loonytunes1234 1 Posted May 10, 2016 Posted May 10, 2016 Any reason why we do not have the ability to sort our channels into an order we prefer, also in the "on now" section the first couple of tiles are full sized then the rest are truncated and you have to read the full description below to see what it is sometimes? Any way of showing full tiles for on now? Cheers
loonytunes1234 1 Posted May 10, 2016 Author Posted May 10, 2016 Hi Luke, looked around all the options and looked up on google, cant see how to do it, so if its possible then do tell?
loonytunes1234 1 Posted May 11, 2016 Author Posted May 11, 2016 what makes you think you can't already do that? If it is possible, 9 words would have probably covered HOW to do it?
Luke 42242 Posted May 11, 2016 Posted May 11, 2016 Sorry, in situations like these I like to learn what it is you're struggling with in addition to answering the question, that way we can change whatever needs to be changed so that the next person will get it on the first try. The answer is you can edit channel sort titles using the metadata manager just like any other content, and/or you can also mark channels as favorites to affect sorting as well.
loonytunes1234 1 Posted May 11, 2016 Author Posted May 11, 2016 Hi Luke, thanks for your response. I did in fact find a way of doing it by adding channels as favs I had to be careful what order I did it in to have them in the right slots but it kinda worked. I did look at the metadata manager but I could only find a way to change channel names maybe, not the number order in which they appear in the epg. I will try to play around a bit more but if you can spare a mo, a pointer as to how to use meta manger to do it would be cool TIA
Luke 42242 Posted May 11, 2016 Posted May 11, 2016 Ok, it does look like the sort name field is hidden for tv channels, i will unhide it for the next release of the server. 1
loonytunes1234 1 Posted May 11, 2016 Author Posted May 11, 2016 Ok, it does look like the sort name field is hidden for tv channels, i will unhide it for the next release of the server. Thank you
