided font API for X applications libXi-1.7.6,1 X Input extension library libXrender-0.9.9 X Render extension library libXt-1.1.5,1 X Toolkit library libXv-1.0.10_3,1 X Video Extension library libXvMC-1.0.9 X Video Extension Motion Compensation library libXxf86vm-1.1.4_1 X Vidmode Extension libaacplus-2.0.2_8 HE-AAC+ Codec as Shared Library libarchive-3.2.0_1,1 Library to create and read several streaming archive formats libass-0.13.2 Portable ASS/SSA subtitle renderer libatomic_ops-7.4.0_1 Atomic operations access library libcheck-0.10.0 Unit test framework for C libclc-0.2.0.20151006 Required library functions for OpenCL C programming language libcroco-0.6.11 CSS2 parsing library libdaemon-0.14_1 Lightweight C library that eases the writing of UNIX daemons libdevq-0.0.2_1 Generic Device Query and Monitor interface libdrm-2.4.66,1 Userspace interface to kernel Direct Rendering Module services libedit-3.1.20150325_2 Command line editor library libffi-3.2.1 Foreign Function Interface libfontenc-1.1.3 The fontenc Library libfpx-1.3.1.4_1 Library routines for working with Flashpix images libgcrypt-1.7.0 General purpose crypto library based on code used in GnuPG libglapi-11.1.2 Common GL api library used by Mesa based ports libgpg-error-1.22 Common error values for all GnuPG components libgsf-1.14.36 Extensible I/O abstraction for dealing with structured file formats libiconv-1.14_9 Character set conversion library libidn-1.31 Internationalized Domain Names command line tool liblqr-1-0.4.1_8 Easy to use C/C++ seam carving library libltdl-2.4.6 System independent dlopen wrapper liblz4-131 LZ4 compression library, lossless and very fast libogg-1.3.2_1,4 Ogg bitstream library libpaper-1.1.24.4 Library providing routines for paper size management libpciaccess-0.13.4 Generic PCI access library libpthread-stubs-0.3_6 This library provides weak aliases for pthread functions librsvg2-2.40.13 Library for parsing and rendering SVG vector-graphic files libtasn1-4.8 ASN.1 structure parser library libtheora-1.1.1_6 Theora video codec for the Ogg multimedia streaming system libtool-2.4.6 Generic shared library support script libv4l-1.6.3_1 Video4Linux library libva-1.7.0 VAAPI wrapper and dummy driver libvdpau-1.1.1 VDPAU wrapper and tracing library libvorbis-1.3.5,3 Audio compression codec library libvpx-1.5.0_1 VP8/VP9 Codec SDK libwmf-0.2.8.4_15 Tools and library for converting Microsoft WMF (windows metafile) libx264-0.144.2533_1 H.264/MPEG-4 AVC Video Encoding (Library) libxcb-1.11.1 The X protocol C-language Binding (XCB) library libxml2-2.9.3 XML parser library for GNOME libxshmfence-1.2 Shared memory 'SyncFence' synchronization primitive libxslt-1.1.28_8 The XSLT C library for GNOME llvm37-3.7.1_2 LLVM and Clang lzo2-2.09 Portable speedy, lossless data compression library m4-1.4.17_1,1 GNU m4 makedepend-1.0.5,1 Dependency generator for makefiles mkfontdir-1.0.7 Create an index of X font files in a directory mkfontscale-1.1.2 Creates an index of scalable font files for X mono-4.2.3.4 Open source implementation of .NET Development Framework mpfr-3.1.4 Library for multiple-precision floating-point computations nano-2.4.3 Nano's ANOther editor, an enhanced free Pico clone nasm-2.11.08_1,1 General-purpose