CBers 7554 Posted May 5, 2016 Posted May 5, 2016 I've just purchased a HDHomeRun Connect and having issues getting all channels recognised in Emby, If I use the HDHomeRun app on my Shield TV or the HDHomeRun plugin in Kodi, then all the channels show up, including the channel icons. I have checked the server log after re-running the Guide Refresh and there are no errors, it's just not fetching everything. Anyone got UK OTA channels to show correctly in Emby please ??
Latchmor 584 Posted May 5, 2016 Posted May 5, 2016 I've just purchased a HDHomeRun Connect and having issues getting all channels recognised in Emby, If I use the HDHomeRun app on my Shield TV or the HDHomeRun plugin in Kodi, then all the channels show up, including the channel icons. I have checked the server log after re-running the Guide Refresh and there are no errors, it's just not fetching everything. Anyone got UK OTA channels to show correctly in Emby please ?? Yip. One thing I'll check with you first because I've seen others with the problem - Are you entering full post code because you just need the first part. AB12 only, no need for AB12 3CD...?
CBers 7554 Posted May 5, 2016 Author Posted May 5, 2016 Yip. One thing I'll check with you first because I've seen others with the problem - Are you entering full post code because you just need the first part. AB12 only, no need for AB12 3CD...? I think I entered the full postcode. Can I change it in? Where do I do that, SD, Emby or the actual HDHomeRun?
Latchmor 584 Posted May 5, 2016 Posted May 5, 2016 I think I entered the full postcode. Can I change it in? Where do I do that, SD, Emby or the actual HDHomeRun? Emby 1
CBers 7554 Posted May 5, 2016 Author Posted May 5, 2016 Thanks. So I'll need your remove the HDHomeRun and re-add? There's one EDIT option?
Latchmor 584 Posted May 5, 2016 Posted May 5, 2016 Thanks. So I'll need your remove the HDHomeRun and re-add? There's one EDIT option? I think I removed the SD Provider from Emby and started from scratch after I realised the Post Code issue. Just to start fresh.
CBers 7554 Posted May 5, 2016 Author Posted May 5, 2016 OK, thanks. I'll have a play. I'm also in communication with one of the techies at SD, so there might be something they can suggest to help out Emby.
maegibbons 1287 Posted December 8, 2016 Posted December 8, 2016 (edited) Sorry to Hi-jack this thread but very related. Trying to set this up now. When i enter the postcode, 2 digits or 4, even tried AB12 above, i am NOT offered the Freeview lineup only BSkyB and Freesat? Any clues? KR's Mark Edited December 8, 2016 by maegibbons
CBers 7554 Posted December 8, 2016 Author Posted December 8, 2016 Sorry to Hi-jack this thread but very related. Trying to set this up now. When i enter the postcode, 2 digits or 4, even tried AB12 above, i am NOT offered the Freeview lineup on BSkyB and Freesat? Any clues? KR's Mark You should be able to put your full postcode in, with and/or without a space.
maegibbons 1287 Posted December 8, 2016 Posted December 8, 2016 Hi Well I contacted SD support as I looked at the data using xmltv json grabber and freeview wasnt listed there either. They told me to use Youview which is a superset apparently. Krs Mark
Latchmor 584 Posted December 8, 2016 Posted December 8, 2016 Hi Well I contacted SD support as I looked at the data using xmltv json grabber and freeview wasnt listed there either. They told me to use Youview which is a superset apparently. Krs Mark Just checked my lineup which was set as Freeview months ago. It now says YouView, no idea when it changed but it's working fine. Cheers
maegibbons 1287 Posted December 12, 2016 Posted December 12, 2016 (edited) Hi @@Latchmor Is channel 4 data coming through for you? Krs Mark Edited December 12, 2016 by maegibbons
Latchmor 584 Posted December 12, 2016 Posted December 12, 2016 Hi @@Latchmor Is channel 4 data coming through for you? Krs Mark Yeah, 4 and 104 (HD).
