solabc16 379 Posted May 3, 2016 Posted May 3, 2016 (edited) Evening I've seen a few notes kicking around on this, here's a set of steps that will work with the new permissions model and avoid the need for WinSCP. As I said somewhere else, it's good to see Synology are following one of the best practices we'd normally advocate for *nix systems. - SSH to your Synology box and login as 'admin'. - Switch to root with 'sudo -i'. - Remove any existing downloads, e.g. 'rm Emby.Mono.zip*' - Grab the latest server release, e.g. 'wget https://github.com/MediaBrowser/Emby/releases/download/3.0.5934/Emby.Mono.zip'. - Stop Emby, using 'stop pkgctl-emby'. - Extract the updated files, assuming default location, with '7z x Emby.Mono.zip -o/volume1/@appstore/emby/share/emby -y'. - Start Emby, using 'start pkgctl-emby'. EDIT (removed): - Update package with version number, e.g. "sed -i.bak 's/\(^version="\)[^"]*\("$\)/\1v3\.0\.5934\.0\2/' /var/packages/emby/INFO". Here's a worked example for today's v3.0.5934 update:- login as: admin admin@192.168.236.105's password: admin@JFK:~$ sudo -i Password: root@JFK:~# wget https://github.com/MediaBrowser/Emby/releases/download/3.0.5934/Emby.Mono.zip [output removed] Saving to: 'Emby.Mono.zip.1' 100%[==============================================================================>] 17,718,901 5.19MB/s in 3.9s 2016-05-03 22:00:15 (4.35 MB/s) - 'Emby.Mono.zip.1' saved [17718901/17718901] root@JFK:~# stop pkgctl-emby pkgctl-emby stop/waiting root@JFK:~# 7z x Emby.Mono.zip -o/volume1/@appstore/emby/share/emby -y [output removed] Everything is Ok Folders: 568 Files: 3388 Size: 49421341 Compressed: 17718901 root@JFK:~# start pkgctl-emby pkgctl-emby start/running root@JFK:~# If you have ISO format media files in your media collection, then please refer to http://emby.media/community/index.php?/topic/28187-mbt-not-mounting-iso-when-pointing-at-synology-based-server/?p=328805 for an additional step you will need to take. - James Edited July 29, 2016 by solabc16 2
solabc16 379 Posted May 7, 2016 Author Posted May 7, 2016 Afternoon, a couple of tweaks to the above to make the instructions clearer, following feedback from @@KRULL.
solabc16 379 Posted May 8, 2016 Author Posted May 8, 2016 Evening Instructions updated to also include updating the version number, as seen in the package center UI. e.g. Before After - James
solabc16 379 Posted May 12, 2016 Author Posted May 12, 2016 Instructions updated to include additional step required if you have ISO files in your media collection. - James
Bjorr 2 Posted May 16, 2016 Posted May 16, 2016 Thank you for this guide! works great on my Synology NAS DS415+
solabc16 379 Posted May 16, 2016 Author Posted May 16, 2016 Thanks @@Bjorr for the feedback and well done on getting your system updated. - James
cytec 11 Posted May 19, 2016 Posted May 19, 2016 Please DONT update the version in /var/packages/emby/INFO that'll eventually break your ability to update to newer synocommunity packages :/
solabc16 379 Posted May 19, 2016 Author Posted May 19, 2016 Morning @@cytec That's not strictly true. The Emby binaries are already being updated manually by the user, as part of the current update process for the Synology platform. This has been the situation for some time, so the package version is unlikely to reflect the actually installed version of the software. Updating the version number will simply prevent an unexpected rollback for those keeping their Emby binaries up-to-date, should another package appear with a different set of earlier Emby binaries. The package version reflects the version of Emby binaries, so if it is genuinely newer then it will still be applied. - James
cytec 11 Posted May 19, 2016 Posted May 19, 2016 @@solabc16 you should at least hint the users that they are changing stuff in a more or less closed environment. IF there will be a new Package it doesn't mean you'll automatically update to it. there are a few things that have to be true for Synology to consider it the Same package.... same name, higher version number etc. that's one reason why synocommunity appends an ongoing Revision at the end of the version.
