pünktchen 1411 Posted May 14, 2018 Author Posted May 14, 2018 (edited) So now something is broken. Autocreate Timer Taks, has an error. log.txt Somehow the plugin can't find a ID for the channel where "Doctor Who" is running. Please enter this http://192.168.178.10:8089/api/getchannelsxml.html?favonly=1 in your browser and post the output here. Edited May 14, 2018 by pünktchen
Kodi_Newcomer 27 Posted May 15, 2018 Posted May 15, 2018 (edited) Here the txt with all the channel names. Neues Textdokument.txt Is it right that only within 24 hours is searched. Everything beyond is not searched. So it is normal that he does not find an episode that is only on Monday? Edited May 15, 2018 by Kodi_Newcomer
pünktchen 1411 Posted May 15, 2018 Author Posted May 15, 2018 Your channel list looks okay, but i think i've found a bug in the DMS API. Please test this: and report back! 1
pünktchen 1411 Posted May 15, 2018 Author Posted May 15, 2018 Is it right that only within 24 hours is searched. Everything beyond is not searched. So it is normal that he does not find an episode that is only on Monday? Yes, it's normal. But it will find the Monday episode around Sunday...
Kodi_Newcomer 27 Posted May 15, 2018 Posted May 15, 2018 (edited) Now it seems to be work. He has create some Timers. Is this right ? Elementary - Tödliches Pulver but how did emby know witch season and episode it is ? My self created timers looks like this Westworld - S2E4 Das Rätsel der Sphinx Another quest. There are two series, i will not record. Is there a option in the serie to stop recording episodes for these ? And another feature request. Maybe you can add more regex and search in the title ? My series naming looks like this :: Deep State - (S1E6) - Die Schwachstelle So i can see it directly in kodi on the epg. Now for working with your plugin it looks like this you know Elementary - Tödliches Pulver. So i have no directly check witch episode and season it is. I must go over it with the mouse to look. So when you can add more regex and search at the title this would be create. Edited May 15, 2018 by Kodi_Newcomer
pünktchen 1411 Posted May 15, 2018 Author Posted May 15, 2018 Now it seems to be work. He has create some Timers. Is this right ? Elementary - Tödliches Pulver but how did emby know witch season and episode it is ? My self created timers looks like this Westworld - S2E4 Das Rätsel der Sphinx This wasn't my intention. Will be fixed. Another quest. There are two series, i will not record. Is there a option in the serie to stop recording episodes for these ?Not that i know. We'll have to ask @@Luke if it's possible to download missing Episodes for only specific tv shows. Maybe by locking the other series in the metadata manager? And another feature request. Maybe you can add more regex and search in the title ? Will have to think about this. 1
pünktchen 1411 Posted May 15, 2018 Author Posted May 15, 2018 Not that i know. We'll have to ask @@Luke if it's possible to download missing Episodes for only specific tv shows. Maybe by locking the other series in the metadata manager? At least i could create a condition that only series that are not locked are considered for the autocreated timers. Would that help?
Kodi_Newcomer 27 Posted May 15, 2018 Posted May 15, 2018 (edited) There is another problem i think. I activate manual Legion - (S2E7) - Legion. After the task "Refresh DVBV Timers" is running, the Timer is deactivate. But the episode is missing in Emby Lib. I activate it again, and after the Task is running the timer is deactivate again. Neues Textdokument.txt At least i could create a condition that only series that are not locked are considered for the autocreated timers. Would that help? What exactly do you mean with locked ? That the series is finished ? Edited May 15, 2018 by Kodi_Newcomer
pünktchen 1411 Posted May 15, 2018 Author Posted May 15, 2018 What exactly do you mean with locked ? That the series is finished ? Locked = Sperren. Prevent changing of metadata. Last test for today:
Kodi_Newcomer 27 Posted May 16, 2018 Posted May 16, 2018 (edited) Locked = Sperren. Prevent changing of metadata Is this only for the complete Series or can i lock only a season ? Edited May 16, 2018 by Kodi_Newcomer