multi-platform x86 and amd64 assembler nettle-3.2 Low-level cryptographic library ninja-1.7.1,2 Ninja is a small build system closest in spirit to Make opencv-core-2.4.9_3 Open Source Computer Vision library openjpeg-2.1.1 Open-source JPEG 2000 codec opus-1.1.2 IETF audio codec orc-0.4.25 Library and toolset to operate arrays of data p11-kit-0.23.2 Library for loading and enumerating of PKCS#11 modules p5-Authen-SASL-2.16_1 Perl5 module for SASL authentication p5-Digest-HMAC-1.03_1 Perl5 interface to HMAC Message-Digest Algorithms p5-Error-0.17024 Error/exception handling in object-oriented programming style p5-GSSAPI-0.28_1 Perl extension providing access to the GSSAPIv2 library p5-IO-Socket-IP-0.37 Drop-in replacement for IO::Socket::INET supporting IPv4 and IPv6 p5-IO-Socket-SSL-2.027 Perl5 interface to SSL sockets p5-Locale-gettext-1.06 Message handling functions p5-Mozilla-CA-20160104 Perl extension for Mozilla CA cert bundle in PEM format p5-Net-SMTP-SSL-1.03 SSL support for Net::SMTP p5-Net-SSLeay-1.74 Perl5 interface to SSL p5-Socket-2.021 Networking constants and support functions p5-XML-Parser-2.44 Perl extension interface to James Clark's XML parser, expat pango-1.38.0_1 Open-source framework for the layout and rendering of i18n text patch-2.7.5 GNU patch utility pciids-20160522 Database of all known IDs used in PCI devices pcre-8.38_1 Perl Compatible Regular Expressions library perl5-5.20.3_13 Practical Extraction and Report Language pixman-0.34.0 Low-level pixel manipulation library pkg-1.8.3 Package manager pkgconf-0.9.12_1 Utility to help to configure compiler and linker flags png-1.6.21 Library for manipulating PNG images presentproto-1.0 Present protocol specification py27-Babel-2.3.4 Collection of tools for internationalizing Python applications py27-Jinja2-2.8 Fast and easy to use stand-alone template engine py27-MarkupSafe-0.23 Implements XML/HTML/XHTML Markup safe string for Python py27-alabaster-0.7.6 Modified Kr Sphinx theme py27-docutils-0.12 Python Documentation Utilities py27-enum34-1.0.4 Python 3.4 Enum backported to 3.3, 3.2, 3.1, 2.7 py27-imagesize-0.7.1 Python image size library py27-pygments-2.1.3 Syntax highlighter written in Python py27-pystemmer-1.3.0_1 Snowball Stemming Algorithms for Information Retrieval py27-pytz-2016.4,1 World Timezone Definitions for Python py27-setuptools27-20.0 Python packages installer py27-six-1.10.0 Python 2 and 3 compatibility utilities py27-snowballstemmer-1.2.0_1 Snowball stemming library collection for Python py27-sphinx-1.4.1 Python documentation generator py27-sphinx_rtd_theme-0.1.9 Mobile-friendly py-sphinx theme python2-2_3 The "meta-port" for version 2 of the Python interpreter python27-2.7.11_2 Interpreted object-oriented programming language renderproto-0.11.1 RenderProto protocol headers schroedinger-1.0.11_4 High-speed Dirac codec scons-2.5.0 Build tool alternative to make sdocbook-xml-1.1_2,2 "Simplified" DocBook XML DTD serf-1.3.8_1 Serf HTTP client library sqlite3-3.13.0 SQL database engine in a C library svgalib-1.4.3_7 Low level console graphics library swig13-1.3.40_1 Simplified Wrapper and Interface Generator texi2html-5.0_1,1 Texinfo to HTML converter tiff-4.0.6_1 Tools and library routines for