Lee 212 Posted May 9, 2016 Posted May 9, 2016 server update fixed this for me.. theatre keeps loosing remote focus now tho
Luke 42242 Posted May 9, 2016 Posted May 9, 2016 The server update has no effect on this. if you still see the problem, make sure to read this thread.
Lee 212 Posted May 9, 2016 Posted May 9, 2016 The server update has no effect on this. if you still see the problem, make sure to read this thread. it did though? maybe my issue was different and something was stuck??, I also had crashes in web browser trying to play video but now all is ok.. remote loss is still an issue, mostly occurs after playing video or going back in the menus.
jsbarde 10 Posted May 12, 2016 Posted May 12, 2016 Thanks. Can you please perform one more test. please change line 230 from var url = 'http://mediabrowser.github.io/Emby.Web/index.html'; to var url = 'http://tv.emby.media/index.html'; Then try running the app and see if it makes the difference. thanks. I had the same problem today and this fixed it. Thanks Luke!
