Schimi 26 Posted May 21, 2016 Posted May 21, 2016 would it help if i activate the debug loggin from emby, too? :-)
pünktchen 1411 Posted May 21, 2016 Author Posted May 21, 2016 Got it! Will update the plugin in the evening. 2
Schimi 26 Posted May 23, 2016 Posted May 23, 2016 Got it! Will update the plugin in the evening. WORKS!! :-)
chvb 1 Posted May 31, 2016 Posted May 31, 2016 Hi together, i've got a problem with the epg. It's not shown correctly. Under the Dashboard > Activities the time is ok. But in the Live TV EPG there is a time difference Here is a example. Now its 07:00 o'Clock. It is the start of "Guten Morgen Deutschland"
pünktchen 1411 Posted May 31, 2016 Author Posted May 31, 2016 Hi together, i've got a problem with the epg. It's not shown correctly. Under the Dashboard > Activities the time is ok. But in the Live TV EPG there is a time difference Here is a example. Now its 07:00 o'Clock. It is the start of "Guten Morgen Deutschland" Oh, your the first one who complains about time differences. I've thought that it would operate correct... What is your setting in Recording Service?
chvb 1 Posted May 31, 2016 Posted May 31, 2016 (edited) thanks for your answer. I think that the timezone of the host is the Problem. I set the timezone to the correct one. But now, when i want to refresh the TV Data in Emby the process leaves at 0,0% I use a Password for the Recording Service Web Interface because i also using the IOS app to shedule recordings. Did anybody know, why the refresh of the Program Data don't work? /// EDIT Ok, everything is fine now. There is no process but it works. Also the EPG Time is now correct. Edited May 31, 2016 by chvb 1
pünktchen 1411 Posted May 31, 2016 Author Posted May 31, 2016 The guide refresh is just very slow compared to previous Emby server releases, so just be patient. Of course it also depends on the number of channels you have...
rechner123 12 Posted June 4, 2016 Posted June 4, 2016 Hi I only want inform that a new recording service 1.33 is available, with some changes for authentification, security and some other things. 2
chvb 1 Posted June 8, 2016 Posted June 8, 2016 The guide refresh is just very slow compared to previous Emby server releases, so just be patient. Of course it also depends on the number of channels you have... Hello together, I think my problem with the EPG time are not fixed. When I set the Timezone manual to +2, everything in Emby works fine. EPG is fine. But in the Kodi Clients with the DVBViewer Addon the EPG isn't correct. When i set the timezone to automatically there is the epg Problem in Emby. In the Kodi Clients there is everything fine. What can i make that Emby and Kodi works correct? My Emby is working on a UNRAID Server in a Docker. The time is shown correctly. Thanks for any suggestions. chvb
pünktchen 1411 Posted June 8, 2016 Author Posted June 8, 2016 Hello together, I think my problem with the EPG time are not fixed. When I set the Timezone manual to +2, everything in Emby works fine. EPG is fine. But in the Kodi Clients with the DVBViewer Addon the EPG isn't correct. When i set the timezone to automatically there is the epg Problem in Emby. In the Kodi Clients there is everything fine. What can i make that Emby and Kodi works correct? My Emby is working on a UNRAID Server in a Docker. The time is shown correctly. Thanks for any suggestions. chvb Hi @@chvb, i'm also from germany, so same timezone like you and i can say for sure: the plugin is working right! On your Windows machine the system time should be UTC+01:00 (Amsterdam, Berlin, Bern, Rom, Stockholm, Wien) and in RecordingService just automatic. If this doesn't work, you should check the timezone in unRAID server and your Docker configuration! There are lots of Google results about problems/different timezones in unRAID and Docker especially when it comes to daylight saving time. Unfortunately i don't know anything about those systems, so i can't help you here. 1
chvb 1 Posted June 9, 2016 Posted June 9, 2016 Hi @@pünktchen first many thanks for your help. You led me in the right direction. Now, my Problem is finally solved. I need to make a volume mapping for the emby docker. i have make the following volume mapping /etc/localtime:/etc/localtime Now anything is working correctly with the epg. Many thanks, chvb
Schimi 26 Posted June 18, 2016 Posted June 18, 2016 (edited) hmm.. since i updated the recording service to 1.33... i can´t set recordings in emby..... if i do it in the DVBViewer Web interface, then it works but not in emby himself server-63601850355.txt Edited June 18, 2016 by Schimi
pünktchen 1411 Posted June 18, 2016 Author Posted June 18, 2016 hmm.. since i updated the recording service to 1.33... i can´t set recordings in emby..... if i do it in the DVBViewer Web interface, then it works but not in emby himself server-63601850355.txt Yeah, there are some changes to the API in 1.33 but i didn't test it yet. Will try to look at this tomorrow.
Schimi 26 Posted June 18, 2016 Posted June 18, 2016 ok... the important thing is.... it´s not my fault :-) THX!! great job :-)
Zeze21 1 Posted June 20, 2016 Posted June 20, 2016 The DVBViewer plugin increases my ram and cpu usage to enourmous amounts: here you can find my logfiles (packed 724 kb unpacked ~ 20 mb) http://ul.to/kliz4de2 Does anyone have a solution for this?
pünktchen 1411 Posted June 20, 2016 Author Posted June 20, 2016 The DVBViewer plugin increases my ram and cpu usage to enourmous amounts: here you can find my logfiles (packed 724 kb unpacked ~ 20 mb) http://ul.to/kliz4de2 Does anyone have a solution for this? It's because your refresh guide task is triggered every 3 Seconds!
Nikolaech 32 Posted June 20, 2016 Posted June 20, 2016 (edited) Does anyone have a solution for this? helps restart PC and @@Luke Try to run the server as a service Windows. but not completely sure. Edited June 20, 2016 by Nikolaech
Zeze21 1 Posted June 22, 2016 Posted June 22, 2016 (edited) It's because your refresh guide task is triggered every 3 Seconds! That should not be - it is set to do this every 24 hours... helps restart PC and @@Luke Try to run the server as a service Windows. but not completely sure. I will try that but I am not sure how this will help check the schedule for the task. Did it is supposed to refresh the guide every 24h... by default "Every 12 hours" mine is set (apparently by default) to 24 hours I have now switched the days from auto to 1 Now the refreshing takes about 4-5 minutes but apparently starts over again after a few seconds Also i don't know if this is related but if i go to my program listings I have every channel listed twice. First every Channel is listed as Channel # "-1" I would love to get rid of those channels... EDIT: OK got rid of the extra channels did not know that you had to disable the default tuner! Reinstalled the Plugin (did a restart after every step) But the Refresh thing keeps existing - it keeps poping up and if i manually try to stop it - it just comes up instantly again.... Edited June 22, 2016 by Zeze21
pünktchen 1411 Posted June 22, 2016 Author Posted June 22, 2016 (edited) Stop Emby Server, delete the folder "ScheduledTasks" from "Emby-Server/data" and "Emby-Server/config" after making a backup and restart Emby Server. Does the guide refresh start itself? If not, do it one time manually and wait for it to complete. What happens then? Edited June 22, 2016 by pünktchen
Zeze21 1 Posted June 22, 2016 Posted June 22, 2016 Did exactly as you said - The Refresh starts by itself and restarts serveral times a second...
pünktchen 1411 Posted June 22, 2016 Author Posted June 22, 2016 Did exactly as you said - The Refresh starts by itself and restarts serveral times a second...@@Luke can you help here please?
Luke 42244 Posted June 22, 2016 Posted June 22, 2016 Is the plugin during events about data source updated?
