allen00se 18 Posted May 24, 2016 Posted May 24, 2016 @@softworkz So I had some auto-organize jobs fail and when I went to run them manually I noticed that some of my shows are listed twice. When I run the job manually, auto-organize will fail on the first listing but will work for the second listing. I have looked through my metadata manager and do not see any duplicates for these shows, where is auto-organize getting these duplicates from and how do I get rid of them?
softworkz 5127 Posted June 6, 2016 Posted June 6, 2016 Sorry, I missed your original post. You might be surprised, but in fact I had the same problem with my own installation (some shows even tripled). I examined the situation down to the database level, but manual correction would have been difficult and painful. I solved it by rebuilding the library database from scratch: Stop Emby Delete (or better rename) "library.db" in the "data" folder Restart Emby Perform a full library scan I suppose that the problem is caused by some database changes in the dev branch.
allen00se 18 Posted June 7, 2016 Author Posted June 7, 2016 Sorry, I missed your original post. You might be surprised, but in fact I had the same problem with my own installation (some shows even tripled). I examined the situation down to the database level, but manual correction would have been difficult and painful. I solved it by rebuilding the library database from scratch: Stop Emby Delete (or better rename) "library.db" in the "data" folder Restart Emby Perform a full library scan I suppose that the problem is caused by some database changes in the dev branch. So would this cause me to lose all of my watched episode status' I assume??
softworkz 5127 Posted June 7, 2016 Posted June 7, 2016 I would guess so, but I don't remember that it happened... But you can try and go back to the previous db in case.
softworkz 5127 Posted June 7, 2016 Posted June 7, 2016 Oh sorry! So he will lose his "watched" states?
ebr 16307 Posted June 7, 2016 Posted June 7, 2016 Oh sorry! So he will lose his "watched" states? No, he shouldn't.
Happy2Play 9800 Posted June 7, 2016 Posted June 7, 2016 I believe the watched state is in the userdata_v2.db.
softworkz 5127 Posted June 7, 2016 Posted June 7, 2016 Thanks for the infos! I was rather sure I didn't lose mine after deleting library.db...
