3dcooper 0 Posted May 24, 2016 Posted May 24, 2016 Hello May I ask if there are any plans to put the Emby Home view icons/tiles directly on the Android TV Leanback interface. Thanks Dave
ebr 16339 Posted May 24, 2016 Posted May 24, 2016 Not sure what you mean but we already create recommendation tiles on the device home screen.
3dcooper 0 Posted May 25, 2016 Author Posted May 25, 2016 Hi ebr Thanks for responding. Let me try and explain a little better. We have an shield and it boots into android leanback (as you well know). It has all the icons for games YouTube etc. The key thing is may family like this interface and would like to select TV, music, movies or Google play directly from here. Up until now I've been setting up smpc to launch instead of leanback but I'm getting tied of the whole kodi thing! It would be good to have the emby home screen / library icons direct on lean back e.g 1. Logon/ who is login in 2. Emby TV 3. Emby music 4 Emby Movies Etc Meaning someone using leanback could see a live TV icon rather than have to select emby then TV. Does this make sense? Thanks Dave
ebr 16339 Posted May 25, 2016 Posted May 25, 2016 That makes sense but there is no facility in the framework for creating multiple entry points for an app from the device home - other than the recommendations which we are using now. Notice, none of your other apps are doing that either...
3dcooper 0 Posted May 25, 2016 Author Posted May 25, 2016 And the emby client couldn't be separate apps...bar the login control? As at the minute there is a non intuitive step between leanback and emby depending on the content you want to consume?? That said maybe I've spent to much time with smpc as my launcher and I've just become used to the idea? Thanks again Dave
ebr 16339 Posted May 25, 2016 Posted May 25, 2016 It would not be possible to create separate apps on the fly for different people's entry points. It wouldn't surprise me a whole lot if the ability to add intents to the main launcher eventually becomes possible though...
3dcooper 0 Posted May 26, 2016 Author Posted May 26, 2016 I see what you mean. Fingers crossed for adding intents! Thanks again Dave
3dcooper 0 Posted January 10, 2017 Author Posted January 10, 2017 Ebr Happy New Year to you and thanks for all your hard work 2016! May I reopen an old thread and ask if "the ability to add intents to the main android TV launcher has become possible"? Thanks Dave
ebr 16339 Posted January 10, 2017 Posted January 10, 2017 Happy New Year! May I reopen an old thread and ask if "the ability to add intents to the main android TV launcher has become possible"? Not to my knowledge.
CBers 7557 Posted January 10, 2017 Posted January 10, 2017 May I reopen an old thread and ask if "the ability to add intents to the main android TV launcher has become possible"? And in English, that means?
bluemonkey07 590 Posted January 10, 2017 Posted January 10, 2017 What would be cool is if the emby app could have the option to be the default launcher like is possible with spmc ( though that would mean the emby app would have to add the functionality to launch other apps
3dcooper 0 Posted January 10, 2017 Author Posted January 10, 2017 Hi It is just Ebr's description of what was needed in Android to achieve the following which I asked about earlier in this thread...... It would be good to have the emby home screen / library icons direct on lean back e.g 1. Logon/ who is login in 2. Emby TV 3. Emby music 4 Emby Movies Etc Meaning someone using leanback could see a live TV icon rather than have to select emby then TV. Thanks Dave
