SikSlayer 254 Posted May 26, 2016 Posted May 26, 2016 I finally got my M-card for my HD HomeRun Prime, and it works great in WMC, and ServerWMC is passing along the channels just fine, mostly. I removed my ATSC analog tuner from the tuner pool in WMC, which I would remove it completely if I didn't use it for FM radio. The issue I have now is, I see every channel twice in Emby, or in Emby Theater. Via Kodi, they only show up once. It might be a ServerWMC setting, but I don't know how to reset it, in case I changed any defaults. Any ideas as to what the problem is?
Solution krustyreturns 191 Posted May 26, 2016 Solution Posted May 26, 2016 My guess is that emby's integrated tv picked up the tuner and added the channels also. If you only want the channels to be served by swmc you need to disable the tuners in Emby. 1
SikSlayer 254 Posted May 26, 2016 Author Posted May 26, 2016 My guess is that emby's integrated tv picked up the tuner and added the channels also. If you only want the channels to be served by swmc you need to disable the tuners in Emby. I did just that and it worked! Thanks a bunch.
