Fuego 0 Posted May 3, 2016 Posted May 3, 2016 Recently, I found out that a couple of shows are not appearing in their folder any more. They are there on the hard drive and I can play them. I have copies of each episode. One in wtv and the other in a converted mp4. I am fairly confident there is no file issue. These used to appear just fine, but after one of the updates (not sure which one as this wasn't watched for a while), it prevented it from being listed. The folder is there, but it says it is empty. I just had this thought on my way to work this morning, but I don't think the files are named properly. Ie, 5x01 - Episode Name.mp4 or s05e01 - Episode Name.mp4. They are still in the format when recorded from WMC. This used to work and we could watch based off of air date. I can provide current server version when I get home. Hoping this is a simple issue. Thanks!
ebr 16307 Posted May 3, 2016 Posted May 3, 2016 We'll need to see the exact layout of the file system (screen shots) and how you have the library configured.
Fuego 0 Posted May 3, 2016 Author Posted May 3, 2016 Thanks ebr! When I get home, I will get you screenshots of my Library (Emby Server perspective) and file system (several layers). Do you actually need screenshots of the file system or can I just provide a text listing?
