RedBaron164 18 Posted May 5, 2016 Posted May 5, 2016 I enabled the 3D Indicator Overlay in CoverArt 4.0 but it doesn't actually show up on any of my 3D movies. The other Indicator overlay options, like Resolution and Audio do show up properly. How does CoverArt determine if the movie is 3D or not? I'm assuming that the system is just not currently able to distinguish between my 3D and non-3D movies since they are all just mkv's. Does it rely on a certain extension or an indicator in the file name? I have all my 3D films in one folder which is called 3D.
Solution ebr 16340 Posted May 5, 2016 Solution Posted May 5, 2016 You need to tag them as such to the system. https://github.com/MediaBrowser/Wiki/wiki/3D%20videos 1
RedBaron164 18 Posted May 5, 2016 Author Posted May 5, 2016 (edited) Thank you, forgot about the Wiki Edited May 5, 2016 by RedBaron164
