rechner123 12 Posted February 26, 2018 Posted February 26, 2018 I updated the plugin and now it looks like in the picture.
pünktchen 1411 Posted February 26, 2018 Author Posted February 26, 2018 At least umlauts are working now I don't know if i can solve this. The problem is with the RecordingService. http://127.0.0.1:8089/api/getconfigfile.html?file=config%5Csearches.xml delivers the file with its original utf-8 encoding, while http://127.0.0.1:8089/api/timerlist.html?utf8=2 delivers the file with human readable iso encoding. I've tried to double decode the searches.xml strings, but as you can see it isn't working in every case. @@Luke any idea?
Luke 42245 Posted February 26, 2018 Posted February 26, 2018 I'm not yet sure. I have not been able to look at it yet.
pünktchen 1411 Posted February 26, 2018 Author Posted February 26, 2018 @rechner123 give this one a try: 1
rechner123 12 Posted February 26, 2018 Posted February 26, 2018 Thank you pünktchen! Series name is now correct in emby and RS. I will try later if recording is working.
rechner123 12 Posted February 27, 2018 Posted February 27, 2018 So now i had time to try. Timer programing now work with correct title in emby and RS. But in RS, the timer is disabled and so not under shedule in emby. If i go to RS and enable the timer, then in emby it will show also in shedule.
pünktchen 1411 Posted February 27, 2018 Author Posted February 27, 2018 So now i had time to try. Timer programing now work with correct title in emby and RS. But in RS, the timer is disabled and so not under shedule in emby. If i go to RS and enable the timer, then in emby it will show also in shedule. I don't understand. You'd like to see disabled timers also in Emby or the timer is disabled although it should not?
rechner123 12 Posted February 27, 2018 Posted February 27, 2018 Sorry Wenn bei der Sendung "Die größten Konstruktionsfehler der Welt" eine Serienaufnahme in Emby programmiere, wird diese unter Serien auch angezeigt. Unter shedule jedoch nicht. Dann habe ich im RS unter den Timern nachgesehen und festgestellt dass diese Deaktiviert sind! Wenn ich den Timer in RS aktiviere, ist er auch in Emby unter shedule vorhanden.
pünktchen 1411 Posted February 27, 2018 Author Posted February 27, 2018 Okay, but it's the RS that disables the timers depending on the settings of the "Auto-EPG-Suche". You can control the defaults that prevent a recording from within the plugin settings (existing timer, existing recording...) or you can disable this alltogether for an existing series schedule in Emby by unchecking "Don't record episodes that are already in my library".
rechner123 12 Posted February 28, 2018 Posted February 28, 2018 1. Staffel, Folge 6 was not recorded although this was no existing recoding or timer. Now i have deleted all my timers in emby and RS. Reboot system, and now i think it is working. Tried with different series, that have also season and episodes numbers in guide to inspect. Looks good! My server did automatic update to 3.3 For testing this plugin i have done a rollback to 3.2.7 and stuck with it. But have tried also 3.3 and there were not the following info on the dashboard: Can i update to 3.3 or are there known issues? Or should i try it?
pünktchen 1411 Posted February 28, 2018 Author Posted February 28, 2018 I don't know if there are issues with my DVBViewer plugin because i'm using MediaPortal ;-) You can try a seperate portable Emby install for testing https://github.com/MediaBrowser/Emby/releases/tag/3.3.0.0 But you should update to the latest stable release, because 3.2.7 has a bug that can potentially lead to deletion of all tv recordings! The webpage you've captured in your screenshot is out of my control. The info has been removed by the Emby devs. 1
rechner123 12 Posted March 1, 2018 Posted March 1, 2018 I have updated to 3.3 So far everything works as it should. Thank you very much!
rechner123 12 Posted March 29, 2018 Posted March 29, 2018 Hy again! Yesterday i have installed the new DMS, because i want to convert recordings into .mkv files automatically. Now if i go to series, there is a spinning circle, and nothing else. Is something to be considered during installation, or do I have a special problem?
