Guy 7 Posted May 20, 2016 Posted May 20, 2016 Three issues with playlists; Playlists from Movies/TV shows are appearing under the Music view Playlists from other users are visible under the Music view (Only playlists belonging to user should be visible) When adding a new item to a playlist, the drop list shows ALL playlists regardless of which user a specific playlist belongs to. Shouldn't the playlists in the drop list be limited to owner of playlists?
Luke 42186 Posted May 20, 2016 Posted May 20, 2016 The user is known and will be resolved in a future release, thanks. 1
Deedeetee 8 Posted June 18, 2016 Posted June 18, 2016 Hello! I've set up a playlist and put the movies into a specific order, but on testing this on the emby theatre on another laptop, the playlist order is not reflected, and the films are in a random order. Am I missing a setting somewhere that ensures the playlist order is the same on whichever device it is being viewed?
