Cokefrevr 0 Posted May 14, 2016 Posted May 14, 2016 So emby has been working fine but in the last day or so Emby opens to the loading screen, then the screen goes black. After 10-15 seconds the app auto closes and goes back to the fireTV home screen.
Luke 42243 Posted May 14, 2016 Posted May 14, 2016 Hi there, sorry to hear about this. Can you please provide the emby server log? http://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks.
Cokefrevr 0 Posted May 14, 2016 Author Posted May 14, 2016 (edited) Thanks, @Luke I included the portion of the log that includes the time. If you need the full log ill include it too, but the server said it was too large to include. Emby Log Time of the issue.txt Edited May 15, 2016 by Cokefrevr
Cokefrevr 0 Posted May 15, 2016 Author Posted May 15, 2016 There compressed it to all hell haha thats the full file. The time i opened the appp was around 6:30 and it closed on its own at 6:31/32 May 14th(today) server-63598780800.zip
Solution Luke 42243 Posted May 15, 2016 Solution Posted May 15, 2016 Would you mind doing a quick test. Can you remove the kodi sync plugin and then see if the issue persists? thanks. 1
Cokefrevr 0 Posted May 15, 2016 Author Posted May 15, 2016 It works now, that's really weird. Thanks!
Cokefrevr 0 Posted May 15, 2016 Author Posted May 15, 2016 Another issue I've had, it's kind of random so I'm. Not sure how to reproduce this, sometimes movies don't have sound and the video plays or the video auto ends without playing. I restart fireTV and the sound issues are fixed. So far I cannot seem to play one video just on fire tv but it works well on other devices.
ebr 16336 Posted May 15, 2016 Posted May 15, 2016 What kind of audio system is the Fire hooked to? Did you read the popup message that came up on first run? How did you respond to it and how is the audio option in the app settings set?
Cokefrevr 0 Posted May 16, 2016 Author Posted May 16, 2016 Its hooked to just the television with 2 auxiliary speakers. I dont recall a pop up message on the Emby app on first run. As for sound settings in app settings they were all left at default.
