Mericon 0 Posted January 22, 2019 Posted January 22, 2019 any effords here? i have an Philips android tv and see the DLNA server but cant get any media over dlna.
Luke 42237 Posted January 22, 2019 Posted January 22, 2019 Not yet unfortunately as I haven't been able to personally test on a Phillips. We do have an Android TV app though.
Guest Posted November 2, 2019 Posted November 2, 2019 Hi, I wanted to know if you found a solution for the Philips Smart TV? If not, I'm ready to test some things if you tell me what to do.
Luke 42237 Posted November 2, 2019 Posted November 2, 2019 Hi, I wanted to know if you found a solution for the Philips Smart TV? If not, I'm ready to test some things if you tell me what to do. We haven't been able to personally test on a Philips ourselves, so it's hard to say. Recent releases have made fixes for other devices though, so there's always a chance it will help with Philips too. You may want to try the 4.3 beta. Thanks.
Guest Posted November 2, 2019 Posted November 2, 2019 (edited) We haven't been able to personally test on a Philips ourselves, so it's hard to say. Recent releases have made fixes for other devices though, so there's always a chance it will help with Philips too. You may want to try the 4.3 beta. Thanks. Well, I've just tested it: I see my server listed on the DLNA devices now but when I enter, it freeses my TV (I can't even turn it off). The model is 58PSU6203. It hasn't Android TV. I used the 4.3.0.18 beta EDIT: I tested again and It worked!!! I'll try tomorrow just to be sure... Edited November 3, 2019 by aldoemby
Guest Posted November 3, 2019 Posted November 3, 2019 (edited) Ok thanks for testing. I tested again this morning. What I did: - I turn the TV on - Go to Network - I see my Emby DLNA (good!) - I go inside: the TV freezes I tested twice and came with the same result. Edited November 3, 2019 by aldoemby
Guest Posted November 4, 2019 Posted November 4, 2019 Hi, I went back to the 4.2.1.0: I don't know if it could be a lead but when I selected "Blast alive messages", Emby appears on my smart tv. It still freeze my tv when I select it. I even saw in the log that emby create a profile with the friendly name of my tv.It may be a profile problem finally. What do you think ?
Happy2Play 9811 Posted November 4, 2019 Posted November 4, 2019 I would think the profile would only affect playback, but I could be wrong. What happens if you try the profile in post 33? https://emby.media/community/index.php?/topic/34597-philips-tv-not-appearing-in-the-device-list-and-no-dlna-access/?p=332454 Can you post a server log after trying that profile.
Guest Posted November 5, 2019 Posted November 5, 2019 (edited) I would think the profile would only affect playback, but I could be wrong. What happens if you try the profile in post 33? https://emby.media/community/index.php?/topic/34597-philips-tv-not-appearing-in-the-device-list-and-no-dlna-access/?p=332454 Can you post a server log after trying that profile. Hello, The problem remains the same. Here is my log file. embyserver.txt Edited November 5, 2019 by aldoemby
Happy2Play 9811 Posted November 5, 2019 Posted November 5, 2019 The Philips TV profiles is not used at all do to different user-agents. 2019-11-05 08:06:10.886 Info HttpServer: HTTP GET http://192.168.11.47:8096/dlna/25a30dc01ea34102906b7941a59ef620/description.xml. UserAgent: IPI/1.0 UPnP/1.0 DLNADOC/1.50 2019-11-05 08:06:10.921 Debug Dlna: No matching device profile found. HOST=192.168.11.47:8096, DATE=Tue, 05 Nov 2019 07:06:09 GMT, CONNECTION=Keep-Alive, USER-AGENT=IPI/1.0 UPnP/1.0 DLNADOC/1.50 Can you go to DLNA-Profiles and select the Philips TV custom profile. Scroll down and expand Identification, then go to HTTP Headers and add another. Name: User-Agent Value: IPI Match type: Substring Cilck OK then save. Don't think you need to but restart Emby. Does that make any difference. Post another server log.
Guest Posted November 5, 2019 Posted November 5, 2019 The Philips TV profiles is not used at all do to different user-agents. 2019-11-05 08:06:10.886 Info HttpServer: HTTP GET http://192.168.11.47:8096/dlna/25a30dc01ea34102906b7941a59ef620/description.xml. UserAgent: IPI/1.0 UPnP/1.0 DLNADOC/1.50 2019-11-05 08:06:10.921 Debug Dlna: No matching device profile found. HOST=192.168.11.47:8096, DATE=Tue, 05 Nov 2019 07:06:09 GMT, CONNECTION=Keep-Alive, USER-AGENT=IPI/1.0 UPnP/1.0 DLNADOC/1.50 Can you go to DLNA-Profiles and select the Philips TV custom profile. Scroll down and expand Identification, then go to HTTP Headers and add another. Name: User-Agent Value: IPI Match type: Substring Cilck OK then save. Don't think you need to but restart Emby. Does that make any difference. Post another server log. I did what you asked me to do: the profile is used but Emby still freezes my TV. I don't know if it helps but Plex DLNA and OMV MiniDLNA works too. embyserver.txt
Guest Posted November 10, 2019 Posted November 10, 2019 Well, I may think that there's no solution for the philips smart tv problem...
