tobedeleted 4 Posted June 26, 2016 Posted June 26, 2016 I installed a Xposed module called Marshmallow SD fix and now I can sync to external SD. (I don't know if Xposed did this or a update of the app.) However, my /data is filled up as always. Is there any way to properly contribute to fix this annoying bug???? I'm tired of posting "the app is unusable for me as it trashes the /data partition on my Android devices" in the thread.
Luke 42243 Posted June 26, 2016 Posted June 26, 2016 It will be reviewed for a future release, thanks.
sh0rty 727 Posted June 28, 2016 Posted June 28, 2016 (edited) Thanks. I may have finally tracked it down. 2.7.01 is headed up to the open beta. Please try that and report back. Fyi, you'll need to reconfigure your custom sync path. @@shorty1483 fyi. Thanks. Still "Failed to create Folder". 1ac84c07-9e27-4aca-848a-7e8ce4a1fb98.log Edited June 28, 2016 by shorty1483
Luke 42243 Posted June 28, 2016 Posted June 28, 2016 Still "Failed to create Folder". Might be out of my control unfortunately and I'll need to report to the developer of the file picker. but if the folder is already there the ability to sync to it should now be fixed.
sh0rty 727 Posted June 28, 2016 Posted June 28, 2016 (edited) Unfortunately not here. When I manually create the folder outside of the Emby app, Emby fails to create the required subfolders for the different sync jobs. Edit: Also this suggestion fails http://emby.media/community/index.php?/topic/35354-unable-to-sync-to-android-phone/&do=findComment&comment=339507 a05be586-4a68-48c9-b11a-427d7acd882b.log Edited June 28, 2016 by shorty1483
Luke 42243 Posted July 17, 2017 Posted July 17, 2017 @@Larx @@shorty1483 @@fatbstrd @@scope99 @@Nutellaeis @@romaing 2.9.32 is rolling out and supports offline browsing and playback. The feature is still very new so please make sure to leave your feedback and we will continue to improve it. Thanks ! 1
