Koleckai Silvestri 1154 Posted December 31, 2013 Posted December 31, 2013 There is an option within MBT. Settings, General, Auto start at startup. You probably have that checked. The option is badly worded and laid out in my opinion. I had it checked for a while as well because it appeared to be paired with the option above about checking for updates. I took it to mean "Check for updates, when Media Browser Theater starts."
2BTSquared 5 Posted December 31, 2013 Posted December 31, 2013 I don't want MBT automatically launching when the system reboots/starts. I've deleted MBT from the Startup folder, but it keeps reappearing. If it's an option somewhere I can't find it. Perhaps somebody could point it out to me. Thanks...
gcw07 347 Posted December 31, 2013 Posted December 31, 2013 There is an option within MBT. Settings, General, Auto start at startup. You probably have that checked.
bruce73 2 Posted December 31, 2013 Posted December 31, 2013 On a related note, I can't figure out why the setup wizard runs on random startups. Sent from my Nexus 4 using Tapatalk 2
2BTSquared 5 Posted December 31, 2013 Posted December 31, 2013 There is an option within MBT. Settings, General, Auto start at startup. You probably have that checked. Thanks found it... Forgot about settings in MBT.
gcw07 347 Posted December 31, 2013 Posted December 31, 2013 Not really sure how else we could word it. Auto-run is a pretty common windows terminology. However I'm sure we are open to any ideas you have on new terminology for it.
Luke 42234 Posted December 31, 2013 Posted December 31, 2013 On a related note, I can't figure out why the setup wizard runs on random startups. Sent from my Nexus 4 using Tapatalk 2 if it can't reach your server, or if any of the required components are missing, the startup wizard will run. 1
Koleckai Silvestri 1154 Posted December 31, 2013 Author Posted December 31, 2013 Not really sure how else we could word it. Auto-run is a pretty common windows terminology. However I'm sure we are open to any ideas you have on new terminology for it. "Start Theater when I start Windows"