josch.hh 2 Posted November 10, 2019 Author Posted November 10, 2019 I guess you realized that emby is the only so call server with dlna function which is not working with philips and i think also not with other android tvs. Other tvs only run by trail and error coding. Lukes argument is that he needs to physically own such a tv to record the traffic and to customize emby to be able to talk to such tvs. Mega lol. Please read all the posting in this thread and you will see. ;-) Use any other DLNA server -> because ALL others are working, even the intel upnp toolkit! The most funny think is that Luke simply ignores that fact that emby is NOT upnp/dlna compatible.
Guest Posted November 11, 2019 Posted November 11, 2019 (edited) Luke, I'm ok to be a beta tester if you need one. We could talk about this by MP if it's ok with you. Edited November 11, 2019 by aldoemby
Guest Posted December 22, 2019 Posted December 22, 2019 Hi, First of all, you need to know that I wanted the device I took for few things. I've found a plan B: I bought a Nvidia Shield TV. Emby works very good on it. Except sometimes I have to run it twice because the first time I get a black screen. I use MX Player with it cause when Emby detects that the codec doen't exist, it has to transcode but my server is not powerful enough for that so the video freezes all the time. But the Shield works fine with MX (I think that it's an Emby player problem that should work as MX Player). It's sad to use a plan B for something I paid but I didn't find another way...
Techie-v2 2 Posted November 21, 2020 Posted November 21, 2020 Hi, Just to update, have just got a philips 50PUS8555 and I am experiencing the constant loading symbol. The emby server is showing in the device list but when selecting it I just get the loading wheel and nothing else. Emby version 4.5.2.0 Happy to do some testing. Thanks
Luke 42237 Posted November 21, 2020 Posted November 21, 2020 6 hours ago, Techie-v2 said: Hi, Just to update, have just got a philips 50PUS8555 and I am experiencing the constant loading symbol. The emby server is showing in the device list but when selecting it I just get the loading wheel and nothing else. Emby version 4.5.2.0 Happy to do some testing. Thanks Hi, it could be related to certain content. You could try setting up a test emby server with only one library using content type home videos, and have this library contain only a single mp4 video file. See if it works with something basic like that. Thanks.
Luke 42237 Posted February 13, 2021 Posted February 13, 2021 Hi, would you mind trying Emby Server 4.6+ (as of today in beta), combined with the 1.0.45 Dlna plugin update(or greater)? Please let us know if this helps. Thanks !
Techie-v2 2 Posted November 29, 2021 Posted November 29, 2021 On 13/02/2021 at 22:06, Luke said: Hi, would you mind trying Emby Server 4.6+ (as of today in beta), combined with the 1.0.45 Dlna plugin update(or greater)? Please let us know if this helps. Thanks ! Hi, Have just tried again on version 4.6.7.0 with dlna version 1.0.69.0 and it still doesn't work for me. My Emby Server shows up in the list of available sources when I browse media on the TV but I still just get a spinning loading wheel when I select it. Dlna works fine on my LG TV just not the Phillip's one. Happy to provide logs if needed. Thanks for looking into this.
Luke 42237 Posted November 30, 2021 Posted November 30, 2021 20 hours ago, Techie-v2 said: Hi, Have just tried again on version 4.6.7.0 with dlna version 1.0.69.0 and it still doesn't work for me. My Emby Server shows up in the list of available sources when I browse media on the TV but I still just get a spinning loading wheel when I select it. Dlna works fine on my LG TV just not the Phillip's one. Happy to provide logs if needed. Thanks for looking into this. Can you please attach the emby server log from when you tried to do that? Thanks.
Techie-v2 2 Posted November 6, 2022 Posted November 6, 2022 Hi, So to revive a year old post. Tried again yesterday after updating to lasted version and still no joy. Log file attached. Let me know if you spot anything or need anything else? Thanks embyserver.txt
Luke 42237 Posted November 6, 2022 Posted November 6, 2022 8 hours ago, Techie-v2 said: Hi, So to revive a year old post. Tried again yesterday after updating to lasted version and still no joy. Log file attached. Let me know if you spot anything or need anything else? Thanks embyserver.txt 88.96 kB · 0 downloads The Philips still sees the server, right?
Techie-v2 2 Posted November 6, 2022 Posted November 6, 2022 Yeah as stated before, the server comes up in the list of sources, but just a spinning loading wheel.......as attached Before you turn emby on, the option on the tv is called "Simply Share" -don't know if that's just what philips called their dlna access option Thanks 1
