pünktchen 1411 Posted June 22, 2016 Author Posted June 22, 2016 Firing events I mean No, the plugin doesn't use public event EventHandler DataSourceChanged; if that's what you mean.
pünktchen 1411 Posted June 22, 2016 Author Posted June 22, 2016 Btw. I don't have this guide refresh problem and no one other reported it yet...
Zeze21 1 Posted June 22, 2016 Posted June 22, 2016 Well the thing is - Emby works fine for about an hour or so then the constant refreshing seems to use up more and more ram and cpu. Btw. Windows 10 Insider user - always the latetest update from the fast ring
dabrain 0 Posted June 23, 2016 Posted June 23, 2016 I used the plugin for a while, and really like it. But my tv guide shows all of my channels 3, 4 or 5 times double. it also shows channels which aren't in my channel group (anymore). See attachment (i put my zoom to 25% to show more channels). In my backend, dvbviewer there only a few (about 20 channels and 10 radio channels). Is there a way to rearrange the channels within emby, or make the double channels disapear?
pünktchen 1411 Posted June 23, 2016 Author Posted June 23, 2016 I used the plugin for a while, and really like it. But my tv guide shows all of my channels 3, 4 or 5 times double. it also shows channels which aren't in my channel group (anymore). See attachment (i put my zoom to 25% to show more channels). In my backend, dvbviewer there only a few (about 20 channels and 10 radio channels). Is there a way to rearrange the channels within emby, or make the double channels disapear? Just read the starting post!
Zeze21 1 Posted June 23, 2016 Posted June 23, 2016 (edited) I used the plugin for a while, and really like it. But my tv guide shows all of my channels 3, 4 or 5 times double. it also shows channels which aren't in my channel group (anymore). See attachment (i put my zoom to 25% to show more channels). In my backend, dvbviewer there only a few (about 20 channels and 10 radio channels). Is there a way to rearrange the channels within emby, or make the double channels disapear? You have to deaktivate the original dvbviewer tuner at the tv page - just run the plugin - nothing else - had the same problem and this solves it. Also I would not show my dnydns address here you never know who will use this and try to access your server Things to stay safe: Use Passwords for Emby don't give away your dyndns to anyone you don't personally know. It can have legal consequences if you make copyrighted Movies, Series, Paytv Channels publicly available. Apart from it being a huge security threat - imagine how easy it is to scan your files on your computer when someone you don't know has access to your entire emby server... If you do not use passwords and someone enters your emby server in the eu - that is not even breaking the law - there is nothing you can do against it. Edited June 23, 2016 by Zeze21
Nikolaech 32 Posted June 23, 2016 Posted June 23, 2016 Btw. I don't have this guide refresh problem and no one other reported it yet... I wrote about this a month ago. Logs no one even looked. http://emby.media/community/index.php?/topic/35064-version-3059700-constant-updating-epg/ This is an old sore, helps to restart PC
pünktchen 1411 Posted June 23, 2016 Author Posted June 23, 2016 I wrote about this a month ago. Logs no one even looked. http://emby.media/community/index.php?/topic/35064-version-3059700-constant-updating-epg/ This is an old sore, helps to restart PC Interesting! I've never seen this before, respectively it has never happened to me.
Nikolaech 32 Posted June 23, 2016 Posted June 23, 2016 In version server 5972 better, but the problem persists.
pünktchen 1411 Posted June 23, 2016 Author Posted June 23, 2016 In version server 5972 better, but the problem persists. To be precise, do you only have the problem of growing memory or does your guide refresh task start itself repeatedly in very short timeframes?
Nikolaech 32 Posted June 23, 2016 Posted June 23, 2016 Refresh guide runs every few seconds. And as you can see, consuming huge resources of the computer.
pünktchen 1411 Posted June 23, 2016 Author Posted June 23, 2016 I don't know... I would suggest: Rename your Emby installation folder and try a fresh install without any libraries, without any plugins but DVBViewer and all with default settings.
Nikolaech 32 Posted June 23, 2016 Posted June 23, 2016 Thank you. Your plugin works fine. I'm tired of the server, it is too crude, bulky and slow.
Zeze21 1 Posted June 25, 2016 Posted June 25, 2016 I wrote about this a month ago. Logs no one even looked. http://emby.media/community/index.php?/topic/35064-version-3059700-constant-updating-epg/ This is an old sore, helps to restart PC Nope sorry does not help to restart the pc...
Nikolaech 32 Posted June 25, 2016 Posted June 25, 2016 Nope sorry does not help to restart the pc... Wanted to check again, but failed. Plugin updated to version 0.8.3 and the problem disappeared. I will report @@pünktchen good job.
Nikolaech 32 Posted June 25, 2016 Posted June 25, 2016 bad grasps the logos perhaps the reason is the Cyrillic. server-63602510207.zip
Nikolaech 32 Posted June 26, 2016 Posted June 26, 2016 Sorry! I hurried. In kodi the same thing. In dvbviewer and regservice everything is OK Cleaned database dvbviewer, does not help (
pünktchen 1411 Posted June 26, 2016 Author Posted June 26, 2016 Sorry! I hurried. In kodi the same thing. In dvbviewer and regservice everything is OK Cleaned database dvbviewer, does not help ( Probably the RS API has a problem to encode it correct.
Nikolaech 32 Posted June 26, 2016 Posted June 26, 2016 how to clear the cache of live TV in Emby? thanks
pünktchen 1411 Posted June 26, 2016 Author Posted June 26, 2016 how to clear the cache of live TV in Emby? thanks On Windows: C:\Users\<USERNAME>\AppData\Roaming\Emby-Server\cache C:\Users\<USERNAME>\AppData\Roaming\Emby-Server\metadata\livetv 1
Spaceboy 2573 Posted June 26, 2016 Posted June 26, 2016 On Windows: C:\Users\<USERNAME>\AppData\Roaming\Emby-Server\cache C:\Users\<USERNAME>\AppData\Roaming\Emby-Server\metadata\livetv Hey punktchen is there any better compatibility with dvbviewer and android? Have a licence for this too [emoji3]
pünktchen 1411 Posted June 26, 2016 Author Posted June 26, 2016 Hey punktchen is there any better compatibility with dvbviewer and android? Have a licence for this too [emoji3] For you, who knows? Just try it out. DVBViewer is really easy to setup...
Nikolaech 32 Posted June 26, 2016 Posted June 26, 2016 Probably the RS API has a problem to encode it correct. Rename logos in DVBVewer (latin) - OK in ES and Kodi :-) 1
