cphconsulting@me.com 1 Posted May 23, 2016 Posted May 23, 2016 Please can anyone help? I cant seem to see a pattern but picture randomly freezes during playback and sound carries on. If I fast forward from the emby App it starts again but I have to miss part of the video. If I rewind it happens again. This is Emby Windows Server Beta Version 3.0.5984.0 but also happens on the official release. Logs attached. Grateful for any support: http://192.168.1.27:8097/emby/videos/e14d50cbeca9888b6fbc92641250f04a/hls1/main/0.ts?DeviceId=4013eae22b87ac4c032228fdc801902e&MediaSourceId=e14d50cbeca9888b6fbc92641250f04a&VideoCodec=h264&AudioCodec=ac3&AudioStreamIndex=1&VideoBitrate=90980571&AudioBitrate=448000&MaxAudioChannels=6&Level=41&Profile=high&PlaySessionId=4521fc55a334459095db7582d26052f6&api_key=91aa5bf21d97414f8eccc799482e6516&CopyTimestamps=false&ForceLiveStream=false {"Protocol":"File","Id":"e14d50cbeca9888b6fbc92641250f04a","Path":"\\\\LENOVOSERVER\\TV Series\\The X-Files\\Season 10\\S10E05 - Babylon.mkv","Type":"Default","Container":"mkv","Name":"720P/H264/AC3","RunTimeTicks":25704430000,"ReadAtNativeFramerate":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"RequiresOpening":false,"RequiresClosing":false,"VideoType":"VideoFile","MediaStreams":[{"Codec":"h264","Language":"eng","IsInterlaced":false,"BitRate":4263485,"BitDepth":8,"RefFrames":5,"IsDefault":true,"IsForced":false,"Height":718,"Width":1280,"AverageFrameRate":23.97602,"RealFrameRate":23.97602,"Profile":"High","Type":"Video","AspectRatio":"16:9","Index":0,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"PixelFormat":"yuv420p","Level":41,"IsAnamorphic":false},{"Codec":"ac3","DisplayTitle":"Dolby Digital 5.1 (D)","IsInterlaced":false,"ChannelLayout":"5.1","BitRate":448000,"Channels":6,"SampleRate":48000,"IsDefault":true,"IsForced":false,"Type":"Audio","Index":1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0}],"PlayableStreamFileNames":[],"Formats":[],"Bitrate":4263485,"RequiredHttpHeaders":{}}C:\Users\Chris\AppData\Roaming\MediaBrowser-Server\ffmpeg\20160410\ffmpeg.exe -i file:"\\LENOVOSERVER\TV Series\The X-Files\Season 10\S10E05 - Babylon.mkv" -map_metadata -1 -threads 0 -map 0:0 -map 0:1 -map -0:s -codec:v:0 copy -bsf:v h264_mp4toannexb -flags -global_header -copyts -codec:a:0 copy -max_delay 5000000 -avoid_negative_ts disabled -start_at_zero -hls_time 10 -start_number 0 -hls_list_size 0 -y "C:\Users\Chris\AppData\Roaming\MediaBrowser-Server\transcoding-temp\d8b7536d6e01670e7e58a42b9a9b9cc5.m3u8"ffmpeg version N-79277-g0c90b2e Copyright © 2000-2016 the FFmpeg developersbuilt with gcc 5.3.0 (GCC)configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libfreetype --enable-libgme --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmfx --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinger --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable-libzimg --enable-lzma --enable-decklink --enable-zliblibavutil 55. 20.100 / 55. 20.100libavcodec 57. 34.100 / 57. 34.100libavformat 57. 32.100 / 57. 32.100libavdevice 57. 0.101 / 57. 0.101libavfilter 6. 41.100 / 6. 41.100libswscale 4. 1.100 / 4. 1.100libswresample 2. 0.101 / 2. 0.101libpostproc 54. 0.100 / 54. 0.100Input #0, matroska,webm, from 'file:\\LENOVOSERVER\TV Series\The X-Files\Season 10\S10E05 - Babylon.mkv':Metadata:ENCODER : mkv 2.1.1 AVSDuration: 00:42:50.44, start: 0.000000, bitrate: 4263 kb/sStream #0:0(eng): Video: h264 (High), yuv420p(tv, bt709/unknown/unknown), 1280x718, SAR 1:1 DAR 640:359, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)Stream #0:1: Audio: ac3, 48000 Hz, 5.1(side), fltp, 448 kb/s (default)Output #0, hls, to 'C:\Users\Chris\AppData\Roaming\MediaBrowser-Server\transcoding-temp\d8b7536d6e01670e7e58a42b9a9b9cc5.m3u8':Metadata:encoder : Lavf57.32.100Stream #0:0: Video: h264, yuv420p, 1280x718 [sAR 1:1 DAR 640:359], q=2-31, 23.98 fps, 23.98 tbr, 90k tbn, 23.98 tbc (default)Stream #0:1: Audio: ac3, 48000 Hz, 5.1(side), 448 kb/s (default)Stream mapping:Stream #0:0 -> #0:0 (copy)Stream #0:1 -> #0:1 (copy)Press [q] to stop, [?] for helpframe= 1849 fps=0.0 q=-1.0 size=N/A time=00:01:17.03 bitrate=N/A speed= 154xframe= 3684 fps=3627 q=-1.0 size=N/A time=00:02:33.60 bitrate=N/A speed= 151xframe= 5313 fps=3505 q=-1.0 size=N/A time=00:03:41.51 bitrate=N/A speed= 146xframe= 6957 fps=3425 q=-1.0 size=N/A time=00:04:50.08 bitrate=N/A speed= 143xframe= 8950 fps=3514 q=-1.0 size=N/A time=00:06:13.20 bitrate=N/A speed= 147xframe=10606 fps=3481 q=-1.0 size=N/A time=00:07:22.27 bitrate=N/A speed= 145xframe=12529 fps=3532 q=-1.0 size=N/A time=00:08:42.49 bitrate=N/A speed= 147xframe=14105 fps=3485 q=-1.0 size=N/A time=00:09:48.21 bitrate=N/A speed= 145xframe=15605 fps=3432 q=-1.0 size=N/A time=00:10:50.78 bitrate=N/A speed= 143xframe=17573 fps=3482 q=-1.0 size=N/A time=00:12:12.86 bitrate=N/A speed= 145xframe=18785 fps=3387 q=-1.0 size=N/A time=00:13:03.42 bitrate=N/A speed= 141xframe=20409 fps=3375 q=-1.0 size=N/A time=00:14:11.16 bitrate=N/A speed= 141xframe=22314 fps=3408 q=-1.0 size=N/A time=00:15:30.59 bitrate=N/A speed= 142xframe=23569 fps=3337 q=-1.0 size=N/A time=00:16:22.94 bitrate=N/A speed= 139xframe=25412 