berrick 30 Posted May 7, 2016 Posted May 7, 2016 Hi All, Not posted for a while but looking for members thoughts on the following. Looking to replace the flat screen in the bedroom with a smart TV specifically to talk with my Emby server. Spec (UK) Freeview HD tuner, 1080 res, up to 28". Manufacturer, LG or Samsung though leaning more toward Samsung with smart hub. Which is more compatible with Emby currently?
SilentAssassin 96 Posted May 8, 2016 Posted May 8, 2016 If you go Samsung you will need to make sure you get a H series as that is the latest that the app can be installed on. 1
dragon2611 29 Posted May 28, 2016 Posted May 28, 2016 Unless you want a really Old TV ~2011 app's don't exist for either.It's only by chance my samsung in the bedroom is an older model (Picked it up cheap in a sale)
SilentAssassin 96 Posted May 29, 2016 Posted May 29, 2016 The H series Samsung TV's are 2014 models and are still sold.
mcpllabelle 8 Posted June 5, 2016 Posted June 5, 2016 Id recommend Samsung. Client exist for it and its really nice.
Luke 42234 Posted August 19, 2016 Posted August 19, 2016 I just want to update you all because I know you are waiting for an Emby for LG app. We have submitted it to the LG store but there appears to be a very long wait time in the app review process. Hopefully it will not be too much longer. Thank you for your patience. 1
Deihmos 170 Posted November 4, 2016 Posted November 4, 2016 I have both and I would recommend samsung instead. The LG software is nice but very limited. I think the Samsug that cost a fraction of the cost of my LG does a lot more.
kwilcox 78 Posted November 4, 2016 Posted November 4, 2016 screenplay for WebOS2 & WebOS3 is very close to being accepted by LG.
henr0 0 Posted November 7, 2016 Posted November 7, 2016 I love my LG TV and for the price it was the best deal. Great picture quality. But OMG WebOS is useless for apps. Not that you really need that many apps for a TV, but still.
Deihmos 170 Posted November 7, 2016 Posted November 7, 2016 I just purchased a 2016 Samsung TV and the software is much nicer than webos and there is plenty of content. I use a cable card and it can play DRM channels so I don't need to attach anything to it. The previous Samsung software was a little sluggish. Sent from my SHIELD Tablet K1 using Tapatalk
Luke 42234 Posted November 7, 2016 Posted November 7, 2016 I just purchased a 2016 Samsung TV and the software is much nicer than webos and there is plenty of content. I use a cable card and it can play DRM channels so I don't need to attach anything to it. The previous Samsung software was a little sluggish. Sent from my SHIELD Tablet K1 using Tapatalk There is an update for the Emby Samsung app rolling out now so you should give it a shot. It's version 1.0.14 and it will most likely direct play everything you throw at it.
Deihmos 170 Posted November 8, 2016 Posted November 8, 2016 (edited) Cool. It works great but ai don't see a TV guide. Is this the same app coming to LG or is it another app with the name screenplay? Edited November 8, 2016 by Deihmos
kwilcox 78 Posted November 8, 2016 Posted November 8, 2016 The official emby app is in the works for LG as well. Not to be confused with screenplay.
Allan Cameron 40 Posted November 17, 2016 Posted November 17, 2016 I have both and would definitely go with Samsung. Smart hub is much nicer then WebOS IMO. However using either of them or any TV for that matter as my main media client (Emby/Plex) just doesn't cut it. Requires transcoding to often to lower quality as its unable to direct play video I shoot with high bitrates of 40 to 50Mbit without stutter and choppiness. Smart TVs just don't have the horsepower yet of a high end media box such as my Roku Ultra and Apple TV 4 which play those files with ease. I realize a lot of people wouldn't have this issue due to not having extreme bitrate video in their libraries and in that case a smart TV is fine.
SHSPVR 125 Posted November 23, 2016 Posted November 23, 2016 I just want to update you all because I know you are waiting for an Emby for LG app. We have submitted it to the LG store but there appears to be a very long wait time in the app review process. Hopefully it will not be too much longer. Thank you for your patience. So Luke it this in the Store now ?
Luke 42234 Posted November 23, 2016 Posted November 23, 2016 Not yet. I am in process of packaging another revision for submission.
SHSPVR 125 Posted November 23, 2016 Posted November 23, 2016 Ok thanks can take look at other message under General Discussion about Streaming Media Players
