pünktchen 1411 Posted March 3, 2017 Author Posted March 3, 2017 I think i know what the problem is. Those two channels, that still have guide data are the only ones with a channel logo? Please pm me your server log after doing a guide refresh!
rechner123 12 Posted March 4, 2017 Posted March 4, 2017 Hi pünktchen You are correct. All the channel with channel logo have also guide data. I have sent you the logfile! 1
rechner123 12 Posted March 6, 2017 Posted March 6, 2017 (edited) Is there anything i can do to become guide back? Edited March 6, 2017 by rechner123
pünktchen 1411 Posted March 6, 2017 Author Posted March 6, 2017 Is there anything i can do to become guide back?For the time being, just set your missing channel logos in RecordingService. This would also look so much nicer [emoji6] 1
rechner123 12 Posted March 8, 2017 Posted March 8, 2017 It is so easy when you know how it's done But is this normal for channels with no logo, there also have no guide data in emby?
pünktchen 1411 Posted March 8, 2017 Author Posted March 8, 2017 It is so easy when you know how it's done But is this normal for channels with no logo, there also have no guide data in emby? Of course not, but i haven't found the time yet to publish a new version. You know - private life and the other things... 1
pvcminator 0 Posted March 10, 2017 Posted March 10, 2017 hallo. ich habe auch das problem mit der neuen version. keine epg
rechner123 12 Posted March 10, 2017 Posted March 10, 2017 hallo. ich habe auch das problem mit der neuen version. keine epg It works for me resetting channel logos in dvbviewer recording service.
pünktchen 1411 Posted March 10, 2017 Author Posted March 10, 2017 Du sollst im RecordingService Senderlogos hinterlegen! Oder du wartest noch ein, zwei Tage. Hab eben eine neue Plugin Version an die Emby Entwickler geschickt. I've sent a new plugin version to the Emby devs. So it should be fixed in one or two days. 1
rechner123 12 Posted March 15, 2017 Posted March 15, 2017 Hi pünktchen With the latest update, i think all is working correct. Time in guide and also guide on channels without logo. Tried with delete a channel logo. Thanks for update and of course for the plugin! 1
Jaques-Ludwig 0 Posted August 4, 2017 Posted August 4, 2017 Does this plugin also works with the new DVBViewer Media Server? Thanks, Stephan
rechner123 12 Posted January 30, 2018 Posted January 30, 2018 (edited) HiI have problems with recording series and normal recording.I dont know if this problem comes with emby or the plugin.If i record series with letters, ä, ö, ü, ß, in the title, i have cryptic symbols instead of the letter. I have tried the language setting of emby english and german.And the other is my normal(one time) recording does not work. If i click record, i only have a spinning circle and nothing happen.Can anyone help me please? Edit: changelog added server-63652936385.txt Edited January 30, 2018 by rechner123
Luke 42245 Posted January 30, 2018 Posted January 30, 2018 If i click record, i only have a spinning circle and nothing happen. Please attach the information requested in how to report a problem. thanks !