fps=3360 q=-1.0 size=N/A time=00:17:39.80 bitrate=N/A speed= 140xframe=26920 fps=3332 q=-1.0 size=N/A time=00:18:42.72 bitrate=N/A speed= 139xframe=27848 fps=3246 q=-1.0 size=N/A time=00:19:21.44 bitrate=N/A speed= 135xframe=28864 fps=3174 q=-1.0 size=N/A time=00:20:03.80 bitrate=N/A speed= 132xframe=30330 fps=3161 q=-1.0 size=N/A time=00:21:04.93 bitrate=N/A speed= 132xframe=31392 fps=3109 q=-1.0 size=N/A time=00:21:49.24 bitrate=N/A speed= 130xframe=33052 fps=3119 q=-1.0 size=N/A time=00:22:58.46 bitrate=N/A speed= 130xframe=33936 fps=3033 q=-1.0 size=N/A time=00:23:35.33 bitrate=N/A speed= 126xframe=34607 fps=2957 q=-1.0 size=N/A time=00:24:03.31 bitrate=N/A speed= 123xframe=35762 fps=2930 q=-1.0 size=N/A time=00:24:51.52 bitrate=N/A speed= 122xframe=36486 fps=2868 q=-1.0 size=N/A time=00:25:21.69 bitrate=N/A speed= 120xframe=37480 fps=2835 q=-1.0 size=N/A time=00:26:03.14 bitrate=N/A speed= 118xframe=38744 fps=2820 q=-1.0 size=N/A time=00:26:55.87 bitrate=N/A speed= 118xframe=40027 fps=2811 q=-1.0 size=N/A time=00:27:49.37 bitrate=N/A speed= 117xframe=41734 fps=2829 q=-1.0 size=N/A time=00:29:00.57 bitrate=N/A speed= 118xframe=42484 fps=2782 q=-1.0 size=N/A time=00:29:31.87 bitrate=N/A speed= 116xframe=43984 fps=2789 q=-1.0 size=N/A time=00:30:34.43 bitrate=N/A speed= 116xframe=44883 fps=2740 q=-1.0 size=N/A time=00:31:11.91 bitrate=N/A speed= 114xframe=45838 fps=2713 q=-1.0 size=N/A time=00:31:51.74 bitrate=N/A speed= 113xframe=46742 fps=2680 q=-1.0 size=N/A time=00:32:29.47 bitrate=N/A speed= 112xframe=47392 fps=2641 q=-1.0 size=N/A time=00:32:56.57 bitrate=N/A speed= 110xframe=48251 fps=2614 q=-1.0 size=N/A time=00:33:32.38 bitrate=N/A speed= 109xframe=49407 fps=2593 q=-1.0 size=N/A time=00:34:20.60 bitrate=N/A speed= 108xframe=50217 fps=2566 q=-1.0 size=N/A time=00:34:54.40 bitrate=N/A speed= 107xframe=50791 fps=2531 q=-1.0 size=N/A time=00:35:18.33 bitrate=N/A speed= 106xframe=51718 fps=2514 q=-1.0 size=N/A time=00:35:56.99 bitrate=N/A speed= 105xframe=52523 fps=2493 q=-1.0 size=N/A time=00:36:30.59 bitrate=N/A speed= 104xframe=53565 fps=2483 q=-1.0 size=N/A time=00:37:14.02 bitrate=N/A speed= 104xframe=54707 fps=2479 q=-1.0 size=N/A time=00:38:01.65 bitrate=N/A speed= 103xframe=55898 fps=2475 q=-1.0 size=N/A time=00:38:51.32 bitrate=N/A speed= 103xframe=57094 fps=2450 q=-1.0 size=N/A time=00:39:41.21 bitrate=N/A speed= 102xframe=57968 fps=2435 q=-1.0 size=N/A time=00:40:17.69 bitrate=N/A speed= 102xframe=58688 fps=2413 q=-1.0 size=N/A time=00:40:47.71 bitrate=N/A speed= 101xframe=59165 fps=2381 q=-1.0 size=N/A time=00:41:07.61 bitrate=N/A speed=99.3xframe=60259 fps=2375 q=-1.0 size=N/A time=00:41:53.21 bitrate=N/A speed=99.1xframe=61139 fps=2363 q=-1.0 size=N/A time=00:42:29.95 bitrate=N/A speed=98.6x
cphconsulting@me.com 1 Posted May 23, 2016 Author Posted May 23, 2016 Hi Luke, It is playing through my Xbox One using edge and I use the app on my iphone to control it
cphconsulting@me.com 1 Posted May 23, 2016 Author Posted May 23, 2016 It did it again maybe the log file attached will help? New Text Document.txt
Luke 42186 Posted May 23, 2016 Posted May 23, 2016 the logs look fine, actually they're showing great performance. it might just be too much for the device to handle. try customizing the in-app bitrate to a low value. start with 3mbps and then try working your way up.
cphconsulting@me.com 1 Posted May 23, 2016 Author Posted May 23, 2016 Ok ill try that thanks Luke, weird thing is its only started doing it since saturday doesnt normally have any issues. Thanks for the advice ill give it a go
Luke 42186 Posted May 23, 2016 Posted May 23, 2016 yea we're not limiting the bitrate for the xbox one at all and just giving it as much as the network can handle. there's a good chance we're probably just pushing it too hard. i need to research xbox one documentation to see if it has any documented video btirate limit. @@BAS might know
BAS 225 Posted May 23, 2016 Posted May 23, 2016 (edited) I've seen this as well, but it's hard to figure out whats causing it because as you saw Luke the log doesnt really seem to give anything going wrong. It also seems to only happen after a certain time frame, like longer then 40 mins in so wont show the problem on shorter tv episodes, and also I did notice it resolve itself recently and now reappear last night I will try to keep any eye on version numbers. I will try the bitrate setting as well to see if perhaps that is where the problem might be. Edited May 23, 2016 by BAS
cphconsulting@me.com 1 Posted May 23, 2016 Author Posted May 23, 2016 I have tried lowering bitrate but no effect still happens at exactly 39:03 I wonder what changed from Saturday it hasn't done this in all the time I've used emby before
BAS 225 Posted May 23, 2016 Posted May 23, 2016 I changed my bitrate inside the tv.emby.media settings area from 1080p 60Mbps to 1080p 8Mbps as everything I read for h264 content that max bitrate is 10Mbps on Xbox One. The same episode that didn't complete last night completed just now from start to finish, 43:39 in length, a mkv file. I will try to test something of higher quality and length and report back.
