Auto-Organize not recognizing a show
Go to solution Solved by icthusman1,
icthusman1
I ripped and added to my collection last night "Frank Herbert's Dune (2000)". My TV collection in Emby shows the show, has data for it, shows the Season 01 I have.
However, when I try and use auto-organize to rename the files and get them into the folder on the server, auto-organize does not show this as an option. So the files fail. Manual matching does not work either.
As you can see, the show is not listed in here. Looking at the data for the show, it looks like it is being recognized as a TV Show and not a movie. I have been trying over the last 12 hours to get this working and nothing has changed. The nightly library scan also ran in-between when I first tried and my submitting this.
What can I do to get this working?
Currently running Emby Beta Version 3.0.5946.22772. Which is another issue I reported elsewhere that my server started downloading beta versions and won't stop.
  • Solution
icthusman1
Welp, guess I am blind. I see now that the show is showing as Dune in the series list but Frank Herbert's Dune when viewing media.
