nekromantik 24 Posted May 17, 2016 Posted May 17, 2016 Hi all, I got a really random problem. My Emby library on my PC has all my watched status correct. When I add a new item most of the time Kodi updates fine and I see the new item however every now and then it re syncs a lot of times even though I only added 1 or 2 new items and I loose all my watched status in Kodi. Attached is a log after it done that a few mins ago. Thanks spmc.log
nekromantik 24 Posted May 18, 2016 Author Posted May 18, 2016 None of the above. Not using trakt or NFOs.
xnappo 1611 Posted May 18, 2016 Posted May 18, 2016 Also see here: http://emby.media/community/index.php?/topic/23971-fast-startup-sync-server-plugin/page-25&do=findComment&comment=315390
nekromantik 24 Posted May 18, 2016 Author Posted May 18, 2016 next thing to check would be to make sure all your shows are correctly identified in Emby. For the shows that are updating all the time check that Emby has correctly identified them. Yes Emby has them correctly identified.