working with TIFF images tpm-emulator-0.7.4_1 Trusted Platform Module (TPM) emulator trousers-0.3.13 Open-source TCG Software Stack v4l_compat-1.6.3 Video4Linux IOCTL header files videoproto-2.3.2 Video extension headers w3m-0.5.3_5 Pager/text-based WWW browser webp-0.5.0 Google WebP image format conversion tool x265-1.9 H.265/High Efficiency Video Coding (HEVC) format xcb-proto-1.11_1 The X protocol C-language Binding (XCB) protocol xcb-util-0.4.0_1,1 Module with libxcb/libX11 extension/replacement libraries xcb-util-renderutil-0.3.9_1 Convenience functions for the Render extension xcmiscproto-1.2.2 XCMisc extension headers xextproto-7.3.0 XExt extension headers xf86bigfontproto-1.2.0 XFree86-Bigfont extension headers xf86vidmodeproto-2.3.1 XFree86-VidModeExtension extension headers xmlcatmgr-2.2_2 SGML and XML catalog manager xmlcharent-0.3_2 XML character entities xmlto-0.0.28 Front-end to an XSL toolchain xorg-fonts-truetype-7.7_1 X.Org TrueType fonts xorg-macros-1.19.0 X.Org development aclocal macros xproto-7.0.28 X11 protocol headers xtrans-1.3.5 Abstract network code for X xvid-1.3.4,1 Opensource MPEG-4 codec, based on OpenDivx yasm-1.2.0 Complete rewrite of the NASM assembler The failures happen when I'm streaming via DLNA to either a PS3 or PS4 (it fails on both). Here it was I believe is the relevant section of the server log showing the failure (Note: there is no transcode log generated because it doesn't even get to the transcoding stage) 2016-06-01 16:37:27.6023 Info HttpServer: HTTP GET http://192.168.1.3:8096/dlna/24c02322338687f2b0a7d10f7acd83ab/contentdirectory/contentdirectory.xml. UserAgent: MediaPlayer/1.50 UPnP/1.0 DLNADOC/1.50 (PlayStation 4) 2016-06-01 16:37:27.6192 Info HttpServer: HTTP Response 200 to 192.168.1.30. Time: 17ms. http://192.168.1.3:8096/dlna/24c02322338687f2b0a7d10f7acd83ab/contentdirectory/contentdirectory.xml 2016-06-01 16:37:27.6293 Info HttpServer: HTTP POST http://192.168.1.3:8096/dlna/24c02322338687f2b0a7d10f7acd83ab/contentdirectory/control. UserAgent: MediaPlayer/1.50 UPnP/1.0 DLNADOC/1.50 (PlayStation 4) 2016-06-01 16:37:27.7874 Info HttpServer: HTTP Response 200 to 192.168.1.30. Time: 158ms. http://192.168.1.3:8096/dlna/24c02322338687f2b0a7d10f7acd83ab/contentdirectory/control 2016-06-01 16:37:27.7883 Info HttpServer: HTTP POST http://192.168.1.3:8096/dlna/24c02322338687f2b0a7d10f7acd83ab/contentdirectory/control. UserAgent: MediaPlayer/1.50 UPnP/1.0 DLNADOC/1.50 (PlayStation 4) 2016-06-01 16:37:28.0856 Info HttpServer: HTTP Response 200 to 192.168.1.30. Time: 297ms. http://192.168.1.3:8096/dlna/24c02322338687f2b0a7d10f7acd83ab/contentdirectory/control 2016-06-01 16:37:29.6046 Info HttpServer: HTTP POST http://192.168.1.3:8096/dlna/24c02322338687f2b0a7d10f7acd83ab/contentdirectory/control. UserAgent: MediaPlayer/1.50 UPnP/1.0 DLNADOC/1.50 (PlayStation 4) 2016-06-01 16:37:30.2292 Info HttpServer: HTTP Response 200 to 192.168.1.30. Time: 625ms. http://192.168.1.3:8096/dlna/24c02322338687f2b0a7d10f7acd83ab/contentdirectory/control 2016-06-01 16:37:32.7406 Info HttpServer: HTTP POST http://192.168.1.3:8096/dlna/24c02322338687f2b0a7d10f7acd83ab/contentdirectory/control. UserAgent: MediaPlayer/1.50 UPnP/1.0 DLNADOC/1.50 (PlayStation 4) 