BAS 225 Posted May 23, 2016 Posted May 23, 2016 This is the chart I saved awhile ago that use to be on Microsoft's site, I can no longer find this page. This was relevant to content being directly played on the Xbox One, not sure how that effect your work inside Microsoft Edge / Theater support. Only thing missing from the chart is MKV container support, but the content inside the MKV still has to fall in these guidelines/specs. 2
cphconsulting@me.com 1 Posted May 23, 2016 Author Posted May 23, 2016 Why would of only started doing this at the weekend for me and I have used this for months and nothing has changed seems unusual
BAS 225 Posted May 24, 2016 Posted May 24, 2016 Media Info Video CodecH264Codec tagavc1 AVCYes ProfileHigh Level41 Resolution1280x536 Aspect ratio2.40:1 AnamorphicNo InterlacedNo Framerate23.97602 Bitrate5592 kbps Bit depth8 bit Pixel formatyuv420p Ref frames5 NAL4 Audio LanguageengCodecAAC Codec tagmp4a ProfileLC Layoutstereo Channels2 ch Bitrate277 kbps Sample rate48000 khz DefaultYes TitleEng AAC stereo (D) Audio LanguageengCodecAC3 Codec tagac-3 Layout5.1 Channels6 ch Bitrate375 kbps Sample rate48000 khz DefaultYes TitleEng Dolby Digital 5.1 (D) Subtitle LanguageengCodecSRT DefaultNo ForcedNo ExternalYes TitleEng srt (EXT) Containermp4 This file completed fine as well. I'm not going to lie, I've seen the issue the user posted and it's weird at best, I will recommend trying the bitrate I suggested, 1080p 8Mbps in users settings/playback of tv.emby.media, I will report back if it creeps up again Why would of only started doing this at the weekend for me and I have used this for months and nothing has changed seems unusual I just haven't had time to post about it but I've seen it, there is few things you can try, and with all testing do one thing first and if it still results in the same thing then move on to the next. Not sure what you put the bitrate at but you could try the one I recommended. Here is how I have my tv.emby.media user settings Below are some general tips / things to try Make sure you learn to quit Microsoft Edge when done on Xbox One that way your always starting a clean session, and if that's all your using edge for it will still have tv.emby.media as the only tab open when you last quit it forcing a refresh on first entry. You quit an app on xbox one by exiting to the Xbox one desktop, putting the focus frame around the app you want to quit and pressing menu on controller and selecting quit. Edge is kinda of confusing on Xbox One, biggest thing I see is people having a ton of tabs open in Edge killing its performance, open the tabs menu via the back/context button on controller and close any extra tabs you may have left open. Do Not Pin the Emby website to home screen, instead pin microsoft edge and follow my tip above for it being the only tab open, everytime you open a pin of a website Edge creates a new tab. Try clearing the history/cache of Microsoft Edge on Xbox One. You press the menu button on controller to get to the Edge settings area. Full shutdown of the Xbox one, while the system is powered on hold the power button down until you hear a special chime I think its like 3-5 secs. Turn system back on, you will notice it takes a lot longer to boot up. Give it a shot especially if you did all the stuff in Edge listed above with no luck. 1
MrWebsmith 598 Posted May 24, 2016 Posted May 24, 2016 (edited) Below are some general tips / things to try Make sure you learn to quit Microsoft Edge when done on Xbox One that way your always starting a clean session, and if that's all your using edge for it will still have tv.emby.media as the only tab open when you last quit it forcing a refresh on first entry. You quit an app on xbox one by exiting to the Xbox one desktop, putting the focus frame around the app you want to quit and pressing menu on controller and selecting quit. Edge is kinda of confusing on Xbox One, biggest thing I see is people having a ton of tabs open in Edge killing its performance, open the tabs menu via the back/context button on controller and close any extra tabs you may have left open. Do Not Pin the Emby website to home screen, instead pin microsoft edge and follow my tip above for it being the only tab open, everytime you open a pin of a website Edge creates a new tab. Try clearing the history/cache of Microsoft Edge on Xbox One. You press the menu button on controller to get to the Edge settings area. Full shutdown of the Xbox one, while the system is powered on hold the power button down until you hear a special chime I think its like 3-5 secs. Turn system back on, you will notice it takes a lot longer to boot up. Give it a shot especially if you did all the stuff in Edge listed above with no luck. good tips.. i def have the theater page "pinned" and ill change that to your suggestions BAS thank you Edited May 24, 2016 by MrWebsmith 1
