Ice 23 Posted May 25, 2016 Author Posted May 25, 2016 I may have fixed it, I shutdown the server renamed the directory with the files in it that I was having trouble with and all seems to be fine. I have restarted the server a couple of times and run the library refresh and they are still showing up, I suppose time will tell.
Ice 23 Posted June 7, 2016 Author Posted June 7, 2016 In TV Shows, example: (AUD dates) Folder A creation date is the 01/12/15 latest file in Folder A is the 02/12/15 Foder B creation date is the 29/11/15 latest file in Folder B is the 05/12/15 When the WMC client sorts by date it will put Folder A above Folder B even though Folder B has a newer file inside it The older stable release didn't do this it would always put Folder B before Folder A when sorting by dates I thought this problem had been fixed but after 2 weeks the database is no closer to being sorted in the correct order
Luke 42239 Posted June 8, 2016 Posted June 8, 2016 I thought this problem had been fixed but after 2 weeks the database is no closer to being sorted in the correct order Hi, try going to the metadata manager in the web interface. Click on your TV library, then on the right hand side click the 3-dot menu and refresh the tv library. This will take some time so best to do it overnight. thanks.