2016-06-01 16:37:32.8060 Info HttpClient: HttpClientManager POST: http://192.168.1.29:52235/upnp/control/AVTransport1 2016-06-01 16:37:32.8744 Info HttpServer: HTTP Response 200 to 192.168.1.30. Time: 134ms. http://192.168.1.3:8096/dlna/24c02322338687f2b0a7d10f7acd83ab/contentdirectory/control 2016-06-01 16:37:35.7941 Info HttpServer: HTTP POST http://192.168.1.3:8096/dlna/24c02322338687f2b0a7d10f7acd83ab/contentdirectory/control. UserAgent: MediaPlayer/1.50 UPnP/1.0 DLNADOC/1.50 (PlayStation 4) 2016-06-01 16:37:35.8383 Info HttpServer: HTTP Response 200 to 192.168.1.30. Time: 44ms. http://192.168.1.3:8096/dlna/24c02322338687f2b0a7d10f7acd83ab/contentdirectory/control 2016-06-01 16:37:36.6281 Info HttpServer: HTTP POST http://192.168.1.3:8096/dlna/24c02322338687f2b0a7d10f7acd83ab/contentdirectory/control. UserAgent: MediaPlayer/1.50 UPnP/1.0 DLNADOC/1.50 (PlayStation 4) 2016-06-01 16:37:36.7372 Info UpnpContentDirectory: Not eligible for DirectPlay due to unsupported subtitles 2016-06-01 16:37:36.7372 Info UpnpContentDirectory: Not eligible for DirectStream due to unsupported subtitles 2016-06-01 16:37:36.7372 Info UpnpContentDirectory: Profile: Sony PlayStation 4, Path: /embymedia/TV/The Expanse/Season 1/The.Expanse.S01E01.1080p.WEB-DL.DD5.1.H.264.mkv, isEligibleForDirectPlay: False, isEligibleForDirectStream: False 2016-06-01 16:37:36.7943 Info UpnpContentDirectory: Profile: Sony PlayStation 4, Path: /embymedia/TV/The Expanse/Season 1/The.Expanse.S01E01.1080p.WEB-DL.DD5.1.H.264_SUB-NOT-FORCED.mkv, isEligibleForDirectPlay: True, isEligibleForDirectStream: True 2016-06-01 16:37:36.8668 Info HttpServer: HTTP Response 200 to 192.168.1.30. Time: 239ms. http://192.168.1.3:8096/dlna/24c02322338687f2b0a7d10f7acd83ab/contentdirectory/control 2016-06-01 16:37:37.1286 Info HttpServer: HTTP GET http://192.168.1.3:8096/Items/0ee633bd50c7b724442315d58c1b8cfa/Images/Primary/0/298b6db485547f4360a82bd0fe68b353/jpg/480/480/0/0. UserAgent: MediaPlayer/1.50 libhttp/3.50 (PlayStation 4) 2016-06-01 16:37:37.1726 Info HttpServer: HTTP Response 200 to 192.168.1.30. Time: 44ms. http://192.168.1.3:8096/Items/0ee633bd50c7b724442315d58c1b8cfa/Images/Primary/0/298b6db485547f4360a82bd0fe68b353/jpg/480/480/0/0 2016-06-01 16:37:37.3457 Info HttpServer: HTTP GET http://192.168.1.3:8096/Items/54f66ae182be387ec2d09118df478718/Images/Primary/0/f54b75dd6b88e61222f03cb8c7435000/jpg/480/480/0/0. UserAgent: MediaPlayer/1.50 libhttp/3.50 (PlayStation 4) 2016-06-01 16:37:37.3498 Info HttpServer: HTTP Response 200 to 192.168.1.30. Time: 4ms. http://192.168.1.3:8096/Items/54f66ae182be387ec2d09118df478718/Images/Primary/0/f54b75dd6b88e61222f03cb8c7435000/jpg/480/480/0/0 2016-06-01 16:37:38.0546 Info HttpServer: HTTP GET http://192.168.1.3:8096/videos/0ee633bd50c7b724442315d58c1b8cfa/stream.ts?Params=149b85ca768b749a33fc2989d9f3697e;test;0ee633bd50c7b724442315d58c1b8cfa;false;h264;aac;1;2;15360000;320000;;30;1920;1080;0;41;;;;;;;;0ee633bd50c7b724442315d58c1b8cfa;false;false;Encode;. UserAgent: MediaPlayer/1.50 libhttp/3.50 (PlayStation 4) 2016-06-01 16:37:38.1411 Error DtoUtils: ServiceBase<TRequest>::Service Exception *** Error Report *** Version: 3.0.5972.0 Command line: /usr/local/lib/emby-server/MediaBrowser.Server.Mono.exe -ffmpeg /usr/local/bin/ffmpeg -ffprobe /usr/local/bin/ffprobe -programdata /var/db/emby-server Operating system: Unix 10.3.0.0 Processor count: 8 64-Bit OS: True 64-Bit Process: True Program data path: /var/db/emby-server Mono: 4.2.3 (Stable 4.2.3.4/832de4b Mon May 30 08:55:22 UTC 2016) Application Path: /usr/local/lib/emby-server/MediaBrowser.Server.Mono.exe Input string was not in a correct format. System.FormatException at System.Number.StringToNumber (System.String str, NumberStyles options, System.NumberBuffer& number, System.Globalization.NumberFormatInfo info, Boolean parseDecimal) <0x117e20 + 0x00116> in <filename unknown>:0 at System.Number.ParseInt32 (System.String s, NumberStyles style, System.Globalization.NumberFormatInfo info) <0x117c80 + 0x000a1> in <filename unknown>:0 at System.Int32.Parse (System.String s, IFormatProvider provider) <0x118480 + 0x00035> in <filename unknown>:0 at MediaBrowser.Api.Playback.BaseStreamingService.ParseParams (MediaBrowser.Api.Playback.StreamRequest request) <0xb481e0 + 0x0094d> in <filename unknown>:0 at MediaBrowser.Api.Playback.BaseStreamingService+<GetState>c__async3.MoveNext () <0xb45d50 + 0x0023c> in <filename unknown>:0 2016-06-01 16:37:38.1477 Error HttpServer: Error processing request for /videos/0ee633bd50c7b724442315d58c1b8cfa/stream.ts?Params=149b85ca768b749a33fc2989d9f3697e;test;0ee633bd50c7b724442315d58c1b8cfa;false;h264;aac;1;2;15360000;320000;;30;1920;1080;0;41;;;;;;;;0ee633bd50c7b724442315d58c1b8cfa;false;false;Encode; *** Error Report *** Version: 3.0.5972.0 Command line: /usr/local/lib/emby-server/MediaBrowser.Server.Mono.exe -ffmpeg /usr/local/bin/ffmpeg -ffprobe /usr/local/bin/ffprobe -programdata /var/db/emby-server Operating system: Unix 10.3.0.0 Processor count: 8 64-Bit OS: True 64-Bit Process: True Program data path: /var/db/emby-server Mono: 4.2.3 (Stable 4.2.3.4/832de4b Mon May 30 08:55:22 UTC 2016) Application Path: /usr/local/lib/emby-server/MediaBrowser.Server.Mono.exe Input string was not in a correct format. ServiceStack.HttpError No Stack Trace Available 2016-06-01 16:37:38.2028 Info HttpServer: HTTP Response 500 to 192.168.1.30. Time: 151ms. http://192.168.1.3:8096/videos/0ee633bd50c7b724442315d58c1b8cfa/stream.ts?Params=149b85ca768b749a33fc2989d9f3697e;test;0ee633bd50c7b724442315d58c1b8cfa;false;h264;aac;1;2;15360000;320000;;30;1920;1080;0;41;;;;;;;;0ee633bd50c7b724442315d58c1b8cfa;false;false;Encode; 2016-06-01 16:37:38.2117 Info HttpServer: HTTP GET http://192.168.1.3:8096/videos/0ee633bd50c7b724442315d58c1b8cfa/stream.ts?Params=149b85ca768b749a33fc2989d9f3697e;test;0ee633bd50c7b724442315d58c1b8cfa;false;h264;aac;1;2;15360000;320000;;30;1920;1080;0;41;;;;;;;;0ee633bd50c7b724442315d58c1b8cfa;false;false;Encode;. UserAgent: MediaPlayer/1.50 libhttp/3.50 (PlayStation 4) 2016-06-01 16:37:38.2140 Error DtoUtils: ServiceBase<TRequest>::Service Exception *** Error Report *** Version: 3.0.5972.0 Command line: /usr/local/lib/emby-server/MediaBrowser.Server.Mono.exe -ffmpeg /usr/local/bin/ffmpeg -ffprobe /usr/local/bin/ffprobe -programdata /var/db/emby-server Operating system: Unix 10.3.0.0 Processor count: 8 64-Bit OS: True 64-Bit Process: True Program data path: /var/db/emby-server Mono: 4.2.3 (Stable 4.2.3.4/832de4b