radioactivesqrl 2 Posted May 9, 2016 Posted May 9, 2016 Hi, I've noticed in the past couple releases of Emby for FreeNAS that the cinema mode has stopped playing trailers. Currently I'm running version emby-3.0.5931-amd64. When I play a movie it just goes directly into the main feature as if the setting was disabled entirely. The trailers are stored locally with the movie and I am able to play the trailer directly from the web interface so it shouldn't be any kind of format/transcoding problem or anything wrong with the file location. Server>Playback>Cinema Mode settings (which haven't changed) Enable for: Movies Include Trailers from my Library Enable smart Parental control Cinema mode is also enabled under my User>Playback settings I've checked the server logs and didn't find any kinds of errors there. Just a bunch of HTTP 200 messages. Is this a known issue? Is there somewhere I should check next?
Luke 42237 Posted May 9, 2016 Posted May 9, 2016 Hi, there are fixes for this in 3.0.5934, so I would start by updating to the latest version of Emby Server.
bluemonkey07 590 Posted May 10, 2016 Posted May 10, 2016 3.0.5931 is the latest, freenas releases are a little behind
radioactivesqrl 2 Posted May 10, 2016 Author Posted May 10, 2016 Hi, there are fixes for this in 3.0.5934, so I would start by updating to the latest version of Emby Server. Thanks Luke, I guess I'll just wait for the update.