cphconsulting@me.com 1 Posted May 31, 2016 Author Posted May 31, 2016 Hey Luke, I did everything that was suggested but still having the issue. I even re-installed the whole system. I dont have this issue if I play direct to the TV but as soon as the Xbox One is involved with emby through edge it just starts to have the freezing problems. I even reduced the quality to 1080 - 6Mbps. Im not sure what else I can do http://192.168.1.27:8097/emby/videos/c1323bb72c2aa43493321b0768ce50ad/hls1/main/547.ts?DeviceId=fcb7e96935bed4cf4086b9c246d0dfbe&MediaSourceId=c1323bb72c2aa43493321b0768ce50ad&VideoCodec=h264&AudioCodec=ac3&AudioStreamIndex=1&VideoBitrate=4552001&AudioBitrate=448000&MaxAudioChannels=6&Level=41&Profile=high&PlaySessionId=4bebc10c7eda4a7fa496b534309b3db7&api_key=ec6faf20e94f4713abd167b9bb03595c&CopyTimestamps=false&ForceLiveStream=false{"Protocol":"File","Id":"c1323bb72c2aa43493321b0768ce50ad","Path":"E:\\ServerFolders\\TV Series\\Arrow\\Season 4\\S04E23 - Schism.mkv","Type":"Default","Container":"mkv","Name":"720P/H264/AC3","RunTimeTicks":25253440000,"ReadAtNativeFramerate":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"RequiresOpening":false,"RequiresClosing":false,"VideoType":"VideoFile","MediaStreams":[{"Codec":"h264","NalLengthSize":"4","IsInterlaced":false,"IsAVC":true,"BitRate":5329279,"BitDepth":8,"RefFrames":8,"IsDefault":false,"IsForced":false,"Height":720,"Width":1280,"AverageFrameRate":23.97602,"RealFrameRate":23.97602,"Profile":"High","Type":"Video","AspectRatio":"16:9","Index":0,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"PixelFormat":"yuv420p","Level":41,"IsAnamorphic":false},{"Codec":"ac3","DisplayTitle":"Dolby Digital 5.1 (D)","IsInterlaced":false,"ChannelLayout":"5.1","BitRate":384000,"Channels":6,"SampleRate":48000,"IsDefault":true,"IsForced":false,"Type":"Audio","Index":1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0}],"PlayableStreamFileNames":[],"Formats":[],"Bitrate":5329279,"RequiredHttpHeaders":{}}C:\Users\Chris\AppData\Roaming\Emby-Server\ffmpeg\20160410\ffmpeg.exe -ss 00:27:21.000 -i file:"E:\ServerFolders\TV Series\Arrow\Season 4\S04E23 - Schism.mkv" -map_metadata -1 -threads 0 -map 0:0 -map 0:1 -map -0:s -codec:v:0 libx264 -pix_fmt yuv420p -preset superfast -crf 23 -b:v 4552001 -maxrate 4552001 -bufsize 9104002 -vsync vfr -profile:v high -level 41 -force_key_frames "expr:gte(t,n_forced*3)" -flags -global_header -copyts -codec:a:0 copy -max_delay 5000000 -avoid_negative_ts disabled -start_at_zero -hls_time 3 -start_number 547 -hls_list_size 0 -y "C:\Users\Chris\AppData\Roaming\Emby-Server\transcoding-temp\b2a7d20189d56d8e3efb34ccfc832c8a.m3u8"ffmpeg version N-79277-g0c90b2e Copyright © 2000-2016 the FFmpeg developersbuilt with gcc 5.3.0 (GCC)configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libfreetype --enable-libgme --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmfx --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinger --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable-libzimg --enable-lzma --enable-decklink --enable-zliblibavutil 55. 20.100 / 55. 20.100libavcodec 57. 34.100 / 57. 34.100libavformat 57. 32.100 / 57. 32.100libavdevice 57. 0.101 / 57. 0.101libavfilter 6. 41.100 / 6. 41.100libswscale 4. 1.100 / 4. 1.100libswresample 2. 0.101 / 2. 0.101libpostproc 54. 0.100 / 54. 0.100Input #0, matroska,webm, from 'file:E:\ServerFolders\TV Series\Arrow\Season 4\S04E23 - Schism.mkv':Metadata:encoder : libebml v1.3.1 + libmatroska v1.4.2creation_time : 2016-05-26 01:14:36Duration: 00:42:05.34, start: 0.000000, bitrate: 5329 kb/sStream #0:0: Video: h264 (High), yuv420p, 1280x720 [sAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbcMetadata:BPS : 4943671BPS-eng : 4943671DURATION : 00:42:05.231000000DURATION-eng : 00:42:05.231000000NUMBER_OF_FRAMES: 60545NUMBER_OF_FRAMES-eng: 60545NUMBER_OF_BYTES : 1560489029NUMBER_OF_BYTES-eng: 1560489029_STATISTICS_WRITING_APP: mkvmerge v8.4.0 ('A better way to fly') 64bit_STATISTICS_WRITING_APP-eng: mkvmerge v8.4.0 ('A better way to fly') 64bit_STATISTICS_WRITING_DATE_UTC: 2016-05-26 01:14:36_STATISTICS_WRITING_DATE_UTC-eng: 2016-05-26 01:14:36_STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES_STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTESStream #0:1: Audio: ac3, 48000 Hz, 5.1(side), fltp, 384 kb/s (default)Metadata:BPS : 384000BPS-eng : 384000DURATION : 00:42:05.344000000DURATION-eng : 00:42:05.344000000NUMBER_OF_FRAMES: 78917NUMBER_OF_FRAMES-eng: 78917NUMBER_OF_BYTES : 121216512NUMBER_OF_BYTES-eng: 121216512_STATISTICS_WRITING_APP: mkvmerge v8.4.0 ('A better way to fly') 64bit_STATISTICS_WRITING_APP-eng: mkvmerge v8.4.0 ('A better way to fly') 64bit_STATISTICS_WRITING_DATE_UTC: 2016-05-26 01:14:36_STATISTICS_WRITING_DATE_UTC-eng: 2016-05-26 01:14:36_STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES_STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES[libx264 @ 0000000001c3b2c0] using SAR=1/1[libx264 @ 0000000001c3b2c0] using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX FMA3 AVX2 LZCNT BMI2[libx264 @ 0000000001c3b2c0] profile High, level 4.1Output #0, hls, to 'C:\Users\Chris\AppData\Roaming\Emby-Server\transcoding-temp\b2a7d20189d56d8e3efb34ccfc832c8a.m3u8':Metadata:encoder : Lavf57.32.100Stream #0:0: Video: h264 (libx264), yuv420p, 1280x720 [sAR 1:1 DAR 16:9], q=-1--1, 4552 kb/s, 23.98 fps, 90k tbn, 23.98 tbcMetadata:encoder : Lavc57.34.100 libx264Side data:cpb: bitrate max/min/avg: 4552000/0/4552000 buffer size: 9104000 vbv_delay: -1Stream #0:1: Audio: ac3, 48000 Hz, 5.1(side), 384 kb/s (default)Stream mapping:Stream #0:0 -> #0:0 (h264 (native) -> h264 (libx264))Stream #0:1 -> #0:1 (copy)Press [q] to stop, [?] for helpframe= 64 fps=0.0 q=24.0 size=N/A time=00:27:24.16 bitrate=N/A speed=3.29e+003xframe= 134 fps=132 q=25.0 size=N/A time=00:27:26.91 bitrate=N/A speed=1.62e+003xframe= 196 fps=129 q=25.0 size=N/A time=00:27:29.56 bitrate=N/A