madjomack 0 Posted April 30, 2016 Posted April 30, 2016 I've tried to get Cinema Mode to work but i'm not able to figure out how. I have the Gold MB "Thank you for supporting Emby". I have the "Trailers" plugin installed and all selections are checked. I've enabled Cinema mode for Movies under playback. I've enabled Cinema mode under my profile. I have waited a few days since enabling it and still nothing and restarted the server. If i start a movie using the web client it only plays the movie and no trailers. I have attached a serverlog. server-63597566240.txt
Luke 42186 Posted April 30, 2016 Posted April 30, 2016 Hi, try changing some of the filters on that screen such as the checkboxes near the top and also the parental control setting. See if that makes a difference. Also, make sure to read what it says at the bottom - each app has a setting for cinema mode and some apps are off by default. the setting for the web client can be found under your user preferences.
madjomack 0 Posted April 30, 2016 Author Posted April 30, 2016 I have played with all of the options and I have Smart Parental Control disabled.. And enabling "Include trailers from older movies" is the only way to get a trailer to play before a movie. Yet I only want new trailers to play. Is this a bug?
Luke 42186 Posted April 30, 2016 Posted April 30, 2016 I don't think so. I just selected the same settings and got the trailer for Ted when I went to play Entourage. It might just be a little too strict right now in terms of checking for similarity. I'll review that.
leezy 1 Posted April 30, 2016 Posted April 30, 2016 I am having the same issue as well with Cinema Mode. Cinema Mode does not play new and upcoming movies and only play if "include trailers from older movies" is enabled.
Luke 42186 Posted April 30, 2016 Posted April 30, 2016 Ok, I put in a fix for the next Emby Server release, thanks.
QUIKFLUX 6 Posted May 1, 2016 Posted May 1, 2016 Ok, I put in a fix for the next Emby Server release, thanks. This is working again for me now after the last update to emby server.Thanks heaps Luke.
