Kodi_Newcomer 27 Posted June 10, 2018 Posted June 10, 2018 The same. I have restart the server, shutdown the server wait for some minutes. Try again, try again, but the task ends always with an error. Here is the log again. Log.txt
pünktchen 1411 Posted June 10, 2018 Author Posted June 10, 2018 I didn't expect it to work, but hopefully i can trac it down from your log [emoji6]
pünktchen 1411 Posted June 10, 2018 Author Posted June 10, 2018 Okay @@Kodi_Newcomer the problem is i can't identify some of your channels by the provided guide data. Please make sure there's only one guide data source enabled for your channels. Either "External EPG" or "DVB EPG"! Also you should really create a new channel group. You'll have to copy the channels from your "Astra" group, not from your "Favoriten"!
Kodi_Newcomer 27 Posted June 10, 2018 Posted June 10, 2018 Also you should really create a new channel group. You'll have to copy the channels from your "Astra" group, not from your "Favoriten"! This was my first mistake i have try'ed to copy the Fav Channels to my new group. So it works.
pünktchen 1411 Posted June 10, 2018 Author Posted June 10, 2018 (edited) Here's a small task for you: 1. Open this in a browser http://127.0.0.1:8089/api/getchannelsxml.html?fav=1 2. There should be two instances of your FOX channel. Onetime it occurs under "Favoriten" and onetime under "Astra". Is the "EPGID" the same for both? If yes, copy the "EPGID" number of your FOX channel 3. Open this in a browser with the EPGID instead of #### http://127.0.0.1:8089/api/epg.html?lvl=2&channel=####&start=43261.14236111&end=43264.14236111 4. Attach the output here Edited June 10, 2018 by pünktchen
Kodi_Newcomer 27 Posted June 11, 2018 Posted June 11, 2018 (edited) Here's a small task for you: 1. Open this in a browser http://127.0.0.1:8089/api/getchannelsxml.html?fav=1 2. There should be two instances of your FOX channel. Onetime it occurs under "Favoriten" and onetime under "Astra". Is the "EPGID" the same for both? If yes, copy the "EPGID" number of your FOX channel 3. Open this in a browser with the EPGID instead of #### http://127.0.0.1:8089/api/epg.html?lvl=2&channel=####&start=43261.14236111&end=43264.14236111 4. Attach the output here So the 2 epg id's are the same. So when i do it right, so this is the result of it. EPG from Fox I create a new group with all my channels that i will have for recordings. I will test it tomorrow, because now some recordings running. I will give feedback then. Edited June 11, 2018 by Kodi_Newcomer
pünktchen 1411 Posted June 11, 2018 Author Posted June 11, 2018 So the 2 epg id's are the same. So when i do it right, so this is the result of it. EPG from Fox Like i expected, there are two different channel numbers in your guide data!!! channel="563521184202764" channel="563521184202768" One of those numbers (Channel EPGID) for sure is the one the plugin gets from your channels.xml and then in return uses to get the guide data. But to create a timer i have to use the Channel ID not the Channel EPGID. So the plugin takes the first Channel EPGID it finds in the guide data and compares it with the channels.xml to get the proper Channel ID. Unfortunately the first number is the false number in your case. So the real question is why do you have two different Channel EPGID's in your guide data that is returned from a call with a single unique Channel EPGID? I cannot answer this. This is a question that you have to ask at the DVBViewer forum. I guess it is something with the source of your guide data.