thor2002ro 5 Posted May 16, 2018 Posted May 16, 2018 2018-05-16 10:22:45.732 Error TaskManager: Error *** Error Report *** Version: 3.4.1.5 Command line: C:\Users\Administrator\AppData\Roaming\Emby-Server\system\EmbyServer.dll C:\Users\Administrator\AppData\Roaming\Emby-Server\system\EmbyServer.dll C:\Users\Administrator\AppData\Roaming\Emby-Server\system\EmbyServer.dll C:\Users\Administrator\AppData\Roaming\Emby-Server\system\EmbyServer.dll -noautorunwebapp Operating system: Microsoft Windows NT 6.2.9200.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 4 Program data path: C:\Users\Administrator\AppData\Roaming\Emby-Server\programdata Application directory: C:\Users\Administrator\AppData\Roaming\Emby-Server\system System.AggregateException: One or more errors occurred. (NotFound) ---> MediaBrowser.Model.Net.HttpException: NotFound at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.Get(HttpRequestOptions options) --- End of inner exception stack trace --- at System.Threading.Tasks.Task`1.GetResultCore(Boolean waitCompletionNotification) at MediaBrowser.Plugins.DVBViewer.Services.Proxies.ProxyBase.GetFromService[TResult](CancellationToken cancellationToken, Type type, String action, Object[] args) at MediaBrowser.Plugins.DVBViewer.Services.Proxies.TVServiceProxy.GetSeriesSchedules(CancellationToken cancellationToken) at MediaBrowser.Plugins.DVBViewer.Services.Proxies.TVServiceProxy.GetSeriesSchedulesFromMemory(CancellationToken cancellationToken) at MediaBrowser.Plugins.DVBViewer.Services.Proxies.TVServiceProxy.RefreshSchedules(CancellationToken cancellationToken) at MediaBrowser.Plugins.DVBViewer.Helpers.RefreshTimersTask.Execute(CancellationToken cancellationToken, IProgress`1 progress) at Emby.Server.Implementations.ScheduledTasks.ScheduledTaskWorker.ExecuteInternal(TaskOptions options) ---> (Inner Exception #0) MediaBrowser.Model.Net.HttpException: NotFound at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.Get(HttpRequestOptions options)<--- System.AggregateException at System.Threading.Tasks.Task`1.GetResultCore(Boolean waitCompletionNotification) at MediaBrowser.Plugins.DVBViewer.Services.Proxies.ProxyBase.GetFromService[TResult](CancellationToken cancellationToken, Type type, String action, Object[] args) at MediaBrowser.Plugins.DVBViewer.Services.Proxies.TVServiceProxy.GetSeriesSchedules(CancellationToken cancellationToken) at MediaBrowser.Plugins.DVBViewer.Services.Proxies.TVServiceProxy.GetSeriesSchedulesFromMemory(CancellationToken cancellationToken) at MediaBrowser.Plugins.DVBViewer.Services.Proxies.TVServiceProxy.RefreshSchedules(CancellationToken cancellationToken) at MediaBrowser.Plugins.DVBViewer.Helpers.RefreshTimersTask.Execute(CancellationToken cancellationToken, IProgress`1 progress) at Emby.Server.Implementations.ScheduledTasks.ScheduledTaskWorker.ExecuteInternal(TaskOptions options) InnerException: MediaBrowser.Model.Net.HttpException MediaBrowser.Model.Net.HttpException: NotFound at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.Get(HttpRequestOptions options) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.Get(HttpRequestOptions options) 2018-05-16 10:22:45.732 Info TaskManager: Refresh DVBViewer timers Failed after 0 minute(s) and 0 seconds error on timers every time refresh timers is ran
pünktchen 1411 Posted May 16, 2018 Author Posted May 16, 2018 2018-05-16 10:22:45.732 Error TaskManager: Error *** Error Report *** Version: 3.4.1.5 Command line: C:\Users\Administrator\AppData\Roaming\Emby-Server\system\EmbyServer.dll C:\Users\Administrator\AppData\Roaming\Emby-Server\system\EmbyServer.dll C:\Users\Administrator\AppData\Roaming\Emby-Server\system\EmbyServer.dll C:\Users\Administrator\AppData\Roaming\Emby-Server\system\EmbyServer.dll -noautorunwebapp Operating system: Microsoft Windows NT 6.2.9200.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 4 Program data path: C:\Users\Administrator\AppData\Roaming\Emby-Server\programdata Application directory: C:\Users\Administrator\AppData\Roaming\Emby-Server\system System.AggregateException: One or more errors occurred. (NotFound) ---> MediaBrowser.Model.Net.HttpException: NotFound at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.Get(HttpRequestOptions options) --- End of inner exception stack trace --- at System.Threading.Tasks.Task`1.GetResultCore(Boolean waitCompletionNotification) at MediaBrowser.Plugins.DVBViewer.Services.Proxies.ProxyBase.GetFromService[TResult](CancellationToken cancellationToken, Type type, String action, Object[] args) at MediaBrowser.Plugins.DVBViewer.Services.Proxies.TVServiceProxy.GetSeriesSchedules(CancellationToken cancellationToken) at MediaBrowser.Plugins.DVBViewer.Services.Proxies.TVServiceProxy.GetSeriesSchedulesFromMemory(CancellationToken cancellationToken) at MediaBrowser.Plugins.DVBViewer.Services.Proxies.TVServiceProxy.RefreshSchedules(CancellationToken cancellationToken) at