Taurec 60 Posted May 11, 2016 Posted May 11, 2016 Hello I have a "big" problem with the DVBViewer Plugin. The Plugin doesn't work for me correctly. I get all Channel name like: 0-Unitymedia-History without any Logos. That mean i have removed the plugin (uninstall) But now the the "Refresh Guide" toggle off and on and the DVBViewer Media Server appear at the Live-TV When i remove the Server, it comes back after 10-30 second and the Refresh Guide start to toggle again. How can i remove the DVBViewer media Server permanently. Is there a possibility to remive some entry in some files? What can I do ? cu Taurec P.S: A new install and a uninstall again change nothing
pünktchen 1410 Posted May 11, 2016 Posted May 11, 2016 [emoji20] You really should have asked for help with your channel names and logos instead of uninstalling the plugin! Anyway, what do you mean by "it shows the DVBViewer Media Server"? Please post a screenshot.
Taurec 60 Posted May 12, 2016 Author Posted May 12, 2016 Hello pünktchen, today i like to prepare some screenshot. That mean i install the plugin again and give me the access to the live-TV. After the reboot of Emby i adjust the settings and the Refresh Guide starts and at the live-tv the channels appears. But now with correct names. ( i'm really suprised) So far so good, with deactivated emby direct playback at the setting, i can watch tv But the toggle of the Refresh Guide is still happen. It doesn matter how often i cancel the Refresh Guide it comes back afte a few second. At the moment there is a continue acceess on my Harddisk and the Refresh Guide are activ but always on 0% What can i do to stop the guide. Do you have any idea cu Taurec P.S. how can i remove the Icons for the TV Guide and the TV Aufnahmen?
Taurec 60 Posted May 12, 2016 Author Posted May 12, 2016 @ Pünktchen, and now Emby is blocked. (i have watch TV for prox. 15min) No operation at the emby server possible. ffmpeg is running with 15%. I have to reboot the qnap However, come we back to my entry question: How can i remove the DVBViewer media Server permanently. (because the dvbviewer media server comes back, doesn't matter how often i use the delete button (the plugin is already removed) what file I need to edit. cu Taurec
pünktchen 1410 Posted May 12, 2016 Posted May 12, 2016 (edited) @ Pünktchen, and now Emby is blocked. (i have watch TV for prox. 15min) No operation at the emby server possible. ffmpeg is running with 15%. I have to reboot the qnap However, come we back to my entry question: How can i remove the DVBViewer media Server permanently. (because the dvbviewer media server comes back, doesn't matter how often i use the delete button (the plugin is already removed) what file I need to edit. cu Taurec What DVBViewer Media Server?Do you mean the DVB devices listed at the top of the tv status page? They have nothing to do with my plugin! You have to click on each device and then uncheck "Enable this tuner". Don't use the trash icon or they will always come back again! Maybe that's the reason why you have problems with the plugin. Better read the description in my DVBViewer starting thread next time... Edited May 12, 2016 by pünktchen
Taurec 60 Posted May 12, 2016 Author Posted May 12, 2016 Hello Pünktchen, befor i install you plugin there was no server at the status page, absolut nothing! After the install of the plugin my dvbviewer recording service (same Network other Device) appears at this page. Now i like to uninstall all, remove the plugin, diable the live-tv access for me, the DVBViewer media server is still at this page. And the refresh guide is toggling. now after 4 time reboot with dectivating of my dvbviewer recording service i was enable to get the option to disable the tuner. With deactivating of the tuner the refresh guide stopped. What do you mean, befor i install your plugin i had no tuner, after the install i have a tuner, with deinstallation of the plugin the tuner is still existing. I like to get a clean system without any dead components. cu Taurec P.S. is this maybe happen because Emby is runnning on a Qnap system ?
pünktchen 1410 Posted May 12, 2016 Posted May 12, 2016 (edited) After you have installed my plugin, you have restarted your Emby server for sure. Propably at the same time a new Emby server update was installed that shows those DVB-IP devices. You cannot get rid of those devices because it's a core feature of Emby! Again, it's not because of my plugin! I've seen those devices in Emby without my plugin right after i installed DVBViewer Recording Service. Edited May 12, 2016 by pünktchen