pünktchen 1411 Posted June 11, 2018 Author Posted June 11, 2018 (edited) @@Kodi_Newcomer Which one of those two numbers is the one you've found for your FOX channel? I've already seen and reported a similar problem in DVBViewer: https://www.dvbviewer.tv/forum/topic/61399-api-epghtml-returns-programs-for-not-existing-channels/ Edited June 11, 2018 by pünktchen 1
pünktchen 1411 Posted June 12, 2018 Author Posted June 12, 2018 Hi @@Kodi_Newcomer here's another test version: I've tried to workaround the shortcomings of DVBViewer's DMS API. There's no help to be expected from the DVBViewer guys 1
Kodi_Newcomer 27 Posted June 12, 2018 Posted June 12, 2018 (edited) So now i have a new channel group. Now it will test. Maybe there was Fox SD, Fox HD (deu) and Fox HD ? Maybe there is the problem. I made here and there a channel update when i search for new channels. So there was a new group with sky channels and there was the other Fox HD channel, maybe this was the problem with the two id's ? No i have delet double channels with little different name and use now the extra created channel group for your plugin, no it seems to be work. But why it works in the past ? I will give feedback in a view minutes. So now i have only one Fox HD and one Fox Serie (SD). I have used the version bevor your last post. Now there is no error anymore. I looks like it works now. Here is the log, maybe you find some other issues, or he is clean now. But i have another issue found. Westworld S2E8 is in the lib since yesterday. I hoped your plugin deactivate the timer, but he did not. So i have a look at it, because you tell'ed me there must be priority at 49 that your plugin can deactivate it. But the priority was 79, and the timer was create from Api. Hi @@Kodi_Newcomer here's another test version: MediaBrowser.Plugins.DVBViewer.zip I've tried to workaround the shortcomings of DVBViewer's DMS API. There's no help to be expected from the DVBViewer guys Should i use your lates'ed version nevertheless ? Edited June 12, 2018 by Kodi_Newcomer
pünktchen 1411 Posted June 12, 2018 Author Posted June 12, 2018 So now i have a new channel group. Now it will test. Maybe there was Fox SD, Fox HD (deu) and Fox HD ? Maybe there is the problem. I made here and there a channel update when i search for new channels. So there was a new group with sky channels and there was the other Fox HD channel, maybe this was the problem with the two id's ? No i have delet double channels with little different name and use now the extra created channel group for your plugin, no it seems to be work. But why it works in the past ? I will give feedback in a view minutes. So now i have only one Fox HD and one Fox Serie (SD). I have used the version bevor your last post. Now there is no error anymore. I looks like it works now. Here is the log, maybe you find some other issues, or he is clean now. But i have another issue found. Westworld S2E8 is in the lib since yesterday. I hoped your plugin deactivate the timer, but he did not. So i have a look at it, because you tell'ed me there must be priority at 49 that your plugin can deactivate it. But the priority was 79, and the timer was create from Api. Should i use your lates'ed version nevertheless ? Yes please test the last version i've posted. With this the priority should also be 49 again. 1
Kodi_Newcomer 27 Posted June 12, 2018 Posted June 12, 2018 (edited) Yes please test the last version i've posted. With this the priority should also be 49 again. Hm it looks good to for now. Now error after Autocreate Timer. I will now look what happend when there are more timers for the same episode, if he deactivate it now, after the episode is in the lib. Feedback comes. So far, thanks a lot for your create development and support. It looks im the only one how use your genius tool ? Edited June 12, 2018 by Kodi_Newcomer
pünktchen 1411 Posted June 12, 2018 Author Posted June 12, 2018 It looks im the only one how use your genius tool ?I don't think so, but maybe you're the only one who uses the new special features. 1
thor2002ro 5 Posted June 14, 2018 Posted June 14, 2018 anyone here have issues with livetv subtitles not showing....? tried hbo that has separate subtitles not embedded and they dont show and have no option to enable them....
pünktchen 1411 Posted June 14, 2018 Author Posted June 14, 2018 anyone here have issues with livetv subtitles not showing....? tried hbo that has separate subtitles not embedded and they dont show and have no option to enable them....Seperate subtitles for a live tv stream? I've never seen this. Either DVBViewer also doesn't know how to handle this or it's an Emby app problem. The plugin just delivers the url to the DVBViewer stream. Nothing more.
thor2002ro 5 Posted June 14, 2018 Posted June 14, 2018 (edited) here its using dvb viewer rtsp on vlc Edited June 14, 2018 by thor2002ro
pünktchen 1411 Posted June 14, 2018 Author Posted June 14, 2018 Ah a seperate subtitle stream in the ts stream... If you want to check if it comes through my plugin, then just play the same channel in your browser, so it gets transcoded. In Emby's ffmpeg log you will find the DVBViewer stream url. It's a http stream, not rtsp because this is not supported by default in ffmpeg.