Luke 42245 Posted March 29, 2018 Posted March 29, 2018 Hy again! Yesterday i have installed the new DMS, because i want to convert recordings into .mkv files automatically. Now if i go to series, there is a spinning circle, and nothing else. Is something to be considered during installation, or do I have a special problem? Server log?
pünktchen 1411 Posted March 29, 2018 Author Posted March 29, 2018 Open http://192.168.0.14:3366/api/getconfigfile.html?file=config%5Csearches.xml Is there any entry with either no Starttime or no EndTime? If so, how did you create this search entry?
rechner123 12 Posted March 29, 2018 Posted March 29, 2018 (edited) Start an endtime are present: <!--Created by DVBViewer Media Server: 29.03.2018 20:12:01--><Searches Ver="1"><Search Name="Die gröÃten Konstruktionsfehler der Welt" AutoRecording="-1" AutoRemind="0" IgnoreCase="-1" UseRegEx="0" CheckRecTitle="-1" CheckRecSubTitle="-1" CheckTimer="-1" MonitorPDC="-1" MonitorForStart="0"><EndTime>23:59</EndTime><StartTime>00:00</StartTime><EPGAfter>7</EPGAfter><EPGBefore>5</EPGBefore><Genre>-1</Genre><RecordingFolder>Auto</RecordingFolder><Priority>50</Priority><RecFormat>2</RecFormat><RecNameScheme>%year-%date_%time_%station_%name</RecNameScheme><SearchFields>1</SearchFields><SearchPhrase>^Die gröÃten Konstruktionsfehler der Welt$</SearchPhrase><DurationMin>0</DurationMin><DurationMax>0</DurationMax><Days>127</Days><Series>Die gröÃten Konstruktionsfehler der Welt</Series><Channels><Channel>282046207754370</Channel></Channels></Search><Search Name="Die gröÃten Projekte der Welt" AutoRecording="-1" AutoRemind="0" IgnoreCase="-1" UseRegEx="0" CheckRecTitle="-1" CheckRecSubTitle="-1" CheckTimer="-1" MonitorPDC="-1" MonitorForStart="0"><EndTime>23:59</EndTime><StartTime>00:00</StartTime><EPGAfter>7</EPGAfter><EPGBefore>5</EPGBefore><Genre>-1</Genre><RecordingFolder>Auto</RecordingFolder><Priority>50</Priority><RecFormat>2</RecFormat><RecNameScheme>%year-%date_%time_%station_%name</RecNameScheme><SearchFields>1</SearchFields><SearchPhrase>^Die gröÃten Projekte der Welt$</SearchPhrase><DurationMin>0</DurationMin><DurationMax>0</DurationMax><Days>127</Days><Series>Die gröÃten Projekte der Welt</Series><Channels><Channel>282046207754370</Channel></Channels></Search><Search Name="Die Sendung mit der Maus" AutoRecording="-1" AutoRemind="0" IgnoreCase="-1" UseRegEx="0" CheckRecTitle="0" CheckRecSubTitle="0" CheckTimer="0" MonitorPDC="-1" MonitorForStart="0"><EndTime>23:59</EndTime><StartTime>00:00</StartTime><EPGAfter>7</EPGAfter><EPGBefore>5</EPGBefore><Genre>-1</Genre><RecordingFolder>Auto</RecordingFolder><Priority>50</Priority><RecFormat>2</RecFormat><RecNameScheme>%year-%date_%time_%station_%name</RecNameScheme><SearchFields>1</SearchFields><SearchPhrase>^Die Sendung mit der Maus$</SearchPhrase><DurationMin>0</DurationMin><DurationMax>0</DurationMax><Days>64</Days><Series>Die Sendung mit der Maus</Series><Channels><Channel>281479272016792</Channel></Channels></Search><Search Name="Löwenzahn" AutoRecording="-1" AutoRemind="0" IgnoreCase="-1" UseRegEx="0" CheckRecTitle="-1" CheckRecSubTitle="-1" CheckTimer="-1" MonitorPDC="-1" MonitorForStart="0"><EndTime>12:00</EndTime><StartTime>11:00</StartTime><EPGAfter>10</EPGAfter><EPGBefore>5</EPGBefore><Genre>-1</Genre><RecordingFolder>Auto</RecordingFolder><Priority>50</Priority><RecFormat>2</RecFormat><RecNameScheme>%year-%date_%time_%station_%name</RecNameScheme><SearchFields>1</SearchFields><SearchPhrase>^Löwenzahn$</SearchPhrase><DurationMin>0</DurationMin><DurationMax>0</DurationMax><Days>64</Days><Series>Löwenzahn</Series><Channels><Channel>281479272016792</Channel></Channels></Search><Search