popy 73 Posted April 2, 2018 Posted April 2, 2018 Yep, it seems so. Who can give some love to the plugin? [emoji4] Gesendet von meinem LG-H815 mit Tapatalk
rechner123 12 Posted April 2, 2018 Posted April 2, 2018 I once had a similar problem with deleting the timer. For me it helped to delete all the timers in the rs directly. after that also the delete in emby worked.
pünktchen 1411 Posted April 2, 2018 Author Posted April 2, 2018 Yep, it seems so. Who can give some love to the plugin? [emoji4] Gesendet von meinem LG-H815 mit Tapatalk Don't stress me. It's ready when it's ready.But then you'll get big eyes! 1
popy 73 Posted April 2, 2018 Posted April 2, 2018 I once had a similar problem with deleting the timer. For me it helped to delete all the timers in the rs directly. after that also the delete in emby worked. thx for the hint, tried it but the issue persits. I'll deleted all the timers and "Suchvorgaben" in DMS, and created a new one through emby. Sadly i cant delete the "Suchvorgabe" with emby than. Don't stress me. It's ready when it's ready. But then you'll get big eyes! No problem, i didnt want to stress you. Just want to know if you are working on the addon, since you often wrote that you are using MP yourself No big deal, take your time. pOpY
pünktchen 1411 Posted April 5, 2018 Author Posted April 5, 2018 Just a little teaser from the MediaPortal plugin: 2
popy 73 Posted April 6, 2018 Posted April 6, 2018 Just a little teaser from the MediaPortal plugin: Nice! Looking forward to an DVBV plugin update
Kodi_Newcomer 27 Posted April 9, 2018 Posted April 9, 2018 That sounds great. I hope this works good with dvbv. Keep up the good Work.
Kodi_Newcomer 27 Posted April 11, 2018 Posted April 11, 2018 Where can i load the newest version from your plugin, when i understand it right not from the emby catalog ?
pünktchen 1411 Posted April 11, 2018 Author Posted April 11, 2018 Where can i load the newest version from your plugin, when i understand it right not from the emby catalog ?If you mean the one with those special recording features, it's not ready yet.
Kodi_Newcomer 27 Posted April 11, 2018 Posted April 11, 2018 No i know. The last one how can be downloaded.
pünktchen 1411 Posted April 11, 2018 Author Posted April 11, 2018 (edited) No i know. The last one how can be downloaded. https://emby.media/community/index.php?/topic/34417-DVBViewer-Live-TV-Plugin&do=findComment&comment=562169 Edited April 11, 2018 by pünktchen
pünktchen 1411 Posted April 23, 2018 Author Posted April 23, 2018 Any of you guys running the Emby beta server?
Kodi_Newcomer 27 Posted April 24, 2018 Posted April 24, 2018 Hm i run Version 3.3.1.0 So i think i do not run the beta server.
popy 73 Posted April 24, 2018 Posted April 24, 2018 Also running latest stable, because I must have a high WAF [emoji3] Do I smell an update of the plugin? I can test it on the latest stable, if it runs on that? pOpY Gesendet von meinem LG-H815 mit Tapatalk
pünktchen 1411 Posted April 24, 2018 Author Posted April 24, 2018 No it runs only with beta server onwards, so you'll have to wait for the next stable release. Hopefully there aren't to many bugs in my plugin then [emoji6] 1
popy 73 Posted April 25, 2018 Posted April 25, 2018 No it runs only with beta server onwards, so you'll have to wait for the next stable release. Hopefully there aren't to many bugs in my plugin then [emoji6]Thx a lot for your efforts! I will test it on the next stable of emby and report back. Gesendet von meinem LG-H815 mit Tapatalk
Kodi_Newcomer 27 Posted April 26, 2018 Posted April 26, 2018 Can i install the beta over the stable ? So i can help you to test the plugin. I can make a backup from the system and look how it works. I think this is what you want, testers, because you ask for beta use ?
Luke 42245 Posted April 26, 2018 Posted April 26, 2018 For now, you would need the beta server in order to use the updated plugin.
Kodi_Newcomer 27 Posted April 26, 2018 Posted April 26, 2018 For now, you would need the beta server in order to use the updated plugin. Yes i know, but my quest was, if i can install the beta server over the stable rls ? Or must i uninstall the stable and install the beta ? Or can i run both ?
Kodi_Newcomer 27 Posted April 27, 2018 Posted April 27, 2018 You can install over the top, yes. Is this the right one ? Emby.Mono.zip ?
Luke 42245 Posted April 27, 2018 Posted April 27, 2018 Please follow the instructions on our website: https://emby.media/download If a beta release is available for your platform, it will be listed there. Thanks.
rechner123 12 Posted May 4, 2018 Posted May 4, 2018 (edited) Hi I have updated emby to 3.4.0.0 and the plugin automatic updatet himself to 1.5.4. Now the plugin does not work anymore for me. I can not choose a channel group and guide refresh is finish in few seconds. So Live Tv channels are available. tried a rollback to previous emby, but did also not work anymore. tried uninstalling plugin, clear cache from emby and browser, installed new DMS 2.1 embyserver.txt Edited May 4, 2018 by rechner123
Luke 42245 Posted May 5, 2018 Posted May 5, 2018 Hi I have updated emby to 3.4.0.0 and the plugin automatic updatet himself to 1.5.4. Now the plugin does not work anymore for me. I can not choose a channel group and guide refresh is finish in few seconds. So Live Tv channels are available. tried a rollback to previous emby, but did also not work anymore. tried uninstalling plugin, clear cache from emby and browser, installed new DMS 2.1 Looks like some DVB urls are returning 404 not found. @@pünktchen may have an idea about this. 2018-05-05 01:30:10.685 Info HttpClient: GET http://192.168.0.14:8090/api/getchannelsxml.html?root=&logo=1 2018-05-05 01:30:10.688 Error HttpClient: 2018-05-05 01:30:10.709 Error App: Error refreshing channels for service *** Error Report *** Version: 3.4.0.0 Command line: C:\Users\STREAMER\AppData\Roaming\Emby-Server\system\EmbyServer.dll C:\Users\STREAMER\AppData\Roaming\Emby-Server\system\EmbyServer.dll C:\Users\STREAMER\AppData\Roaming\Emby-Server\system\EmbyServer.dll -noautorunwebapp Operating system: Microsoft Windows NT 6.2.9200.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 4 Program data path: C:\Users\STREAMER\AppData\Roaming\Emby-Server Application directory: C:\Users\STREAMER\AppData\Roaming\Emby-Server\system System.AggregateException: One or more errors occurred. (NotFound) ---> MediaBrowser.Model.Net.HttpException: NotFound
pünktchen 1411 Posted May 5, 2018 Author Posted May 5, 2018 No idea, it's working fine here. Maybe the Windows firewall got reset after some update?