Mon May 30 08:55:22 UTC 2016) Application Path: /usr/local/lib/emby-server/MediaBrowser.Server.Mono.exe Input string was not in a correct format. System.FormatException at System.Number.StringToNumber (System.String str, NumberStyles options, System.NumberBuffer& number, System.Globalization.NumberFormatInfo info, Boolean parseDecimal) <0x117e20 + 0x00116> in <filename unknown>:0 at System.Number.ParseInt32 (System.String s, NumberStyles style, System.Globalization.NumberFormatInfo info) <0x117c80 + 0x000a1> in <filename unknown>:0 at System.Int32.Parse (System.String s, IFormatProvider provider) <0x118480 + 0x00035> in <filename unknown>:0 at MediaBrowser.Api.Playback.BaseStreamingService.ParseParams (MediaBrowser.Api.Playback.StreamRequest request) <0xb481e0 + 0x0094d> in <filename unknown>:0 at MediaBrowser.Api.Playback.BaseStreamingService+<GetState>c__async3.MoveNext () <0xb45d50 + 0x0023c> in <filename unknown>:0 2016-06-01 16:37:38.2142 Error HttpServer: Error processing request for /videos/0ee633bd50c7b724442315d58c1b8cfa/stream.ts?Params=149b85ca768b749a33fc2989d9f3697e;test;0ee633bd50c7b724442315d58c1b8cfa;false;h264;aac;1;2;15360000;320000;;30;1920;1080;0;41;;;;;;;;0ee633bd50c7b724442315d58c1b8cfa;false;false;Encode; *** Error Report *** Version: 3.0.5972.0 Command line: /usr/local/lib/emby-server/MediaBrowser.Server.Mono.exe -ffmpeg /usr/local/bin/ffmpeg -ffprobe /usr/local/bin/ffprobe -programdata /var/db/emby-server Operating system: Unix 10.3.0.0 Processor count: 8 64-Bit OS: True 64-Bit Process: True Program data path: /var/db/emby-server Mono: 4.2.3 (Stable 4.2.3.4/832de4b Mon May 30 08:55:22 UTC 2016) Application Path: /usr/local/lib/emby-server/MediaBrowser.Server.Mono.exe Input string was not in a correct format. ServiceStack.HttpError No Stack Trace Available 2016-06-01 16:37:38.2161 Info HttpServer: HTTP Response 500 to 192.168.1.30. Time: 5ms. http://192.168.1.3:8096/videos/0ee633bd50c7b724442315d58c1b8cfa/stream.ts?Params=149b85ca768b749a33fc2989d9f3697e;test;0ee633bd50c7b724442315d58c1b8cfa;false;h264;aac;1;2;15360000;320000;;30;1920;1080;0;41;;;;;;;;0ee633bd50c7b724442315d58c1b8cfa;false;false;Encode; 2016-06-01 16:37:38.2358 Info HttpServer: HTTP GET http://192.168.1.3:8096/videos/0ee633bd50c7b724442315d58c1b8cfa/stream.ts?Params=149b85ca768b749a33fc2989d9f3697e;test;0ee633bd50c7b724442315d58c1b8cfa;false;h264;aac;1;2;15360000;320000;;30;1920;1080;0;41;;;;;;;;0ee633bd50c7b724442315d58c1b8cfa;false;false;Encode;. UserAgent: MediaPlayer/1.50 libhttp/3.50 (PlayStation 4) 2016-06-01 16:37:38.2380 Error DtoUtils: ServiceBase<TRequest>::Service Exception *** Error Report *** Version: 3.0.5972.0 Command line: /usr/local/lib/emby-server/MediaBrowser.Server.Mono.exe -ffmpeg /usr/local/bin/ffmpeg -ffprobe /usr/local/bin/ffprobe -programdata /var/db/emby-server Operating system: Unix 10.3.0.0 Processor count: 8 64-Bit OS: True 64-Bit Process: True Program data path: /var/db/emby-server Mono: 4.2.3 (Stable 4.2.3.4/832de4b Mon May 30 08:55:22 UTC 2016) Application Path: /usr/local/lib/emby-server/MediaBrowser.Server.Mono.exe Input string was not in a correct format. System.FormatException at System.Number.StringToNumber (System.String str, NumberStyles