homerfan 3 Posted May 28, 2016 Posted May 28, 2016 Hello All, Hope someone can help. I've been scratching my head on this one for a couple of hours now. When trying to play Live TV, I get no audio. The weird thing is that no transcoding log is being generated so I can not check it out to try and troubleshoot. Below is my current setup. Sever - Version 3.0.5972.0 On Ubuntu App - Emby for Fire Tv 1.1.90a Tuners - HD Homerun Prime 2016512atest1 Firmware Attached is a server log but no transcoding log because the app is not generating one. If you see the screenshots, you will see the time that transcode logs were generated and the times that i tried playing a a channel. Let me know if you would like me to provide anymore info. Log.txt
Solution Luke 42243 Posted May 28, 2016 Solution Posted May 28, 2016 Hi, welcome. Try enabling the setting in the app to downmix audio to stereo. 1
homerfan 3 Posted May 28, 2016 Author Posted May 28, 2016 Thank you so much! That did the trick for the audio. I am however still not getting a transcode log.
Luke 42243 Posted May 28, 2016 Posted May 28, 2016 That's OK. The important thing is whether you're having any issues or not, not what the log is doing. Thanks.
ebr 16337 Posted May 28, 2016 Posted May 28, 2016 When you first ran the app, there should have been a message that popped up telling you that, if you were hooked up to just TV speakers, you might not hear sound on some material and then it gave you the option to choose the downmix setting. Do you remember seeing that message?
