Simple CA signed HTTPS SSL certificate with letsencrypt
I just added a CA signed certificate from letsencrypt to get HTTPS for external connections.
This site is really helpful (note - google translate messes up the commands):
http://blog.ouranos..../04/emby-https/
Also basic instructions from here:
https://letsencrypt....etting-started/
You need to have your own domain e.g. emby.mydomain.com, and have DNS configured to point to emby servers external IP.  (inc use of DDNS service to do this. I use dnsomatic and cloudflare DNS)
You need to have port 443 open on your router and port mapped to your emby servers IP.
(This is because letsencrypt certification issuing process calls back to your server to ensure you own the domain)
git clone https://github.com/certbot/certbot
cd certbot
./certbot-auto certonly --standalone -d emby.domain.com
cd /etc/letsencrypt/live/emby.domain.com
sudo openssl pkcs12 -inkey privkey.pem -in fullchain.pem -export -out emby.pfx
Note:
1) Because certbot spawns a root owned process, permissions for /etc/letsencrypt dirs have root-only permissions so you may need to adjust permissions)
2) When openssl asks for password pass none (enter)
Finally configure emby to use certificate at path /etc/letsencrypt/live/emby.domain.com/emby.pfx
letsencrypt certificates are valid for 3 months, so this needs to be repeated every 3 months.
  • Like 2
Thx :) I justed updated the script with your advice @hijinx
  • 2 years later...
Is this tutorial still relevant today?
Yes it should be.
Yes it should be.
Ok, thank you.
  • 6 months later...
What is the recommended way to give emby access to /etc/letsencrypt/live/emby.domain.com/emby.pfx
for now all i did was
chmod -R 777 /etc/letsencrypt/live
but im sure there is a more elegant way
For people in the future here is slightly more information to get you up and running
Forwarded port 443 and 80 to my server so lets encrypt can authenticate
cd certbot/
./certbot-auto certonly --standalone -d xxx.com
sudo su
cd /etc/letsencrypt/live/xxx.com/
Went to
Advanced > External domain: > xxx.com
Advanced > Custom ssl certificate path: > /etc/letsencrypt/live/xxx.com/emby.pfx
Advanced > Secure connection mode: > Required for all remote connections
and it worked flawlessly
Edited by Eddie
  • 9 months later...
You can have a script triggered automatically after a renewal. I wrote the following one that:
  • removes old pfx
  • generates a new one (with a custom password to be changed in the script)
    • The file is generated in /var/lib/emby/cert.pfx. I advise to keep this as default as emby already have access to this folder. You should configure the admin to use this path for the certificate
  • changes its access rights to be accessible by emby user only
  • restarts emby-server
Just create a emby.sh file in /etc/letsencrypt/renewal-hooks/post folder, and chmod +x emby.sh.
#!/bin/sh
set -e
# Should be the same password for the certificate in emby admin
PASS="emby"
DEFAULT_LINEAGE="/etc/letsencrypt/live/YOUR.DOMAIN.TLD/"
RENEWED_LINEAGE=${RENEWED_LINEAGE:-$DEFAULT_LINEAGE}
rm -f /var/lib/emby/cert.pfx
openssl pkcs12 -inkey "$RENEWED_LINEAGE/privkey.pem" -in "$RENEWED_LINEAGE/fullchain.pem" -export -out /var/lib/emby/cert.pfx -passout "pass:$PASS"
chown emby:emby /var/lib/emby/cert.pfx
systemctl restart emby-server
echo "Emby certificate generated"
Edited by adventclad
  • Like 1