speed=1.09e+003xframe= 298 fps=148 q=24.0 size=N/A time=00:27:33.76 bitrate=N/A speed= 820xframe= 358 fps=142 q=24.0 size=N/A time=00:27:36.32 bitrate=N/A speed= 658xframe= 429 fps=142 q=24.0 size=N/A time=00:27:39.13 bitrate=N/A speed= 550xframe= 533 fps=152 q=24.0 size=N/A time=00:27:43.45 bitrate=N/A speed= 473xframe= 584 fps=145 q=26.0 size=N/A time=00:27:45.60 bitrate=N/A speed= 415xframe= 656 fps=145 q=21.0 size=N/A time=00:27:48.92 bitrate=N/A speed= 369xframe= 768 fps=153 q=24.0 size=N/A time=00:27:53.34 bitrate=N/A speed= 334xframe= 810 fps=146 q=24.0 size=N/A time=00:27:55.13 bitrate=N/A speed= 303xframe= 882 fps=146 q=25.0 size=N/A time=00:27:58.24 bitrate=N/A speed= 278xframe= 950 fps=145 q=23.0 size=N/A time=00:28:01.08 bitrate=N/A speed= 257xframe= 1000 fps=142 q=24.0 size=N/A time=00:28:03.10 bitrate=N/A speed= 239xframe= 1079 fps=143 q=23.0 size=N/A time=00:28:06.49 bitrate=N/A speed= 223xframe= 1134 fps=141 q=25.0 size=N/A time=00:28:08.83 bitrate=N/A speed= 209xframe= 1189 fps=139 q=25.0 size=N/A time=00:28:11.00 bitrate=N/A speed= 197xframe= 1268 fps=140 q=27.0 size=N/A time=00:28:14.30 bitrate=N/A speed= 187xframe= 1302 fps=136 q=25.0 size=N/A time=00:28:15.64 bitrate=N/A speed= 177xframe= 1364 fps=135 q=27.0 size=N/A time=00:28:18.24 bitrate=N/A speed= 168xframe= 1444 fps=136 q=25.0 size=N/A time=00:28:21.69 bitrate=N/A speed= 160xframe= 1486 fps=133 q=27.0 size=N/A time=00:28:23.29 bitrate=N/A speed= 153xframe= 1565 fps=134 q=23.0 size=N/A time=00:28:26.65 bitrate=N/A speed= 147xframe= 1626 fps=134 q=25.0 size=N/A time=00:28:29.31 bitrate=N/A speed= 140xframe= 1688 fps=133 q=25.0 size=N/A time=00:28:31.84 bitrate=N/A speed= 135xframe= 1793 fps=136 q=24.0 size=N/A time=00:28:36.32 bitrate=N/A speed= 130xframe= 1844 fps=135 q=25.0 size=N/A time=00:28:38.40 bitrate=N/A speed= 126xframe= 1910 fps=135 q=26.0 size=N/A time=00:28:40.99 bitrate=N/A speed= 121xframe= 1998 fps=136 q=27.0 size=N/A time=00:28:44.70 bitrate=N/A speed= 117xframe= 2039 fps=134 q=25.0 size=N/A time=00:28:46.40 bitrate=N/A speed= 114xframe= 2100 fps=134 q=25.0 size=N/A time=00:28:48.83 bitrate=N/A speed= 110xframe= 2164 fps=134 q=24.0 size=N/A time=00:28:51.52 bitrate=N/A speed= 107xframe= 2212 fps=132 q=30.0 size=N/A time=00:28:53.53 bitrate=N/A speed= 104xframe= 2282 fps=133 q=23.0 size=N/A time=00:28:56.60 bitrate=N/A speed= 101xframe= 2341 fps=132 q=24.0 size=N/A time=00:28:58.97 bitrate=N/A speed=98.2xframe= 2414 fps=133 q=25.0 size=N/A time=00:29:02.14 bitrate=N/A speed=95.7xframe= 2509 fps=134 q=23.0 size=N/A time=00:29:06.24 bitrate=N/A speed=93.4xframe= 2552 fps=133 q=23.0 size=N/A time=00:29:07.74 bitrate=N/A speed= 91xframe= 2613 fps=133 q=24.0 size=N/A time=00:29:10.33 bitrate=N/A speed=88.8xframe= 2700 fps=134 q=25.0 size=N/A time=00:29:14.04 bitrate=N/A speed=86.8xframe= 2786 fps=135 q=29.0 size=N/A time=00:29:17.53 bitrate=N/A speed=84.9xframe= 2868 fps=135 q=29.0 size=N/A time=00:29:21.02 bitrate=N/A speed= 83xframe= 2957 fps=136 q=24.0 size=N/A time=00:29:24.70 bitrate=N/A speed=81.3xframe= 3044 fps=137 q=27.0 size=N/A time=00:29:28.38 bitrate=N/A speed=79.6xframe= 3135 fps=138 q=26.0 size=N/A time=00:29:32.25 bitrate=N/A speed=78.1xframe= 3170 fps=137 q=25.0 size=N/A time=00:29:33.47 bitrate=N/A speed=76.4xframe= 3226 fps=136 q=28.0 size=N/A time=00:29:36.06 bitrate=N/A speed=74.9xframe= 3308 fps=136 q=29.0 size=N/A time=00:29:39.39 bitrate=N/A speed=73.3xframe= 3345 fps=135 q=25.0 size=N/A time=00:29:40.89 bitrate=N/A speed=71.9xframe= 3417 fps=135 q=25.0 size=N/A time=00:29:43.93 bitrate=N/A speed=70.6xframe= 3484 fps=135 q=25.0 size=N/A time=00:29:46.75 bitrate=N/A speed=69.3xframe= 3537 fps=135 q=23.0 size=N/A time=00:29:48.89 bitrate=N/A speed=68.1xframe= 3620 fps=135 q=25.0 size=N/A time=00:29:52.54 bitrate=N/A speed=66.9xframe= 3704 fps=136 q=27.0 size=N/A time=00:29:55.77 bitrate=N/A speed=65.8xframe= 3791 fps=136 q=24.0 size=N/A time=00:29:59.58 bitrate=N/A speed=64.8xframe= 3876 fps=137 q=28.0 size=N/A time=00:30:03.04 bitrate=N/A speed=63.7xframe= 3903 fps=136 q=28.0 size=N/A time=00:30:04.06 bitrate=N/A speed=62.7xframe= 3966 fps=135 q=27.0 size=N/A time=00:30:06.75 bitrate=N/A speed=61.7xframe= 4036 fps=135 q=25.0 size=N/A time=00:30:09.56 bitrate=N/A speed=60.8xframe= 4078 fps=135 q=23.0 size=N/A time=00:30:11.36 bitrate=N/A speed=59.8xframe= 4151 fps=135 q=28.0 size=N/A time=00:30:14.52 bitrate=N/A speed=58.9xframe= 4208 fps=134 q=27.0 size=N/A time=00:30:16.92 bitrate=N/A speed= 58xframe= 4261 fps=134 q=26.0 size=N/A time=00:30:19.00 bitrate=N/A speed=57.2xframe= 4344 fps=134 q=24.0 size=N/A time=00:30:22.56 bitrate=N/A speed=56.4xframe= 4382 fps=134 q=25.0 size=N/A time=00:30:24.22 bitrate=N/A speed=55.6xframe= 4439 fps=133 q=28.0 size=N/A time=00:30:26.59 bitrate=N/A speed=54.8xframe= 4520 fps=133 q=24.0 size=N/A time=00:30:29.98 bitrate=N/A speed= 54xframe= 4566 fps=133 q=25.0 size=N/A time=00:30:31.74 bitrate=N/A speed=53.3xframe= 4653 fps=133 q=23.0 size=N/A time=00:30:35.42 bitrate=N/A speed=52.6xframe= 4722 fps=134 q=24.0 size=N/A time=00:30:38.40 bitrate=N/A speed= 52xframe= 4782 fps=133 q=24.0 size=N/A time=00:30:40.70 bitrate=N/A speed=51.3xframe= 4874 fps=134 q=25.0 size=N/A time=00:30:44.60 bitrate=N/A speed=50.7xframe= 4922 fps=134 q=22.0 size=N/A time=00:30:46.56 bitrate=N/A speed=50.1xframe= 4992 fps=134 q=25.0 size=N/A time=00:30:49.53 bitrate=N/A speed=49.5xframe= 5093 fps=135 q=22.0 