Kramerika 18 Posted April 27, 2016 Posted April 27, 2016 (edited) I have an odd issue. Most of my movies with DTS 5.1 sound direct play on the Nvidia Shield TV app. However, I have come across two that transcode to DD 5.1, and I do not understand why. They are also related to one another in that they are the Avengers movies. Below is the media info for the audio for the files including an example of a movie which direct plays DTS 5.1 (Spectre). The subtitles are the same format as is the container, MKV, and the video which uses the h264 codec. I also have the max streaming bitrate set to 40 Mbps. The Avengers VideoCodec H264Profile HighLevel 41Resolution 1920x1080Aspect ratio 16:9Anamorphic NoInterlaced NoFramerate 23.97602Bitrate 7701 kbpsBit depth 8 bitPixel format yuv420pRef frames 4AudioLanguage engCodec DCAProfile DTSLayout 5.1Channels 6 chBitrate 1500 kbpsSample rate 48000 khzBit depth 24 bitDefault YesSubtitleLanguage engCodec PGSSUBDefault NoForced NoExternal No The Avengers Age of Ultron VideoCodec H264Profile HighLevel 41Resolution 1920x804Aspect ratio 2.40:1Anamorphic NoInterlaced NoFramerate 23.97602Bitrate 5986 kbpsBit depth 8 bitPixel format yuv420pRef frames 4AudioLanguage engCodec DCAProfile DTSLayout 5.1Channels 6 chBitrate 1500 kbpsSample rate 48000 khzDefault YesSubtitleLanguage engCodec PGSSUBDefault NoForced NoExternal No Spectre VideoCodec H264Profile HighLevel 41Resolution 1920x808Aspect ratio 2.40:1Anamorphic NoInterlaced NoFramerate 23.97602Bitrate 8044 kbpsBit depth 8 bitPixel format yuv420pRef frames 4AudioLanguage engCodec DCAProfile DTSLayout 5.1Channels 6 chBitrate 1500 kbpsSample rate 48000 khzBit depth 24 bitDefault YesSubtitleLanguage engCodec PGSSUBDefault NoForced NoExternal No Edited April 27, 2016 by Kramerika
ebr 16336 Posted April 27, 2016 Posted April 27, 2016 What is the full media info for the items? Likely it is something in one of the other streams that is causing the transcode.
Kramerika 18 Posted April 27, 2016 Author Posted April 27, 2016 I added the Video and Subtitle information to my original post. The only difference I see outside of small fluctuations in the bitrate and framerate is in the resolution and aspect ratio, but the Age of Ultron and Spectre are almost identical there and behave differently in terms of direct playing or transcoding the audio while the original Avengers movie and the sequel are different in those areas but both transcode the audio.
ebr 16336 Posted April 27, 2016 Posted April 27, 2016 More than likely the Avengers movies are burning in the subs. If you ever switched them on, the server will remember this and have them on the next time you play.
Kramerika 18 Posted April 27, 2016 Author Posted April 27, 2016 The first Avengers movie has forced subs for some foreign language as does Spectre. I had to burn them in since they were separate tracks and not hardcoded. The Age of Ultron does not have any hardcoded subtitles. How does this affect the transcoding of the audio? Since the Avengers transcodes DTS 5.1 to DD 5.1 and Spectre does not but direct plays DTS 5.1, I don't see a connection that makes sense.
ebr 16336 Posted April 27, 2016 Posted April 27, 2016 If the item has to be transcoded - for any reason - then DTS audio will be converted to some other format that can be streamed. Depending on certain conditions, this will be either AAC or AC3 (DD).
Kramerika 18 Posted April 27, 2016 Author Posted April 27, 2016 (edited) I guess I'm like that little kid who keeps asking why, since I have two kids of my own who do that, but I really want to understand why it is transcoding. I know it's not a big difference from DTS to DD 5.1, but it is using my server resources which I want to avoid. I also prefer not to alter the audio if possible since my sound system supports it. I can play these same movies on SPMC in DTS, so I know the shield and my receiver can work together to output the native audio stream. Edited April 28, 2016 by Kramerika
cbauer25 5 Posted April 28, 2016 Posted April 28, 2016 Ever since the most recent update (or the most recent server update...can't tell which) I've run into the same problem. Almost half of my movies are transcoding when before the update it was direct. Thoughts?
ebr 16336 Posted April 28, 2016 Posted April 28, 2016 The PGS subtitles are what is causing the transcode more than likely. If you post a transcode log I could confirm.
Kramerika 18 Posted April 28, 2016 Author Posted April 28, 2016 (edited) I'll try to do that tonight. What can be different about the subtitles that would cause the audio of one file to transcode and not the other? Almost all of my blu ray movies have PGS subtitles but only a few of them are transcoded. Edited April 28, 2016 by Kramerika
ebr 16336 Posted April 28, 2016 Posted April 28, 2016 The difference would be whether or not the subs are selected and which app is doing the playing.
