MSattler 390 Posted October 29, 2016 Posted October 29, 2016 It was like this when converting to MKV was first added and was fixed, but happening in DEV and Stable. I guess it's in Beta as well, but I don't currently have Beta installe to test with. Hopefully @Luke/@ebr can fix it again It's a feature dontcha know? =) 1
Luke 42242 Posted November 9, 2016 Posted November 9, 2016 @@Kent and others I can't reproduce this but I'm going to increase the ffmpeg analyze duration on the recording stream. we'll see if that helps make a difference, thanks.
Kent 92 Posted November 13, 2016 Posted November 13, 2016 @@Kent and others I can't reproduce this but I'm going to increase the ffmpeg analyze duration on the recording stream. we'll see if that helps make a difference, thanks. Thanks Luke. I'm on FreeNAS so a version or two behind but let me know when i should rerun Live TV recordings and post logs. As of now i can't use Live TV recordings on Version 3.0.8300.0 .
denz 501 Posted November 14, 2016 Posted November 14, 2016 (edited) I recorded few episodes of Seinfeld yesterday now I have over 1 thousand episodes. My pc currently is not fast enough for transcoding so all those settings are disabled. There are number of issues with the files some haven't recorded fully the Fatigues and the Checks it is a 5 hour episode which is clearly incorrect running time this has appeared few times that incorrect running time is recorded. Edit: The Checks it is showing correct recording length in emby it is only not showing correctly in explorer. The fatigues episode it is only showing 26 minutes but should be 43 with padding. Edited November 14, 2016 by denz
CBers 7554 Posted November 14, 2016 Author Posted November 14, 2016 I had a similar issue last night when one of my MP4 recordings was split into multiple files again, most of which were 0Kb in size !! Another recording worked fine though !!
Luke 42242 Posted November 14, 2016 Posted November 14, 2016 @@denz that particular issue is resolved in the latest beta.
CBers 7554 Posted November 14, 2016 Author Posted November 14, 2016 @@denz that particular issue is resolved in the latest beta. And the latest DEV ??
CBers 7554 Posted November 14, 2016 Author Posted November 14, 2016 I'm having trouble playing anything via Emby Live TV at the moment on my Shield TV. Getting the message: Cannot play this video format. Works fine with the HDHomeRun app on my Shield. Will post a server log shortly.
CBers 7554 Posted November 14, 2016 Author Posted November 14, 2016 Seems to be an error in the server log. 2016-11-14 17:40:49.7826 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/LiveTv/Channels/cd85eb06191c3f035679be4fc307a8dc?userId=9eac53d92edd448196cd69a41d3cb18f&format=json. UserAgent: Dalvik/2.1.0 (Linux; U; Android 6.0; SHIELD Android TV Build/MRA58K) 2016-11-14 17:40:49.7966 Info HttpServer: HTTP Response 200 to 192.168.1.233. Time: 14ms. http://192.168.1.140:8096/emby/LiveTv/Channels/cd85eb06191c3f035679be4fc307a8dc?userId=9eac53d92edd448196cd69a41d3cb18f&format=json 2016-11-14 17:40:49.7966 Info HttpServer: HTTP POST http://192.168.1.140:8096/emby/Items/cd85eb06191c3f035679be4fc307a8dc/PlaybackInfo?format=json. UserAgent: Dalvik/2.1.0 (Linux; U; Android 6.0; SHIELD Android TV Build/MRA58K) 2016-11-14 17:40:49.8196 Error MediaSourceManager: Error getting media sources *** Error Report *** Version: 3.1.6162.4468 Command line: C:\Users\Media\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.1.7601 Service Pack 1 64-Bit OS: True 64-Bit Process: True Processor count: 4 Program data path: C:\Users\Media\AppData\Roaming\MediaBrowser-Server Application directory: C:\Users\Media\AppData\Roaming\MediaBrowser-Server\System Object reference not set to an instance of an object. System.NullReferenceException at Emby.Server.Implementations.LiveTv.TunerHosts.M3UTunerHost.IsValidChannelId(String channelId) at Emby.Server.Implementations.LiveTv.TunerHosts.BaseTunerHost.