size=N/A time=00:30:53.72 bitrate=N/A speed= 49xframe= 5161 fps=135 q=22.0 size=N/A time=00:30:56.64 bitrate=N/A speed=48.4xframe= 5260 fps=135 q=20.0 size=N/A time=00:31:00.76 bitrate=N/A speed=47.9xframe= 5339 fps=136 q=23.0 size=N/A time=00:31:03.96 bitrate=N/A speed=47.3xframe= 5384 fps=135 q=26.0 size=N/A time=00:31:05.98 bitrate=N/A speed=46.8xframe= 5456 fps=135 q=26.0 size=N/A time=00:31:08.80 bitrate=N/A speed=46.3xframe= 5519 fps=135 q=22.0 size=N/A time=00:31:11.45 bitrate=N/A speed=45.8xframe= 5573 fps=135 q=24.0 size=N/A time=00:31:13.82 bitrate=N/A speed=45.3xframe= 5686 fps=136 q=26.0 size=N/A time=00:31:18.62 bitrate=N/A speed=44.9xframe= 5729 fps=135 q=23.0 size=N/A time=00:31:20.25 bitrate=N/A speed=44.3xframe= 5814 fps=136 q=24.0 size=N/A time=00:31:23.77 bitrate=N/A speed=43.9xframe= 5899 fps=136 q=24.0 size=N/A time=00:31:27.48 bitrate=N/A speed=43.5xframe= 5946 fps=135 q=23.0 size=N/A time=00:31:29.40 bitrate=N/A speed= 43xframe= 6035 fps=136 q=23.0 size=N/A time=00:31:33.21 bitrate=N/A speed=42.6xframe= 6106 fps=136 q=25.0 size=N/A time=00:31:36.12 bitrate=N/A speed=42.2xframe= 6170 fps=136 q=24.0 size=N/A time=00:31:38.68 bitrate=N/A speed=41.8xframe= 6276 fps=137 q=22.0 size=N/A time=00:31:43.16 bitrate=N/A speed=41.5xframe= 6334 fps=136 q=24.0 size=N/A time=00:31:45.56 bitrate=N/A speed=41.1xframe= 6415 fps=137 q=25.0 size=N/A time=00:31:48.89 bitrate=N/A speed=40.7xframe= 6519 fps=137 q=25.0 size=N/A time=00:31:53.31 bitrate=N/A speed=40.3xframe= 6570 fps=137 q=25.0 size=N/A time=00:31:55.42 bitrate=N/A speed=39.9xframe= 6659 fps=137 q=23.0 size=N/A time=00:31:59.16 bitrate=N/A speed=39.6xframe= 6737 fps=138 q=26.0 size=N/A time=00:32:02.46 bitrate=N/A speed=39.2xframe= 6803 fps=137 q=24.0 size=N/A time=00:32:05.18 bitrate=N/A speed=38.9xframe= 6905 fps=138 q=23.0 size=N/A time=00:32:09.34 bitrate=N/A speed=38.6xframe= 6963 fps=138 q=25.0 size=N/A time=00:32:11.96 bitrate=N/A speed=38.3xframe= 7035 fps=138 q=23.0 size=N/A time=00:32:14.88 bitrate=N/A speed=37.9xframe= 7142 fps=138 q=22.0 size=N/A time=00:32:19.10 bitrate=N/A speed=37.6xframe= 7199 fps=138 q=20.0 size=N/A time=00:32:21.66 bitrate=N/A speed=37.3xframe= 7298 fps=139 q=23.0 size=N/A time=00:32:25.79 bitrate=N/A speed= 37xframe= 7379 fps=139 q=23.0 size=N/A time=00:32:29.18 bitrate=N/A speed=36.7xframe= 7446 fps=139 q=22.0 size=N/A time=00:32:31.87 bitrate=N/A speed=36.4xframe= 7563 fps=140 q=22.0 size=N/A time=00:32:36.80 bitrate=N/A speed=36.2xframe= 7612 fps=139 q=23.0 size=N/A time=00:32:38.84 bitrate=N/A speed=35.9xframe= 7698 fps=140 q=23.0 size=N/A time=00:32:42.36 bitrate=N/A speed=35.6xframe= 7805 fps=140 q=25.0 size=N/A time=00:32:46.91 bitrate=N/A speed=35.3xframe= 7847 fps=140 q=25.0 size=N/A time=00:32:48.73 bitrate=N/A speed=35.1xframe= 7937 fps=140 q=25.0 size=N/A time=00:32:52.60 bitrate=N/A speed=34.8xframe= 8016 fps=140 q=24.0 size=N/A time=00:32:55.71 bitrate=N/A speed=34.6xframe= 8080 fps=140 q=25.0 size=N/A time=00:32:58.33 bitrate=N/A speed=34.3xframe= 8191 fps=141 q=25.0 size=N/A time=00:33:03.07 bitrate=N/A speed=34.1xframe= 8306 fps=142 q=23.0 size=N/A time=00:33:07.71 bitrate=N/A speed=33.9xframe= 8421 fps=142 q=25.0 size=N/A time=00:33:12.76 bitrate=N/A speed=33.7xframe= 8530 fps=143 q=23.0 size=N/A time=00:33:17.34 bitrate=N/A speed=33.5xframe= 8641 fps=144 q=21.0 size=N/A time=00:33:21.79 bitrate=N/A speed=33.3xframe= 8775 fps=145 q=23.0 size=N/A time=00:33:27.36 bitrate=N/A speed=33.1xframe= 8880 fps=145 q=25.0 size=N/A time=00:33:31.64 bitrate=N/A speed=32.9xframe= 8936 fps=145 q=24.0 size=N/A time=00:33:34.14 bitrate=N/A speed=32.6xframe= 9030 fps=145 q=23.0 size=N/A time=00:33:37.92 bitrate=N/A speed=32.4xframe= 9116 fps=145 q=24.0 size=N/A time=00:33:41.60 bitrate=N/A speed=32.2xframe= 9190 fps=145 q=22.0 size=N/A time=00:33:44.70 bitrate=N/A speed= 32xframe= 9282 fps=146 q=23.0 size=N/A time=00:33:48.64 bitrate=N/A speed=31.8xframe= 9327 fps=145 q=23.0 size=N/A time=00:33:50.40 bitrate=N/A speed=31.6xframe= 9393 fps=145 q=23.0 size=N/A time=00:33:53.02 bitrate=N/A speed=31.4xframe= 9487 fps=145 q=25.0 size=N/A time=00:33:57.08 bitrate=N/A speed=31.2xframe= 9546 fps=145 q=24.0 size=N/A time=00:33:59.45 bitrate=N/A speed= 31xframe= 9646 fps=146 q=22.0 size=N/A time=00:34:03.74 bitrate=N/A speed=30.8xframe= 9734 fps=146 q=22.0 size=N/A time=00:34:07.42 bitrate=N/A speed=30.7xframe= 9791 fps=146 q=21.0 size=N/A time=00:34:09.92 bitrate=N/A speed=30.5xframe= 9898 fps=146 q=23.0 size=N/A time=00:34:14.17 bitrate=N/A speed=30.3xframe= 9955 fps=146 q=22.0 size=N/A time=00:34:16.57 bitrate=N/A speed=30.1xframe=10029 fps=146 q=20.0 size=N/A time=00:34:19.74 bitrate=N/A speed= 30xframe=10143 fps=146 q=24.0 size=N/A time=00:34:24.44 bitrate=N/A speed=29.8xframe=10242 fps=147 q=26.0 size=N/A time=00:34:28.60 bitrate=N/A speed=29.6xframe=10331 fps=147 q=24.0 size=N/A time=00:34:32.22 bitrate=N/A speed=29.5xframe=10444 fps=147 q=24.0 size=N/A time=00:34:36.96 bitrate=N/A speed=29.3xframe=10525 fps=148 q=24.0 size=N/A time=00:34:40.44 bitrate=N/A speed=29.2xframe=10632 fps=148 q=23.0 size=N/A time=00:34:44.83 bitrate=N/A speed= 29xframe=10690 fps=148 q=27.0 size=N/A time=00:34:47.45 bitrate=N/A speed=28.9xframe=10748 fps=148 q=24.0 size=N/A time=00:34:49.76 bitrate=N/A speed=28.7xframe=10853 fps=148 q=24.0 size=N/A time=00:34:54.01 bitrate=N/A speed=28.6xframe=10902 fps=148 q=25.0 size=N/A time=00:34:56.16 