MediaBrowser.Plugins.DVBViewer.Helpers.RefreshTimersTask.Execute(CancellationToken cancellationToken, IProgress`1 progress) at Emby.Server.Implementations.ScheduledTasks.ScheduledTaskWorker.ExecuteInternal(TaskOptions options) ---> (Inner Exception #0) MediaBrowser.Model.Net.HttpException: NotFound at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.Get(HttpRequestOptions options)<--- System.AggregateException at System.Threading.Tasks.Task`1.GetResultCore(Boolean waitCompletionNotification) at MediaBrowser.Plugins.DVBViewer.Services.Proxies.ProxyBase.GetFromService[TResult](CancellationToken cancellationToken, Type type, String action, Object[] args) at MediaBrowser.Plugins.DVBViewer.Services.Proxies.TVServiceProxy.GetSeriesSchedules(CancellationToken cancellationToken) at MediaBrowser.Plugins.DVBViewer.Services.Proxies.TVServiceProxy.GetSeriesSchedulesFromMemory(CancellationToken cancellationToken) at MediaBrowser.Plugins.DVBViewer.Services.Proxies.TVServiceProxy.RefreshSchedules(CancellationToken cancellationToken) at MediaBrowser.Plugins.DVBViewer.Helpers.RefreshTimersTask.Execute(CancellationToken cancellationToken, IProgress`1 progress) at Emby.Server.Implementations.ScheduledTasks.ScheduledTaskWorker.ExecuteInternal(TaskOptions options) InnerException: MediaBrowser.Model.Net.HttpException MediaBrowser.Model.Net.HttpException: NotFound at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.Get(HttpRequestOptions options) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.Get(HttpRequestOptions options) 2018-05-16 10:22:45.732 Info TaskManager: Refresh DVBViewer timers Failed after 0 minute(s) and 0 secondserror on timers every time refresh timers is ranDo you have any EPG-Search entries in DMS with an empty Series field?
pünktchen 1411 Posted May 16, 2018 Author Posted May 16, 2018 Locked = Sperren. Prevent changing of metadata Is this only dir the complete Series or can i lock only a season ? Series, season or episode.But i have a better idea. I will make it conditional by a custom "Tag". 1
thor2002ro 5 Posted May 16, 2018 Posted May 16, 2018 Do you have any EPG-Search entries in DMS with an empty Series field? yes some channels have no epg at all....
pünktchen 1411 Posted May 16, 2018 Author Posted May 16, 2018 yes some channels have no epg at all....That was not my question! In mean "Serie" inside the definition of an EPG-Search item.
thor2002ro 5 Posted May 16, 2018 Posted May 16, 2018 Series inside epg search in timer settings is empty
pünktchen 1411 Posted May 16, 2018 Author Posted May 16, 2018 Series inside epg search in timer settings is empty Thanks for confirmation. Will be fixed in next update.
Kodi_Newcomer 27 Posted May 16, 2018 Posted May 16, 2018 (edited) Series, season or episode. But i have a better idea. I will make it conditional by a custom "Tag". Can you explaine it a litle bit ? How does it works, to exclude a season or complete Serie with your idea ? Edited May 16, 2018 by Kodi_Newcomer
pünktchen 1411 Posted May 16, 2018 Author Posted May 16, 2018 Haven't you never explored Emby's metadata editor? There you can define tags for every item - channel, movie, series, season, episode... You'll then have to create a tag, let's say "NoDMS" at the season level and every episode under that will be ignored for Autotimer creation. 1
Kodi_Newcomer 27 Posted May 16, 2018 Posted May 16, 2018 There is another problem i think. I activate manual Legion - (S2E7) - Legion. After the task "Refresh DVBV Timers" is running, the Timer is deactivate. But the episode is missing in Emby Lib. I activate it again, and after the Task is running the timer is deactivate again. What did you fixed in the last version ? Not this problem ?
pünktchen 1411 Posted May 16, 2018 Author Posted May 16, 2018 What did you fixed in the last version ? Not this problem ?I thaught so. Still not working?
Kodi_Newcomer 27 Posted May 16, 2018 Posted May 16, 2018 I thaught so. Still not working? No, everytime the refresh task runs the timer is disabled. Also, your plugin has not created his own timer. Now i have change the last number on the ip adresse in the plugin config, and now the episode timer was activated all the time.
pünktchen 1411 Posted May 16, 2018 Author Posted May 16, 2018 (edited) Next test: Tag to exclude items from autotimer creation is "NoDMS" without quotes. Edited May 16, 2018 by pünktchen 1
Kodi_Newcomer 27 Posted May 16, 2018 Posted May 16, 2018 Next test: MediaBrowser.Plugins.DVBViewer.zip Tag to exclude items from autotimer creation is "NoDMS" without quotes. We could not find the attachment you were attempting to view.