thor2002ro 5 Posted June 14, 2018 Posted June 14, 2018 (edited) yes it is.... Stream #0:0[0x19a1]: Video: h264 (Main) ([27][0][0][0] / 0x001B), yuv420p(tv, bt709, top first), 1920x1080 [SAR 1:1 DAR 16:9], 25 fps, 25 tbr, 90k tbn, 50 tbc Stream #0:1[0x19a2](rum): Audio: mp2 ([3][0][0][0] / 0x0003), 48000 Hz, stereo, fltp, 192 kb/s Stream #0:2[0x19a6](rum): Subtitle: dvb_subtitle ([6][0][0][0] / 0x0006) Stream #0:3[0x19a7](eng): Subtitle: dvb_subtitle ([6][0][0][0] / 0x0006) Stream #0:4[0x19a3](hun): Audio: mp2 ([3][0][0][0] / 0x0003), 48000 Hz, stereo, fltp, 192 kb/s Stream #0:5[0x19a4](eng): Audio: ac3 ([6][0][0][0] / 0x0006), 48000 Hz, 5.1(side), fltp, 384 kb/s Edited June 14, 2018 by thor2002ro
pünktchen 1411 Posted June 14, 2018 Author Posted June 14, 2018 yes it is.... Stream #0:0[0x19a1]: Video: h264 (Main) ([27][0][0][0] / 0x001B), yuv420p(tv, bt709, top first), 1920x1080 [SAR 1:1 DAR 16:9], 25 fps, 25 tbr, 90k tbn, 50 tbc Stream #0:1[0x19a2](rum): Audio: mp2 ([3][0][0][0] / 0x0003), 48000 Hz, stereo, fltp, 192 kb/s Stream #0:2[0x19a6](rum): Subtitle: dvb_subtitle ([6][0][0][0] / 0x0006) Stream #0:3[0x19a7](eng): Subtitle: dvb_subtitle ([6][0][0][0] / 0x0006) Stream #0:4[0x19a3](hun): Audio: mp2 ([3][0][0][0] / 0x0003), 48000 Hz, stereo, fltp, 192 kb/s Stream #0:5[0x19a4](eng): Audio: ac3 ([6][0][0][0] / 0x0006), 48000 Hz, 5.1(side), fltp, 384 kb/s So problem is the app and you should create a new thread under the forum's apps section.
thor2002ro 5 Posted June 14, 2018 Posted June 14, 2018 I don't think it's app related tried in web, lg tv, Samsung tv app and android none work.... Maybe emby live tv doesn't support multiple audio and subtitles?
Luke 42245 Posted June 14, 2018 Posted June 14, 2018 I don't think it's app related tried in web, lg tv, Samsung tv app and android none work.... Maybe emby live tv doesn't support multiple audio and subtitles? How to report a media playback issue. Thanks !
Kodi_Newcomer 27 Posted June 16, 2018 Posted June 16, 2018 Hey @puenktchen, You know bevor i use your plugin i have Set Up my epg Data Like this. Westworld - S2E7 this isnt work. For search with your Plugin so i have changed this how you told me that IT works. Is this a Problem for your Plugin when i add this too ? So i can See directly the SxxExx in the Guide View ? Now it is only in subtitle or how it names. Or did your Plugin then found nothing ? BTW, i good News. Yesterday i had the Fall that a Episode was Double in the Timer He record the First one later He deactivate the Seconds one. It Looks Like IT works great !!!
pünktchen 1411 Posted June 16, 2018 Author Posted June 16, 2018 If you change it back to your previous definition, then it will break the library search. I will not change this. Just use a Kodi skin that has the description under the guide rows.
Kodi_Newcomer 27 Posted July 17, 2018 Posted July 17, 2018 Hello @@pünktchen i have i little issue. Your Plugin runs very good. The most Timers where deactivate from your tool, when the epsiode is in the DB. But for example S.W.A.T. - S1E12 Giftiges Wasser he will not do this. So maybe you can see why ? Another quest, maybe your plugin can pull a media library scan in emby after an record is finished with an time buffer, so the problem with the double episodes can be help out. Here the log für the issue.Log.txt
Kodi_Newcomer 27 Posted July 19, 2018 Posted July 19, 2018 (edited) I have one more issue found. Sometimes he make the same timer with some minutes difference. Look at the screen and here is the log. Maybe you can find out why. Log1.txt When i look at the details, both of it has the right time in it. Edited July 19, 2018 by Kodi_Newcomer