bitrate=N/A speed=28.4xframe=10979 fps=148 q=24.0 size=N/A time=00:34:59.45 bitrate=N/A speed=28.2xframe=11074 fps=148 q=25.0 size=N/A time=00:35:03.16 bitrate=N/A speed=28.1xframe=11125 fps=148 q=26.0 size=N/A time=00:35:05.24 bitrate=N/A speed=27.9xframe=11209 fps=148 q=25.0 size=N/A time=00:35:08.96 bitrate=N/A speed=27.8xframe=11272 fps=148 q=24.0 size=N/A time=00:35:11.68 bitrate=N/A speed=27.6xframe=11319 fps=147 q=24.0 size=N/A time=00:35:13.50 bitrate=N/A speed=27.5xframe=11414 fps=147 q=26.0 size=N/A time=00:35:17.44 bitrate=N/A speed=27.4xframe=11466 fps=147 q=27.0 size=N/A time=00:35:19.55 bitrate=N/A speed=27.2xframe=11518 fps=147 q=23.0 size=N/A time=00:35:21.76 bitrate=N/A speed=27.1xframe=11596 fps=147 q=27.0 size=N/A time=00:35:25.02 bitrate=N/A speed=26.9xframe=11639 fps=146 q=26.0 size=N/A time=00:35:26.68 bitrate=N/A speed=26.7xframe=11723 fps=146 q=23.0 size=N/A time=00:35:30.49 bitrate=N/A speed=26.6xframe=11797 fps=146 q=25.0 size=N/A time=00:35:33.40 bitrate=N/A speed=26.5xframe=11861 fps=146 q=26.0 size=N/A time=00:35:36.06 bitrate=N/A speed=26.4xframe=11951 fps=147 q=26.0 size=N/A time=00:35:39.90 bitrate=N/A speed=26.2xframe=12009 fps=146 q=23.0 size=N/A time=00:35:42.20 bitrate=N/A speed=26.1xframe=12085 fps=146 q=24.0 size=N/A time=00:35:45.47 bitrate=N/A speed= 26xframe=12186 fps=147 q=23.0 size=N/A time=00:35:49.63 bitrate=N/A speed=25.9xframe=12243 fps=146 q=24.0 size=N/A time=00:35:52.03 bitrate=N/A speed=25.7xframe=12348 fps=147 q=25.0 size=N/A time=00:35:56.41 bitrate=N/A speed=25.6xframe=12424 fps=147 q=26.0 size=N/A time=00:35:59.55 bitrate=N/A speed=25.5xframe=12475 fps=147 q=27.0 size=N/A time=00:36:01.69 bitrate=N/A speed=25.4xframe=12551 fps=147 q=26.0 size=N/A time=00:36:04.92 bitrate=N/A speed=25.3xframe=12642 fps=147 q=25.0 size=N/A time=00:36:08.54 bitrate=N/A speed=25.2xframe=12728 fps=147 q=29.0 size=N/A time=00:36:12.32 bitrate=N/A speed=25.1xframe=12807 fps=147 q=29.0 size=N/A time=00:36:15.42 bitrate=N/A speed= 25xframe=12841 fps=147 q=26.0 size=N/A time=00:36:17.02 bitrate=N/A speed=24.8xframe=12906 fps=146 q=27.0 size=N/A time=00:36:19.58 bitrate=N/A speed=24.7xframe=12966 fps=146 q=29.0 size=N/A time=00:36:22.24 bitrate=N/A speed=24.6xframe=13005 fps=146 q=26.0 size=N/A time=00:36:23.74 bitrate=N/A speed=24.5xframe=13085 fps=146 q=27.0 size=N/A time=00:36:27.20 bitrate=N/A speed=24.4xframe=13132 fps=146 q=24.0 size=N/A time=00:36:28.99 bitrate=N/A speed=24.3xframe=13188 fps=146 q=24.0 size=N/A time=00:36:31.36 bitrate=N/A speed=24.2xframe=13277 fps=146 q=27.0 size=N/A time=00:36:35.10 bitrate=N/A speed=24.1xframe=13318 fps=145 q=28.0 size=N/A time=00:36:36.92 bitrate=N/A speed= 24xframe=13389 fps=145 q=25.0 size=N/A time=00:36:39.74 bitrate=N/A speed=23.9xframe=13467 fps=145 q=27.0 size=N/A time=00:36:43.04 bitrate=N/A speed=23.8xframe=13515 fps=145 q=26.0 size=N/A time=00:36:44.96 bitrate=N/A speed=23.7xframe=13606 fps=145 q=25.0 size=N/A time=00:36:48.83 bitrate=N/A speed=23.6xframe=13723 fps=146 q=25.0 size=N/A time=00:36:53.72 bitrate=N/A speed=23.5xframe=13835 fps=146 q=26.0 size=N/A time=00:36:58.36 bitrate=N/A speed=23.4xframe=13964 fps=147 q=22.0 size=N/A time=00:37:03.90 bitrate=N/A speed=23.4xEnter command: <target>|all <time>|-1 <command>[ <argument>]Parse error, at least 3 arguments were expected, only -1 given in string ''frame=13993 fps= 42 q=24.0 size=N/A time=00:37:05.12 bitrate=N/A speed=6.63xframe=14062 fps= 42 q=24.0 size=N/A time=00:37:07.87 bitrate=N/A speed=6.63xframe=14172 fps= 42 q=25.0 size=N/A time=00:37:12.44 bitrate=N/A speed=6.64xframe=14296 fps= 42 q=22.0 size=N/A time=00:37:17.63 bitrate=N/A speed=6.64xframe=14395 fps= 43 q=20.0 size=N/A time=00:37:21.66 bitrate=N/A speed=6.64xframe=14538 fps= 43 q=23.0 size=N/A time=00:37:27.74 bitrate=N/A speed=6.65xframe=14629 fps= 43 q=24.0 size=N/A time=00:37:31.61 bitrate=N/A speed=6.65xframe=14686 fps= 43 q=25.0 size=N/A time=00:37:33.85 bitrate=N/A speed=6.65xframe=14778 fps= 44 q=24.0 size=N/A time=00:37:37.69 bitrate=N/A speed=6.65xframe=14851 fps= 44 q=25.0 size=N/A time=00:37:40.83 bitrate=N/A speed=6.65xframe=14928 fps= 44 q=23.0 size=N/A time=00:37:44.12 bitrate=N/A speed=6.65xframe=15048 fps= 44 q=24.0 size=N/A time=00:37:48.96 bitrate=N/A speed=6.65xframe=15111 fps= 44 q=23.0 size=N/A time=00:37:51.77 bitrate=N/A speed=6.65xframe=15219 fps= 45 q=21.0 size=N/A time=00:37:56.19 bitrate=N/A speed=6.66xframe=15350 fps= 45 q=23.0 size=N/A time=00:38:01.72 bitrate=N/A speed=6.66xframe=15421 fps= 45 q=23.0 size=N/A time=00:38:04.64 bitrate=N/A speed=6.66xframe=15543 fps= 45 q=21.0 size=N/A time=00:38:09.66 bitrate=N/A speed=6.67xframe=15645 fps= 45 q=24.0 size=N/A time=00:38:14.01 bitrate=N/A speed=6.67xframe=15721 fps= 46 q=23.0 size=N/A time=00:38:17.08 bitrate=N/A speed=6.67xframe=15839 fps= 46 q=24.0 size=N/A time=00:38:22.11 bitrate=N/A speed=6.67xframe=15907 fps= 46 q=24.0 size=N/A time=00:38:24.83 bitrate=N/A speed=6.67xframe=15983 fps= 46 q=25.0 size=N/A time=00:38:28.03 bitrate=N/A speed=6.67xframe=16101 fps= 46 q=25.0 size=N/A time=00:38:32.86 bitrate=N/A speed=6.67xframe=16145 fps= 47 q=24.0 size=N/A time=00:38:34.65 bitrate=N/A speed=6.67xframe=16239 fps= 47 q=23.0 size=N/A time=00:38:38.72 bitrate=N/A speed=6.67xframe=16326 fps= 47 q=23.0 size=N/A time=00:38:42.20 bitrate=N/A speed=6.67xframe=16370 fps= 47 q=23.0 size=N/A time=00:38:44.22 bitrate=N/A speed=6.67xframe=16449 