Dynamic Range Compression Setting Issue
Hi, I was recently messing around with the dynamic range compression settings, but now I want to turn it off.  Unfortunately, when I select 'None' it does not change to 'None', instead it remains at the % it was before.  Is there a configuration file I can edit to turn it off?
We'll look into it, thanks.
