00mpy 0 Posted May 10, 2016 Posted May 10, 2016 (edited) scenario: I re-built my jails on freenas 9.10 as the PBI update kept failing via the freenas GUI (still have the old jail which works fine) copied the contents of /var/db/emby-server to the new jail started emby without issue db upgrade and full library scan completed without issue (version update to 5931 from 5786) the issue is now that all video media will not play in any client app (web, chromecast, android) from what i can tell in the logs it appears to be a transcoding issue but that is all that i can understand myself apologies for the size of the server logs..... debug on by the looks remux-f7099ad7-8d41-4e4b-bacd-1ae09bcc45f2.txt transcode-f9a011ef-cdd2-4a46-8b9e-a699330f4448.txt transcode-f051e420-cf72-4a3b-a82e-01d14775176b.txt server-63598495830 part1.txt Edited May 10, 2016 by 00mpy
Luke 42237 Posted May 10, 2016 Posted May 10, 2016 Hi, your version of ffmpeg appears to be missing some required features. I suppose updating that is the first thing I would try to do Shared object "libvorbisenc.so.2" not found, required by "libavcodec.so.56"
00mpy 0 Posted May 10, 2016 Author Posted May 10, 2016 i tried updating ffmpeg using the instructions on http://emby.media/freebsd-server.html. i got the same error in the web client, and the same error in the transcode logs. The server logs appear to have the same stuff as what i have provided previously. Any other thoughts?
00mpy 0 Posted May 11, 2016 Author Posted May 11, 2016 I have it working again. I am not sure what the cause was but here is what i did. backed up the data in /var/db/emby-server/ directory deleted the Emby plugin via FreeNAS GUI install 5913 PBI into the jail started Emby plugin confirmed playback was functional updated the plugin via FreeNAS GUI Confirmed playback was still functional
Luke 42237 Posted May 11, 2016 Posted May 11, 2016 That's really strange, and doesn't make sense to me but Josh might now. Changing Emby Server should't affect what ffmpeg libraries are installed. But I'm glad to hear you're having better results.
00mpy 0 Posted May 11, 2016 Author Posted May 11, 2016 Who knows............. sometimes there is just no answer to the cause. Now I am trying to get the media info for everything to refresh so that it doesn't transcode everything.