Name="So wird's gebaut - Geniale Konstruktionen" AutoRecording="-1" AutoRemind="0" IgnoreCase="-1" UseRegEx="0" CheckRecTitle="-1" CheckRecSubTitle="-1" CheckTimer="-1" MonitorPDC="-1" MonitorForStart="0"><EndTime>23:59</EndTime><StartTime>00:00</StartTime><EPGAfter>5</EPGAfter><EPGBefore>3</EPGBefore><Genre>-1</Genre><RecordingFolder>Auto</RecordingFolder><Priority>50</Priority><RecFormat>2</RecFormat><RecNameScheme>%year-%date_%time_%station_%name</RecNameScheme><SearchFields>1</SearchFields><SearchPhrase>^So wird?s gebaut ? Geniale Konstruktionen$</SearchPhrase><DurationMin>0</DurationMin><DurationMax>0</DurationMax><Days>127</Days><Series>So wird's gebaut - Geniale Konstruktionen</Series><Channels><Channel>282046207623182</Channel></Channels></Search><Search Name="So wird's gemacht!" AutoRecording="-1" AutoRemind="0" IgnoreCase="-1" UseRegEx="0" CheckRecTitle="-1" CheckRecSubTitle="-1" CheckTimer="-1" MonitorPDC="-1" MonitorForStart="0"><EndTime>23:59</EndTime><StartTime>00:00</StartTime><EPGAfter>7</EPGAfter><EPGBefore>5</EPGBefore><Genre>-1</Genre><RecordingFolder>Auto</RecordingFolder><Priority>50</Priority><RecFormat>2</RecFormat><RecNameScheme>%year-%date_%time_%station_%name</RecNameScheme><SearchFields>1</SearchFields><SearchPhrase>^So wird?s gemacht!$</SearchPhrase><DurationMin>0</DurationMin><DurationMax>0</DurationMax><Days>127</Days><Series>So wird's gemacht!</Series><AfterProcessAction>Generate MKV</AfterProcessAction><Channels><Channel>282046207754370</Channel></Channels></Search></Searches> Edited March 29, 2018 by rechner123
pünktchen 1411 Posted March 29, 2018 Author Posted March 29, 2018 Ah, i see. I'm still on DMS 2.0.3.0 and there it is "Starttime" and not StartTime"! Try this one: 1
rechner123 12 Posted March 29, 2018 Posted March 29, 2018 Ah, i see. I'm still on DMS 2.0.3.0 and there it is "Starttime" and not StartTime"! Try this one: MediaBrowser.Plugins.DVBViewer.zip Thank you so much. it works again!
popy 73 Posted April 1, 2018 Posted April 1, 2018 (edited) @pünktchen: i want to use your plugin because i have switched from MP to DMS 2.0.4.0. My main frontend is kodi, which has now really really fast switching times compared to MP. Sadly i have some issues with this Emby (running Version 3.2.70.0) plugin. 1) When ill go to Plugins -> DVBViewer TV Plugin -> i have entered the connection settings once. In Emby ill also see some EPG, channels, recordings but when ill visit the site again to configure the channel groups they are empty. Also when i'll open the page without clicking anything, there is the spinning circle. I cant gat the channel groups to shows up correctly in the combo box. Connection to two kodi clients is ok, so should be no DMS issue. Any hints? 2) Another issue are the channel logos, during my setup i have changed the logo folder in the DMS directory. To take effect i had to delete the cache and Thumbnails directory from kodi (there was a mixing of newer and older logos because of caching). My assumption is that emby has the same "issue". Previously i had the MP plugin running in emby before switching to the DVBV plugin, maybe from there are some cached icons? How can i'll delete the cache of the DVBV plugin so that it loads the newer logos? 3) should i'll use the above version because i have also DMS 2.0.4.0? PS.: Debug log attached thx pOpY Log.txt Edited April 1, 2018 by popy
Luke 42245 Posted April 1, 2018 Posted April 1, 2018 I would suggest updating to the latest version of emby server.
