JohnnyM 40 Posted May 8, 2016 Posted May 8, 2016 I have a directory in Appdata/Roaming/MediaBrowser-Server/ImagesByName/People. Is this directory a holdover from MB2 and I can delete it. It contains 44,000 directorires but doesn't MB3 get its people images from MediaBrowser-Server/metadata/people. Thanks JohmmyM
Luke 42186 Posted May 8, 2016 Posted May 8, 2016 The server dashboard will display the metadata path. Underneath that is there people folder that is being used, so check that.
Happy2Play 9800 Posted May 8, 2016 Posted May 8, 2016 (edited) This was a change 6+ months ago merging IBN and Metadata. That was one of the big changes in 3.05821.0 no longer respecting the "itembyname" path still listed in OLD/ORIGINAL installs. If you look at your log or system.xml file you will probably still see that old path listed. There are several topics on this. http://emby.media/community/index.php?/topic/30885-metadata-people-problem/?p=300617 Edited May 8, 2016 by Happy2Play 1