<GetChannelStreamMediaSources>d__13.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.LiveTv.EmbyTV.EmbyTV.<GetChannelStreamMediaSources>d__81.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.LiveTv.LiveTvManager.<GetChannelMediaSources>d__53.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.LiveTv.LiveTvMediaSourceProvider.<GetMediaSourcesInternal>d__10.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.Library.MediaSourceManager.<GetDynamicMediaSources>d__18.MoveNext() 2016-11-14 17:40:49.8196 Info HttpServer: HTTP Response 200 to 192.168.1.233. Time: 19ms. http://192.168.1.140:8096/emby/Items/cd85eb06191c3f035679be4fc307a8dc/PlaybackInfo?format=json 2016-11-14 17:41:59.9346 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Users/9eac53d92edd448196cd69a41d3cb18f/Items/cd85eb06191c3f035679be4fc307a8dc?format=json. UserAgent: Dalvik/2.1.0 (Linux; U; Android 6.0; SHIELD Android TV Build/MRA58K) 2016-11-14 17:41:59.9876 Info HttpServer: HTTP Response 200 to 192.168.1.233. Time: 53ms. http://192.168.1.140:8096/emby/Users/9eac53d92edd448196cd69a41d3cb18f/Items/cd85eb06191c3f035679be4fc307a8dc?format=json 2016-11-14 17:42:01.8347 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/LiveTv/Programs/Recommended?Limit=20&UserId=9eac53d92edd448196cd69a41d3cb18f&IsAiring=true&EnableTotalRecordCount=false&ImageTypeLimit=1&Fields=Overview%2CPrimaryImageAspectRatio%2CChannelInfo&format=json. UserAgent: Dalvik/2.1.0 (Linux; U; Android 6.0; SHIELD Android TV Build/MRA58K) 2016-11-14 17:42:01.8347 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Users/9eac53d92edd448196cd69a41d3cb18f/Items?Filters=IsResumable&ImageTypeLimit=1&Fields=PrimaryImageAspectRatio%2COverview%2CItemCounts%2CDisplayPreferencesId&MediaTypes=Video&EnableTotalRecordCount=false&recursive=true&ExcludeLocationTypes=Virtual&sortOrder=Descending&Limit=50&SortBy=DatePlayed&format=json. UserAgent: Dalvik/2.1.0 (Linux; U; Android 6.0; SHIELD Android TV Build/MRA58K) 2016-11-14 17:42:01.8617 Info HttpServer: HTTP Response 200 to 192.168.1.233. Time: 25ms. http://192.168.1.140:8096/emby/Users/9eac53d92edd448196cd69a41d3cb18f/Items?Filters=IsResumable&ImageTypeLimit=1&Fields=PrimaryImageAspectRatio%2COverview%2CItemCounts%2CDisplayPreferencesId&MediaTypes=Video&EnableTotalRecordCount=false&recursive=true&ExcludeLocationTypes=Virtual&sortOrder=Descending&Limit=50&SortBy=DatePlayed&format=json 2016-11-14 17:42:01.8847 Info HttpServer: HTTP Response 200 to 192.168.1.233. Time: 50ms. http://192.168.1.140:8096/emby/LiveTv/Programs/Recommended?Limit=20&UserId=9eac53d92edd448196cd69a41d3cb18f&IsAiring=true&EnableTotalRecordCount=false&ImageTypeLimit=1&Fields=Overview%2CPrimaryImageAspectRatio%2CChannelInfo&format=json 2016-11-14 17:42:02.0027 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Items/1d041deb6dea7c7b80a80c0184f36667/Images/Primary?MaxHeight=300&EnableImageEnhancers=true&Tag=1dd76e727badd96e1a2a5d2ca2718b2d. UserAgent: Dalvik/2.1.0 (Linux; U; Android 6.0; SHIELD Android TV Build/MRA58K) 2016-11-14 