solabc16 379 Posted May 19, 2016 Author Posted May 19, 2016 Afternoon @cytec I do understand your point, but we're not at that juncture right now. The update process for users, once they have an initial version installed, is entirely manual via the shell. This in itself breaks the notion of a closed loop environment, but is what we have right now and what we now working on addressing so we can deliver the best Emby experience to the Synology user base. The Emby builds have consistent and reliable release versioning, so it makes sense to take advantage of this and keep the package versioning consistent rather than introduce an additional variable. - James
solabc16 379 Posted May 29, 2016 Author Posted May 29, 2016 Evening Instructions at the top of this page (http://emby.media/community/index.php?/topic/34516-updating-emby-on-dsm6-systems/?p=326672) updated to deal with any previous downloads. Thanks to @@Darkjeje for the feedback. - James
Luke 42239 Posted July 28, 2016 Posted July 28, 2016 We have a new installation procedure for Synology users. It's very easy and is now on our website: http://emby.media/nas-server.html All Synology users are recommended to use this going forward (if your model supports it).
bvanaerde 0 Posted August 29, 2016 Posted August 29, 2016 (edited) All Synology users are recommended to use this going forward (if your model supports it). Thanks for the heads up! Will it be possible to update an existing version (which was installed and updated manually) with this new package, or do we need to remove the previous version prior to installing it? Edited August 29, 2016 by bvanaerde
solabc16 379 Posted August 29, 2016 Author Posted August 29, 2016 (edited) Hello @@bvanaerde You can install the Emby version of the Synology package in parallel, then migrate your configuration, should you choose to do so. The only caveat is that you can't run them both at the same time, as they will both try and listen on the same network ports by default. There's an article on the Wiki here on how to migrate: https://github.com/MediaBrowser/Wiki/wiki/Synology-:-Migrating-From-the-Community-Package What Synology model do you have? Best - James Edited August 29, 2016 by solabc16
bvanaerde 0 Posted August 29, 2016 Posted August 29, 2016 Great, there's even a wiki for migrating. I must have missed this somehow. Will try it out shortly. I'm using a Synology DS1515+
solabc16 379 Posted August 29, 2016 Author Posted August 29, 2016 For reference, the Emby package is completely self-contained and has no dependencies. It's up to you what you do with the existing installation/dependencies once you've migrated. Let us know how you get on @@bvanaerde. - James
bvanaerde 0 Posted August 29, 2016 Posted August 29, 2016 (edited) The migration went smooth! It's still doing the "clean database" task (probably because of the version update), but everything seems to be in place. ******************************************************************************** Script invoked as [./pkgmigrate] by [root]. File Version : 3.0.6300.0-1 ******************************************************************************** This script will migrate your existing Emby Server configuration to the Emby LLC version of the package. PLEASE ONLY USE AS DIRECTED BY SUPPORT WARNING: Any existing configuration under your Emby LLC package installation will be overwritten. Type [yes] and press return to continue: yes Have you granted the user [embysvr] read/write access to your media libraries? Do this by editing the folder permissions under [Control Panel->Shared Folder] Type [yes] and press return to continue: yes Making sure Emby Server is not running... DONE Validating directories... >> Source: [/var/packages/emby/target/var] >> Validating source: OK >> Target: [/var/packages/EmbyServer/target/var] >> Validating target: OK DONE Getting target volume... >> Canonical path is: [/volume1/@appstore/EmbyServer/var] >> Target volume is : [/volume1] DONE Backing up existing target... >> Directory size is 2.5M >> Filename [/volume1/EmbyServer_PreMigration_20160829T224336UTC.tgz] >> Backup size is 192K DONE Migrating user data... >> Removing existing target [/var/packages/EmbyServer/target/var/] >> Transferring data to [/var/packages/EmbyServer/target/var/] >> Recursively setting file and directory ownership. DONE Updating database... >> Updating [data] column in [TypedBaseItems]. >> Updating [Path] column in [TypedBaseItems]. DONE Starting Emby Server... DONE ******************************************************************************** Your user data has been migrated succesfully. A backup of the original Emby LLC package data can be found at the location detailed above in TGZ format. Please refer to the section 'Backing up existing target...'. ******************************************************************************** And... it's already updating to 3.0.6400.0-1. Great! Edited August 29, 2016 by bvanaerde
solabc16 379 Posted August 29, 2016 Author Posted August 29, 2016 Thanks for the feedback @@bvanaerde, pleased to hear all went smoothly. Enjoy! - James
