jasonmcroy 320 Posted May 20, 2016 Posted May 20, 2016 At 9:10 tonight I noticed that 2 recordings I had scheduled earlier today were not recording - Blacklist and The Catch. I am not sure what Beta version I was on at the time they didn't start because I noticed there was a server update available at that time so I updated really quick to see if it would fix the issue and pick them up even though I missed the 1st 10 minutes. it did not resolve the issue so I quickly opened my HDHomerun View app to record them on that DVR, so at least I caught most of the episodes. The current version I am on is Version 3.0.5980.0, so the version prior to that was what I was on when this occurred. Here is my current log in case there is something you can see in there: server-63599289076.txt
Luke 42242 Posted May 20, 2016 Posted May 20, 2016 2016-05-19 21:11:22.3425 Error App: Error recording to \\MEDIA-SERVER\TV Shows2\Series\The Catch\Season 1\The Catch S01E09 The Happy Couple; The Wedding.ts *** Error Report *** Version: 3.0.5980.0 Command line: C:\Users\mcroy\AppData\Roaming\Emby-Server\System\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.2.9200.0 Processor count: 8 64-Bit OS: True 64-Bit Process: True Program data path: C:\Users\mcroy\AppData\Roaming\Emby-Server Application Path: C:\Users\mcroy\AppData\Roaming\Emby-Server\System\MediaBrowser.ServerApplication.exe The network name cannot be found.
jasonmcroy 320 Posted May 20, 2016 Author Posted May 20, 2016 So it's an error in my folder setup? I made a bunch of changes this morning to my folder structure. Did I not put something in there correctly?
Luke 42242 Posted May 20, 2016 Posted May 20, 2016 i have no idea. all i can tell you is that error is being thrown by your file system.
jasonmcroy 320 Posted May 20, 2016 Author Posted May 20, 2016 (edited) Ok. I screwed it up somehow. Sorry. I could have sworn I changed the file path for the recording folder but I just went and looked and it's still showing the old path that I deleted the folder for. Thanks for looking at it so quickly for me though. I have another recording set for 10:00pm so hopefully I have it right this time. EDIT: Ok, so after I fixed the file path I noticed that the recordings started up. Nice to know the server will retry the scheduled recording after it missed it. This was completely user error here. smh Edited May 20, 2016 by jasonmcroy
