Nikolaech 32 Posted June 26, 2016 Posted June 26, 2016 (edited) Thank you. The substrate for the logo. 512x512 px Autor Fubdro Fone.zip Edited June 26, 2016 by Nikolaech
pünktchen 1411 Posted July 12, 2016 Author Posted July 12, 2016 @@Nikolaech there's a new version of the RecordingService available that should fix your channel logo problem. 1
Nikolaech 32 Posted July 12, 2016 Posted July 12, 2016 @pünktchen thank you. Yes, the problem solved. Refresh guide in ES ver 3.1.40 lives his life :-(
Nikolaech 32 Posted August 5, 2016 Posted August 5, 2016 @pünktchen look http://emby.media/community/index.php?/topic/35064-version-3059700-constant-updating-epg/?p=353011
chvb 1 Posted August 25, 2016 Posted August 25, 2016 (edited) Hello together, Ive got some Problem with the EPG. There are some TV stations without EPG Data. When i take a look in the Webinterface from DVBViewer there is everything ok. Every TV Station with EPG. Does anybody know what this Problem can be? Edited August 25, 2016 by chvb
pünktchen 1411 Posted August 25, 2016 Author Posted August 25, 2016 Just disable every listed tuner device in the live tv status page of the Emby Dashboard. Click on the tuners and uncheck "Enable this tuner", DO NOT USE THE TRASH ICON! 1
chvb 1 Posted August 25, 2016 Posted August 25, 2016 Hey Pünktchen, many thanks. This was the solution! There was a SatIP Tuner. After disabling this Tuner the EPG was correct. Many Thanks.
Adumbran11 0 Posted December 6, 2016 Posted December 6, 2016 Here i am with the next Problem ;-) Emby Version 3.1.247.0 beta - Live TV Dvbviewer Plugin 0.8.5.0 It´s not possible to watch Live TV - Have no Video - Audio still works. Had the Problem also with at least the last Emby Regular Version and DvbViewer Plugin 0.8.4.0 Anyone the same Problem? Adumbran11
Luke 42245 Posted December 6, 2016 Posted December 6, 2016 Please provide the information requested in how to report a media playback issue: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks !
pünktchen 1411 Posted December 6, 2016 Author Posted December 6, 2016 Here i am with the next Problem ;-) Emby Version 3.1.247.0 beta - Live TV Dvbviewer Plugin 0.8.5.0 It´s not possible to watch Live TV - Have no Video - Audio still works. Had the Problem also with at least the last Emby Regular Version and DvbViewer Plugin 0.8.4.0 Anyone the same Problem? Adumbran11 No problem here.
Nikolaech 32 Posted February 11, 2017 Posted February 11, 2017 Hi All. I have this problem after starting ES. For several stable versions ES. Only at me so?
pünktchen 1411 Posted February 11, 2017 Author Posted February 11, 2017 Hi All. I have this problem after starting ES. For several stable versions ES. Only at me so? Hi Niko, are you trying to say that your EPG times are of by your timezone offset? One guy at the DVBViewer forum reported this last week, but i hadn't the time to look at this yet.
Nikolaech 32 Posted February 11, 2017 Posted February 11, 2017 Hi Niko, are you trying to say that your EPG times are of by your timezone offset? One guy at the DVBViewer forum reported this last week, but i hadn't the time to look at this yet. Yes. In DVBViewer OK
pünktchen 1411 Posted February 11, 2017 Author Posted February 11, 2017 Out of interest, what's the version of your Recording Service?
Nikolaech 32 Posted February 11, 2017 Posted February 11, 2017 (edited) The latest version. Today reinstall the application. hoped to helps. Hi @pünktchen Strange, today launched the server, all is well. Earlier always there was a difference in time zone. Edited February 12, 2017 by Nikolaech
Nikolaech 32 Posted February 13, 2017 Posted February 13, 2017 Today again the time zone offset at 6 hours. It is not clear where the problem is. DVBViewer OK.
rechner123 12 Posted February 13, 2017 Posted February 13, 2017 I dont use egp, but now i have looking at it. My time is also not correct. It is all an hour too late.
pünktchen 1411 Posted February 14, 2017 Author Posted February 14, 2017 I've created a patch. Your plugins should auto update the next days. 1
rechner123 12 Posted March 2, 2017 Posted March 2, 2017 Hi all!I have only epg data on prosieben maxx and the most sky channels.I tried to reinstall dvbviewer plugin with the same result.When i install the plugin again, the settings was not deleted.(eg. ip adress,port).Same with deinstall, reboot and reinstall. Is this normal?In dvbviewer there are all epg informations correct!Any tips for me? Can i delete the epg data in emby?
pünktchen 1411 Posted March 2, 2017 Author Posted March 2, 2017 You have to remove the plugin, restart Emby, refresh the guide and reinstall the plugin.
rechner123 12 Posted March 2, 2017 Posted March 2, 2017 Thank you for answer I tried this way you wrote, but its the same result. Removed plugin, restarted emby, refreshed guide, installed plugin again. After that there was no epg data. I did a guide refresh and only on the most sky and prosieben maxx are guide informations.
rechner123 12 Posted March 2, 2017 Posted March 2, 2017 I tried again. I have made the same procedur but installed the previuous version of the plugin (8.5.0) and the guide shows correctly, till the server did update the plugin to latest, 5.8.500 and then there was the same problem as before!