fps= 47 q=23.0 size=N/A time=00:38:47.42 bitrate=N/A speed=6.67xframe=16509 fps= 47 q=22.0 size=N/A time=00:38:49.92 bitrate=N/A speed=6.67xframe=16569 fps= 47 q=25.0 size=N/A time=00:38:52.35 bitrate=N/A speed=6.66xframe=16667 fps= 48 q=24.0 size=N/A time=00:38:56.57 bitrate=N/A speed=6.67xEnter command: <target>|all <time>|-1 <command>[ <argument>]Parse error, at least 3 arguments were expected, only -1 given in string ''frame=16675 fps= 47 q=24.0 size=N/A time=00:38:56.83 bitrate=N/A speed=6.57xframe=16736 fps= 47 q=25.0 size=N/A time=00:38:59.26 bitrate=N/A speed=6.57xframe=16784 fps= 47 q=24.0 size=N/A time=00:39:01.50 bitrate=N/A speed=6.57xframe=16872 fps= 47 q=24.0 size=N/A time=00:39:05.21 bitrate=N/A speed=6.57xframe=16975 fps= 47 q=22.0 size=N/A time=00:39:09.28 bitrate=N/A speed=6.57xframe=17029 fps= 48 q=24.0 size=N/A time=00:39:11.64 bitrate=N/A speed=6.57xframe=17119 fps= 48 q=20.0 size=N/A time=00:39:15.39 bitrate=N/A speed=6.57xframe=17210 fps= 48 q=24.0 size=N/A time=00:39:19.23 bitrate=N/A speed=6.57xframe=17314 fps= 48 q=22.0 size=N/A time=00:39:23.52 bitrate=N/A speed=6.57xframe=17430 fps= 48 q=24.0 size=N/A time=00:39:28.41 bitrate=N/A speed=6.58xframe=17490 fps= 49 q=24.0 size=N/A time=00:39:30.91 bitrate=N/A speed=6.58xframe=17567 fps= 49 q=25.0 size=N/A time=00:39:34.20 bitrate=N/A speed=6.58xframe=17682 fps= 49 q=24.0 size=N/A time=00:39:38.78 bitrate=N/A speed=6.58xframe=17728 fps= 49 q=24.0 size=N/A time=00:39:40.83 bitrate=N/A speed=6.58xframe=17813 fps= 49 q=23.0 size=N/A time=00:39:44.35 bitrate=N/A speed=6.58xframe=17905 fps= 49 q=23.0 size=N/A time=00:39:48.19 bitrate=N/A speed=6.58xframe=17963 fps= 49 q=25.0 size=N/A time=00:39:50.43 bitrate=N/A speed=6.58xframe=18052 fps= 50 q=25.0 size=N/A time=00:39:54.17 bitrate=N/A speed=6.58xframe=18143 fps= 50 q=26.0 size=N/A time=00:39:58.04 bitrate=N/A speed=6.58xframe=18233 fps= 50 q=24.0 size=N/A time=00:40:01.79 bitrate=N/A speed=6.58xframe=18340 fps= 50 q=22.0 size=N/A time=00:40:06.40 bitrate=N/A speed=6.58xEnter command: <target>|all <time>|-1 <command>[ <argument>]Parse error, at least 3 arguments were expected, only -1 given in string ''frame=18357 fps= 50 q=25.0 size=N/A time=00:40:07.16 bitrate=N/A speed= 6.5xframe=18425 fps= 50 q=24.0 size=N/A time=00:40:09.85 bitrate=N/A speed=6.49xframe=18527 fps= 50 q=24.0 size=N/A time=00:40:14.11 bitrate=N/A speed= 6.5xframe=18649 fps= 50 q=24.0 size=N/A time=00:40:19.36 bitrate=N/A speed= 6.5xframe=18742 fps= 50 q=24.0 size=N/A time=00:40:23.07 bitrate=N/A speed= 6.5xframe=18793 fps= 50 q=25.0 size=N/A time=00:40:25.12 bitrate=N/A speed= 6.5xframe=18891 fps= 51 q=22.0 size=N/A time=00:40:29.47 bitrate=N/A speed= 6.5xframe=18965 fps= 51 q=24.0 size=N/A time=00:40:32.32 bitrate=N/A speed= 6.5xframe=19030 fps= 51 q=23.0 size=N/A time=00:40:35.10 bitrate=N/A speed= 6.5xframe=19133 fps= 51 q=22.0 size=N/A time=00:40:39.36 bitrate=N/A speed= 6.5xframe=19188 fps= 51 q=21.0 size=N/A time=00:40:41.66 bitrate=N/A speed= 6.5xframe=19265 fps= 51 q=23.0 size=N/A time=00:40:44.86 bitrate=N/A speed= 6.5xframe=19356 fps= 51 q=25.0 size=N/A time=00:40:48.73 bitrate=N/A speed= 6.5xframe=19405 fps= 51 q=25.0 size=N/A time=00:40:50.81 bitrate=N/A speed= 6.5xframe=19490 fps= 52 q=21.0 size=N/A time=00:40:54.36 bitrate=N/A speed= 6.5xframe=19555 fps= 52 q=24.0 size=N/A time=00:40:57.12 bitrate=N/A speed= 6.5xframe=19619 fps= 52 q=24.0 size=N/A time=00:40:59.61 bitrate=N/A speed=6.49xframe=19717 fps= 52 q=21.0 size=N/A time=00:41:03.77 bitrate=N/A speed= 6.5xframe=19772 fps= 52 q=23.0 size=N/A time=00:41:06.08 bitrate=N/A speed=6.49xframe=19851 fps= 52 q=23.0 size=N/A time=00:41:09.28 bitrate=N/A speed=6.49xframe=19939 fps= 52 q=23.0 size=N/A time=00:41:13.02 bitrate=N/A speed=6.49xframe=19989 fps= 52 q=25.0 size=N/A time=00:41:14.94 bitrate=N/A speed=6.49xframe=20079 fps= 53 q=26.0 size=N/A time=00:41:18.88 bitrate=N/A speed=6.49xframe=20139 fps= 53 q=24.0 size=N/A time=00:41:21.21 bitrate=N/A speed=6.49xframe=20205 fps= 53 q=22.0 size=N/A time=00:41:24.16 bitrate=N/A speed=6.49xframe=20299 fps= 53 q=24.0 size=N/A time=00:41:28.09 bitrate=N/A speed=6.49xframe=20348 fps= 53 q=25.0 size=N/A time=00:41:29.98 bitrate=N/A speed=6.49xframe=20416 fps= 53 q=26.0 size=N/A time=00:41:32.89 bitrate=N/A speed=6.49xframe=20494 fps= 53 q=25.0 size=N/A time=00:41:36.16 bitrate=N/A speed=6.49xframe=20547 fps= 53 q=25.0 size=N/A time=00:41:38.30 bitrate=N/A speed=6.48xframe=20633 fps= 53 q=23.0 size=N/A time=00:41:41.85 bitrate=N/A speed=6.48xframe=20694 fps= 54 q=25.0 size=N/A time=00:41:44.44 bitrate=N/A speed=6.48xframe=20754 fps= 54 q=24.0 size=N/A time=00:41:47.00 bitrate=N/A speed=6.48xframe=20841 fps= 54 q=25.0 size=N/A time=00:41:50.81 bitrate=N/A speed=6.48xframe=20929 fps= 54 q=26.0 size=N/A time=00:41:54.17 bitrate=N/A speed=6.48xframe=21065 fps= 54 q=23.0 size=N/A time=00:41:59.96 bitrate=N/A speed=6.49xframe=21165 fps= 54 q=24.0 size=N/A time=00:42:04.16 bitrate=N/A speed=6.49xframe=21202 fps= 54 q=-1.0 Lsize=N/A time=00:42:05.34 bitrate=N/A speed=6.49xvideo:323823kB audio:41566kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown[libx264 @ 0000000001c3b2c0] frame I:1027 Avg QP:18.67 size: 41760[libx264 @ 0000000001c3b2c0] frame P:8278 Avg QP:19.80 size: 24281[libx264 @ 0000000001c3b2c0] frame B:11897 Avg QP:21.62 size: 7373[libx264 @ 0000000001c3b2c0] consecutive B-frames: 13.6% 30.3% 13.1% 42.9%