popy 73 Posted April 1, 2018 Posted April 1, 2018 (edited) DOne, now i am on 3.3.1.0, issues persists. Here is the spinning cirlce: DMS settings: The Option "Passwort auch für LAN/WLAN" (password also for LAN/WLAN) is not activated, also my kodi clients can connect without any authentification. Also when ill opening http://192.168.0.5:8089 no authentification is requiered. Any suggestions? Edited April 1, 2018 by popy
popy 73 Posted April 1, 2018 Posted April 1, 2018 (edited) Have now stopped emby, removed the plugin, started emby, refreshed guide button in dashboard settings, let it run a few minutes, stopped emby again, installed the new proved plugin from above, set it up and same issue again. This time all my EPG, channels, recordings, are gone from emby. Now there is something interresting in the log: 2018-04-01 21:20:39.781 Info TaskManager: Executing Refresh Guide2018-04-01 21:20:39.781 Info HttpServer: HTTP Response 204 to 192.168.0.254. Time: 1ms. http://dintis.duckdns.org:8096/emby/ScheduledTasks/Running/3145e441d9ba27fc391e7ee15face5812018-04-01 21:20:39.785 Info HttpServer: HTTP GET http://dintis.duckdns.org:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/65.0.3325.181 Safari/537.36 2018-04-01 21:20:39.786 Info HttpServer: HTTP Response 200 to 192.168.0.254. Time: 1ms. http://dintis.duckdns.org:8096/emby/ScheduledTasks?IsEnabled=true2018-04-01 21:20:42.103 Debug App: ScheduledTasksWebSocketListener stop transmitting over websocket to [::ffff:192.168.0.254]:501272018-04-01 21:20:42.107 Info HttpServer: HTTP GET http://dintis.duckdns.org:8096/emby/System/Logs. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/65.0.3325.181 Safari/537.36 2018-04-01 21:20:42.107 Info HttpServer: HTTP GET http://dintis.duckdns.org:8096/emby/System/Configuration. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/65.0.3325.181 Safari/537.36 2018-04-01 21:20:42.120 Info HttpServer: HTTP Response 200 to 192.168.0.254. Time: 13ms. http://dintis.duckdns.org:8096/emby/System/Logs2018-04-01 21:20:42.141 Info HttpServer: HTTP Response 200 to 192.168.0.254. Time: 34ms. http://dintis.duckdns.org:8096/emby/System/Configuration2018-04-01 21:20:43.065 Debug App: Refreshing guide from DVBViewer (Recording Service)2018-04-01 21:20:43.065 Info HttpClient: GET http://192.168.0.5:8089/api/getchannelsxml.html?favonly=1&logo=12018-04-01 21:20:43.072 Error App: Error refreshing channels for service *** Error Report *** Version: 3.3.1.0 Command line: C:\Users\whs_admin\AppData\Roaming\Emby-Server\system\EmbyServer.dll -service Operating system: Microsoft Windows NT 6.2.9200.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 4 Program data path: C:\Users\whs_admin\AppData\Roaming\Emby-Server\programdata Application directory: C:\Users\whs_admin\AppData\Roaming\Emby-Server\system System.NullReferenceException: Object reference not set to an instance of an object. at MediaBrowser.Plugins.DVBViewer.Services.Proxies.TVServiceProxy.GetChannels(CancellationToken cancellationToken) at MediaBrowser.Plugins.DVBViewer.DVBViewerTvService.GetChannelsAsync(CancellationToken cancellationToken) at Emby.Server.Implementations.LiveTv.LiveTvManager.<RefreshChannelsInternal>d__72.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.LiveTv.LiveTvManager.<RefreshChannelsInternal>d__71.MoveNext() System.NullReferenceException at MediaBrowser.Plugins.DVBViewer.Services.Proxies.TVServiceProxy.GetChannels(CancellationToken cancellationToken) at MediaBrowser.Plugins.DVBViewer.DVBViewerTvService.GetChannelsAsync(CancellationToken cancellationToken) at Emby.Server.Implementations.LiveTv.LiveTvManager.<RefreshChannelsInternal>d__72.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.LiveTv.LiveTvManager.<RefreshChannelsInternal>d__71.MoveNext() 2018-04-01 21:20:43.072 Debug App: Refreshing guide from Emby I cant connect the plugin to DMS 2.0.4.0. Please help. thx Edited April 1, 2018 by popy
popy 73 Posted April 1, 2018 Posted April 1, 2018 Dont know why, but now it works. Have remove the favourites setting and the authentification and now all data is in emby. Have created my first series timer (which is visible in EPG-Suche in DMS), nice! But i cant select an channel group and the spinning circle is here: Anyway, it works now. Another questions: How can i delete an series recording? When ill go to "Zeitplan" (schedules) in emby, select the series timer (two little red dots) and press "Serie abbrechen" (cancle series) nothing happens. Also the autotimer in DMS will not be deleted. Is there a possibility to add a default "Aufgabe" (Task) to the series timer? Ex.: i have a "Post-Recording" Task which creates an EDL comskip file and cleans old recordings. In DMS i have set it up to run this as default. When ill create an timer in emby, the default "Post-Recording" task will not be set. Thank you pOpY
Luke 42245 Posted April 1, 2018 Posted April 1, 2018 Sounds like the plugin might require updates for that version of the dvb software.
