Add channel numbers to guide
revengineer
I see that channel numbers in the guide are omitted if a channel logo is present. With a total of ~300 channels, having the channel numbers in the guide for all channels is a must. Navigating by logo is very difficult. Please add the numbers to the guide for all channels. Thank you.
  • Like 1
Guest asrequested
Yours don't show? Mine are all there in Chrome
Edited by Doofus
revengineer
Nope looks like the attached image for me. And it's the same on Chrome and Firefox.
Edited by revengineer
revengineer
It seems this has to do with the width of the browser windows. If I make it wider, the numbers show. However, the size of the panels that show the logo and channel number does not really change when I widen the windows. Looks like a bug to me.
Guest asrequested
Mine looks like that if I window ET, but at full screen they are all there. I have reported that a few times. This is what it looks like after installing 3.1.1, in ET when windowed.
revengineer
It also looks like that in Chrome on Android. While I can use full screen et on the PC, on Android the browser is important because live tv in the app is presently crippled.
Guest asrequested
The guide is working much better lately (but still isn't scrolling smoothly), in my android app. Live tv is working fine for me. But yes, the channel numbers are not present.
Edited by Doofus
revengineer
Problem with live TV on android is that I can only access a fraction of my channels because the number of channels in the guide is limited. However, this is posted elsewhere and digresses from the topic.
Guest asrequested
Well, it's been fixed in ET. Great job, Luke!
revengineer
BUT: The problem is not fixed in browsers as reported in the OP.
  • Like 1