rechner123 12 Posted January 30, 2018 Posted January 30, 2018 Thanks Changelog uploaded. First i tried single record-> spinning circle Second i have done a series recording-> cryptic symbol instead a "ü"
Luke 42245 Posted January 30, 2018 Posted January 30, 2018 There's some kind of error in the plugin, i'm not quite sure what it is but hopefully @@pünktchen can advise. 2018-01-30 20:24:40.691 Info HttpClient: GET: http://192.168.0.14:3366/api/getconfigfile.html?file=config%5Cservice.xml 2018-01-30 20:24:40.703 Error HttpServer: Error processing request *** Error Report *** Version: 3.2.70.0 Command line: C:\Users\STREAMER\AppData\Roaming\Emby-Server\system\EmbyServer.dll Operating system: Microsoft Windows NT 6.2.9200.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 4 Program data path: C:\Users\STREAMER\AppData\Roaming\Emby-Server Application directory: C:\Users\STREAMER\AppData\Roaming\Emby-Server\system System.NullReferenceException: Object reference not set to an instance of an object. at MediaBrowser.Plugins.DVBViewer.Services.Entities.Settings.GetEntry(List`1 section, String key) at MediaBrowser.Plugins.DVBViewer.Services.Proxies.TVServiceProxy.CreateSchedule(CancellationToken cancellationToken, TimerInfo timer) at MediaBrowser.Plugins.DVBViewer.DVBViewerTvService.CreateTimerAsync(TimerInfo info, CancellationToken cancellationToken) at Emby.Server.Implementations.LiveTv.LiveTvManager.<CreateTimer>d__101.MoveNext() System.NullReferenceException at MediaBrowser.Plugins.DVBViewer.Services.Entities.Settings.GetEntry(List`1 section, String key) at MediaBrowser.Plugins.DVBViewer.Services.Proxies.TVServiceProxy.CreateSchedule(CancellationToken cancellationToken, TimerInfo timer) at MediaBrowser.Plugins.DVBViewer.DVBViewerTvService.CreateTimerAsync(TimerInfo info, CancellationToken cancellationToken) at Emby.Server.Implementations.LiveTv.LiveTvManager.<CreateTimer>d__101.MoveNext()
pünktchen 1411 Posted January 31, 2018 Author Posted January 31, 2018 Hi I have problems with recording series and normal recording. I dont know if this problem comes with emby or the plugin. If i record series with letters, ä, ö, ü, ß, in the title, i have cryptic symbols instead of the letter. I have tried the language setting of emby english and german. And the other is my normal(one time) recording does not work. If i click record, i only have a spinning circle and nothing happen. Can anyone help me please? Edit: changelog added Hi @@rechner123 for your second problem please try this version: If it doesn't work, please pm me your DMS "service.xml" file. @@Luke i think the problem with umlauts is an Emby bug. I've seen this also with my other tv plugin. With both i just deliver a string of course.
Luke 42245 Posted February 1, 2018 Posted February 1, 2018 Thanks for the info. We can look into that.
rechner123 12 Posted February 22, 2018 Posted February 22, 2018 @@Luke i think the problem with umlauts is an Emby bug. I've seen this also with my other tv plugin. With both i just deliver a string of course. Could this be the reason because my series recording does not work correctly for shows with umlauts? If i record a show "Die größten Konstruktionsfehler der Welt" as example, the recording does work only for one or two shows. Then i have to delete series recording and add them again then it works again for up to 2 shows. Does emby search the guide for the show? Then i think emby will search " Die grÃÂÃÂÃÂÃÂÃÂÃÂÃÂÃÂÃÂÃÂÃÂÃÂÃÂÃÂÃÂöÃÂÃÂÃÂÃÂÃÂÃÂÃÂÃÂÃÂÃÂÃÂÃÂÃÂÃÂÃÂÃÂten Konstruktionsfehler der Welt" and could not find them right? only my thought! Thanks
pünktchen 1411 Posted February 22, 2018 Author Posted February 22, 2018 No, Emby doesn't search the guide to create the timers. The series recording in Emby creates a "EPG-Autotimer-Suche" in DVBViewer, so the RS/DMS is responsible for upcoming timers. How does the "EPG-Autotimer-Suche" look like in the Recording Service Webinterface after creating from within Emby? Is it false right after creation or does it change itself after some time?
rechner123 12 Posted February 22, 2018 Posted February 22, 2018 When i go in RS under Suchvorgaben, then it looks like in the screenshot below
pünktchen 1411 Posted February 22, 2018 Author Posted February 22, 2018 Thanks. Will look into it at the weekend.
rechner123 12 Posted February 22, 2018 Posted February 22, 2018 Thank you! This looks for me so that emby send the false series name to RS and so the series would not be found. I deleted series recording and added them new. In RS it seems to be correct. If i edit the series recording in emby and then look again in RS, the name looks cryptic again.
Luke 42245 Posted February 22, 2018 Posted February 22, 2018 No, the name is for display only. When we communicate with the back end we use a unique id.
pünktchen 1411 Posted February 25, 2018 Author Posted February 25, 2018 (edited) @@rechner123 please try this one: Edited February 26, 2018 by pünktchen