17:42:02.0027 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Items/3805995b206ebb3c4bba4e63af99dabc/Images/Primary?MaxHeight=300&EnableImageEnhancers=true&Tag=30100745fad1c90608cb9e8e96734aa4. UserAgent: Dalvik/2.1.0 (Linux; U; Android 6.0; SHIELD Android TV Build/MRA58K) 2016-11-14 17:42:02.0027 Debug App: ConvertImageToLocal item 1d041deb-6dea-7c7b-80a8-0c0184f36667 - image url: https://s3.amazonaws.com/schedulesdirect/assets/p8158525_n203912_cc_v4_aa.jpg 2016-11-14 17:42:02.0027 Info HttpClient: HttpClientManager GET: https://s3.amazonaws.com/schedulesdirect/assets/p8158525_n203912_cc_v4_aa.jpg 2016-11-14 17:42:02.0027 Info HttpServer: HTTP Response 200 to 192.168.1.233. Time: 3ms. http://192.168.1.140:8096/emby/Items/3805995b206ebb3c4bba4e63af99dabc/Images/Primary?MaxHeight=300&EnableImageEnhancers=true&Tag=30100745fad1c90608cb9e8e96734aa4 2016-11-14 17:42:03.3548 Debug ProviderManager: Saving image to C:\Users\Media\AppData\Roaming\MediaBrowser-Server\metadata\livetv\1d041deb6dea7c7b80a80c0184f36667\poster.jpg 2016-11-14 17:42:03.3548 Debug App: Saving The Chase to database. 2016-11-14 17:42:03.3548 Debug SqliteItemRepository: replace into TypedBaseItems (guid,type,data,Path,StartDate,EndDate,ChannelId,IsKids,IsMovie,IsSports,IsSeries,IsLive,IsNews,IsPremiere,EpisodeTitle,IsRepeat,CommunityRating,CustomRating,IndexNumber,IsLocked,Name,OfficialRating,MediaType,Overview,ParentIndexNumber,PremiereDate,ProductionYear,ParentId,Genres,InheritedParentalRatingValue,SchemaVersion,SortName,RunTimeTicks,OfficialRatingDescription,HomePageUrl,VoteCount,DisplayMediaType,DateCreated,DateModified,ForcedSortName,IsOffline,LocationType,PreferredMetadataLanguage,PreferredMetadataCountryCode,IsHD,ExternalEtag,DateLastRefreshed,DateLastSaved,IsInMixedFolder,LockedFields,Studios,Audio,ExternalServiceId,Tags,IsFolder,UnratedType,TopParentId,IsItemByName,SourceType,TrailerTypes,CriticRating,CriticRatingSummary,InheritedTags,CleanName,PresentationUniqueKey,SlugName,OriginalTitle,PrimaryVersionId,DateLastMediaAdded,Album,IsVirtualItem,SeriesName,UserDataKey,SeasonName,SeasonId,SeriesId,SeriesSortName,ExternalSeriesId,ShortOverview,Tagline,Keywords,ProviderIds,Images,ProductionLocations,ThemeSongIds,ThemeVideoIds,TotalBitrate,ExtraType,Artists,AlbumArtists,ExternalId) values (@1,@2,@3,@4,@5,@6,@7,@8,@9,@10,@11,@12,@13,@14,@15,@16,@17,@18,@19,@20,@21,@22,@23,@24,@25,@26,@27,@28,@29,@30,@31,@32,@33,@34,@35,@36,@37,@38,@39,@40,@41,@42,@43,@44,@45,@46,@47,@48,@49,@50,@51,@52,@53,@54,@55,@56,@57,@58,@59,@60,@61,@62,@63,@64,@65,@66,@67,@68,@69,@70,@71,@72,@73,@74,@75,@76,@77,@78,@79,@80,@81,@82,@83,@84,@85,@86,@87,@88,@89,@90,@91) 2016-11-14 17:42:03.3548 Debug SqliteItemRepository: ExternalId: 2016-11-14 17:42:03.7308 Info HttpServer: HTTP Response 200 to 192.168.1.233. Time: 1728ms (slow). http://192.168.1.140:8096/emby/Items/1d041deb6dea7c7b80a80c0184f36667/Images/Primary?MaxHeight=300&EnableImageEnhancers=true&Tag=1dd76e727badd96e1a2a5d2ca2718b2d I've sent @@ebr the debug log from within the ATV app.
blade005 185 Posted November 14, 2016 Posted November 14, 2016 (edited) I'm having trouble playing anything via Emby Live TV at the moment on my Shield TV. Getting the message: Cannot play this video format. Works fine with the HDHomeRun app on my Shield. Will post a server log shortly. CBers, Same issue reported in the SERVER -- TESTING AREA forum. https://emby.media/community/index.php?/topic/41393-cant-stream-live-tv/ Edited November 14, 2016 by blade005 1