options, System.NumberBuffer& number, System.Globalization.NumberFormatInfo info, Boolean parseDecimal) <0x117e20 + 0x00116> in <filename unknown>:0 at System.Number.ParseInt32 (System.String s, NumberStyles style, System.Globalization.NumberFormatInfo info) <0x117c80 + 0x000a1> in <filename unknown>:0 at System.Int32.Parse (System.String s, IFormatProvider provider) <0x118480 + 0x00035> in <filename unknown>:0 at MediaBrowser.Api.Playback.BaseStreamingService.ParseParams (MediaBrowser.Api.Playback.StreamRequest request) <0xb481e0 + 0x0094d> in <filename unknown>:0 at MediaBrowser.Api.Playback.BaseStreamingService+<GetState>c__async3.MoveNext () <0xb45d50 + 0x0023c> in <filename unknown>:0 2016-06-01 16:37:38.2382 Error HttpServer: Error processing request for /videos/0ee633bd50c7b724442315d58c1b8cfa/stream.ts?Params=149b85ca768b749a33fc2989d9f3697e;test;0ee633bd50c7b724442315d58c1b8cfa;false;h264;aac;1;2;15360000;320000;;30;1920;1080;0;41;;;;;;;;0ee633bd50c7b724442315d58c1b8cfa;false;false;Encode; *** Error Report *** Version: 3.0.5972.0 Command line: /usr/local/lib/emby-server/MediaBrowser.Server.Mono.exe -ffmpeg /usr/local/bin/ffmpeg -ffprobe /usr/local/bin/ffprobe -programdata /var/db/emby-server Operating system: Unix 10.3.0.0 Processor count: 8 64-Bit OS: True 64-Bit Process: True Program data path: /var/db/emby-server Mono: 4.2.3 (Stable 4.2.3.4/832de4b Mon May 30 08:55:22 UTC 2016) Application Path: /usr/local/lib/emby-server/MediaBrowser.Server.Mono.exe Input string was not in a correct format. ServiceStack.HttpError No Stack Trace Available 2016-06-01 16:37:38.2401 Info HttpServer: HTTP Response 500 to 192.168.1.30. Time: 5ms. http://192.168.1.3:8096/videos/0ee633bd50c7b724442315d58c1b8cfa/stream.ts?Params=149b85ca768b749a33fc2989d9f3697e;test;0ee633bd50c7b724442315d58c1b8cfa;false;h264;aac;1;2;15360000;320000;;30;1920;1080;0;41;;;;;;;;0ee633bd50c7b724442315d58c1b8cfa;false;false;Encode; 2016-06-01 16:37:38.2433 Info HttpServer: HTTP GET http://192.168.1.3:8096/videos/0ee633bd50c7b724442315d58c1b8cfa/stream.ts?Params=149b85ca768b749a33fc2989d9f3697e;test;0ee633bd50c7b724442315d58c1b8cfa;false;h264;aac;1;2;15360000;320000;;30;1920;1080;0;41;;;;;;;;0ee633bd50c7b724442315d58c1b8cfa;false;false;Encode;. UserAgent: MediaPlayer/1.50 libhttp/3.50 (PlayStation 4) 2016-06-01 16:37:38.2456 Error DtoUtils: ServiceBase<TRequest>::Service Exception *** Error Report *** Version: 3.0.5972.0 Command line: /usr/local/lib/emby-server/MediaBrowser.Server.Mono.exe -ffmpeg /usr/local/bin/ffmpeg -ffprobe /usr/local/bin/ffprobe -programdata /var/db/emby-server Operating system: Unix 10.3.0.0 Processor count: 8 64-Bit OS: True 64-Bit Process: True Program data path: /var/db/emby-server Mono: 4.2.3 (Stable 4.2.3.4/832de4b Mon May 30 08:55:22 UTC 2016) Application Path: /usr/local/lib/emby-server/MediaBrowser.Server.Mono.exe Input string was not in a correct format. System.FormatException at System.Number.StringToNumber (System.String str, NumberStyles options, System.NumberBuffer& number, System.Globalization.NumberFormatInfo info, Boolean parseDecimal) <0x117e20 + 0x00116> in <filename unknown>:0 at System.Number.ParseInt32 (System.String s, NumberStyles style, System.Globalization.NumberFormatInfo info) <0x117c80 + 0x000a1> in <filename unknown>:0 at System.Int32.Parse (System.String s, IFormatProvider provider) <0x118480 + 0x00035> in <filename unknown>:0 at MediaBrowser.Api.Playback.BaseStreamingService.ParseParams (MediaBrowser.Api.Playback.StreamRequest request) <0xb481e0 + 0x0094d> in <filename unknown>:0 at MediaBrowser.Api.Playback.BaseStreamingService+<GetState>c__async3.MoveNext () <0xb45d50 + 0x0023c> in <filename unknown>:0 2016-06-01 16:37:38.2456 Error HttpServer: Error processing request for /videos/0ee633bd50c7b724442315d58c1b8cfa/stream.ts?Params=149b85ca768b749a33fc2989d9f3697e;test;0ee633bd50c7b724442315d58c1b8cfa;false;h264;aac;1;2;15360000;320000;;30;1920;1080;0;41;;;;;;;;0ee633bd50c7b724442315d58c1b8cfa;false;false;Encode; *** Error Report *** Version: 3.0.5972.0 Command line: /usr/local/lib/emby-server/MediaBrowser.Server.Mono.exe -ffmpeg /usr/local/bin/ffmpeg -ffprobe /usr/local/bin/ffprobe -programdata /var/db/emby-server Operating system: Unix 10.3.0.0 Processor count: 8 64-Bit OS: True 64-Bit Process: True Program data path: /var/db/emby-server Mono: 4.2.3 (Stable 4.2.3.4/832de4b Mon May 30 08:55:22 UTC 2016) Application Path: /usr/local/lib/emby-server/MediaBrowser.Server.Mono.exe Input string was not in a correct format. ServiceStack.HttpError No Stack Trace Available I've tried googling the Input string was not in a correct format error in relation to mono but I haven't had any luck trying to solve this issue. I Know the failure is related to those subtitles because if i remux the mkv file with the sub file included, with the default track at output flag disabled the the file transcodes fine. As a side note, if I use the freenas emby-server plugin the file works as it should, but I would rather have a normal jail setup for emby so I can keep it more up to date than the plugin. Also keep In mind I've only been using BSD for the last month or so as I've been setting up my NAS, but I'm at the end of my powers for this problem and any help would be greatly appreciated.
Luke 42237 Posted June 1, 2016 Posted June 1, 2016 Hi, this has been resolved for the next release of the server, thanks.
Your Paramour 0 Posted June 1, 2016 Author Posted June 1, 2016 Was this a bug introduced into 3.0.5972.0?
Your Paramour 0 Posted June 5, 2016 Author Posted June 5, 2016 Is there any timeline for when a new version with this problem fixed?
josh4trunks 70 Posted June 5, 2016 Posted June 5, 2016 I'll hopefully get an update to this plugin out next week. Maybe this week if I find time.
Your Paramour 0 Posted June 7, 2016 Author Posted June 7, 2016 Just to clarify, the plugin running on emby-server 3.0.5934.0 works fine, it's the latest version 3.0.5972.0 which is causes the problems.
Luke 42237 Posted June 7, 2016 Posted June 7, 2016 Yup, and this is resolved for the next release of the server.
Your Paramour 0 Posted June 23, 2016 Author Posted June 23, 2016 Is there anything I can do in the interim to fix this issue because currently emby is unusable for me.
Luke 42237 Posted June 23, 2016 Posted June 23, 2016 This only affects Dlna. Workaround is to configure user preferences to never play subtitles. Click the user icon in the top right of the web interface -> playback settings.