Kramerika 18 Posted April 29, 2016 Author Posted April 29, 2016 ok, here are the transcoding logs from The Avengers and The Age of Ultron. I have the English subtitles included in all of my MKV files but always off by default. I am not playing them here. http://192.168.1.97:8096/emby/videos/52501a365eedee34e099cc394befd52d/stream.mkv?DeviceId=2017e89812470a8b&MediaSourceId=52501a365eedee34e099cc394befd52d&VideoCodec=h264&AudioCodec=ac3&AudioStreamIndex=1&SubtitleStreamIndex=2&VideoBitrate=39552000&AudioBitrate=448000&MaxAudioChannels=6&Level=51&Profile=high&PlaySessionId=c22c62b88f6545c2956124f6f3013bb6&api_key=4b01e6d8907d4ab4bbc7ce245bf171f5&CopyTimestamps=true&ForceLiveStream=false&SubtitleMethod=Encode{"Protocol":"File","Id":"52501a365eedee34e099cc394befd52d","Path":"F:\\My Movies\\Comics\\Marvel\\The Avengers\\The Avengers (2012).mkv","Type":"Default","Container":"mkv","Name":"1080P/H264/DTS","RunTimeTicks":85748580000,"ReadAtNativeFramerate":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"RequiresOpening":false,"RequiresClosing":false,"VideoType":"VideoFile","MediaStreams":[{"Codec":"h264","Language":"eng","IsInterlaced":false,"BitRate":7886153,"BitDepth":8,"RefFrames":4,"IsDefault":true,"IsForced":false,"Height":1080,"Width":1920,"AverageFrameRate":23.97602,"RealFrameRate":23.97602,"Profile":"High","Type":"Video","AspectRatio":"16:9","Index":0,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"PixelFormat":"yuv420p","Level":41,"IsAnamorphic":false},{"Codec":"dca","Language":"eng","IsInterlaced":false,"ChannelLayout":"5.1","BitRate":1536000,"BitDepth":24,"Channels":6,"SampleRate":48000,"IsDefault":true,"IsForced":false,"Profile":"DTS","Type":"Audio","Index":1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0},{"Codec":"pgssub","Language":"eng","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":2,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0}],"PlayableStreamFileNames":[],"Formats":[],"Bitrate":7886153,"RequiredHttpHeaders":{}}C:\Users\Media Server\AppData\Roaming\Emby-Server\ffmpeg\20160401\ffmpeg.exe -fflags +genpts -noaccurate_seek -i file:"F:\My Movies\Comics\Marvel\The Avengers\The Avengers (2012).mkv" -map 0:0 -map 0:1 -codec:v:0 libx264 -force_key_frames expr:gte(t,n_forced*5) -copyts -avoid_negative_ts disabled -start_at_zero -pix_fmt yuv420p -preset superfast -crf 23 -b:v 7886153 -maxrate 7886153 -bufsize 15772306 -vsync vfr -profile:v high -level 51 -filter_complex "[0:2]format=yuva444p,scale=1920:1080,lut=u=128:v=128:y=gammaval(.3) ; [0:0] overlay" -map_metadata -1 -threads 0 -codec:a:0 ac3 -ac 6 -ab 448000 -af "aresample=async=1" -y "F:\Transcoding\transcoding-temp\0b0494455564b7b2293e3d79827f00e3.mkv"ffmpeg version N-79173-gbe746ae Copyright © 2000-2016 the FFmpeg developersbuilt with gcc 5.3.0 (GCC)configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libfreetype --enable-libgme --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmfx --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinger --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable-libzimg --enable-lzma --enable-decklink --enable-zliblibavutil 55. 19.100 / 55. 19.100libavcodec 57. 32.100 / 57. 32.100libavformat 57. 29.101 / 57. 29.101libavdevice 57. 0.101 / 57. 0.101libavfilter 6. 40.102 / 6. 40.102libswscale 4. 0.100 / 4. 0.100libswresample 2. 0.101 / 2. 0.101libpostproc 54. 0.100 / 54. 0.100[matroska,webm @ 000000000049a8e0] Could not find codec parameters for stream 2 (Subtitle: hdmv_pgs_subtitle): unspecified sizeConsider increasing the value for the 'analyzeduration' and 'probesize' optionsInput #0, matroska,webm, from 'file:F:\My Movies\Comics\Marvel\The Avengers\The Avengers (2012).mkv':Metadata:encoder : libmkv 0.6.5TITLE : Marvel's The AvengersDuration: 02:22:54.86, start: 0.000000, bitrate: 7886 kb/sChapter #0:0: start 0.000000, end 482.440289Metadata:title : Chapter 1Chapter #0:1: start 482.440289, end 709.166789Metadata:title : Chapter 2Chapter #0:2: start 709.166789, end 918.834578Metadata:title : Chapter 3Chapter #0:3: start 918.834578, end 1233.607367Metadata:title : Chapter 4Chapter #0:4: start 1233.607367, end 1384.257867Metadata:title : Chapter 5Chapter #0:5: start 1384.257867, end 1779.486033Metadata:title : Chapter 6Chapter #0:6: start 1779.486033, end 2568.065500Metadata:title : Chapter 7Chapter #0:7: start 3664.661000, end 4445.232456Metadata:title : Chapter 11Chapter #0:8: start 2568.065500, end 3022.394367Metadata:title : Chapter 9Chapter #0:9: start 3022.394367, end 3664.661000Metadata:title : Chapter 10Chapter #0:10: start 4445.232456, end 5281.317700Metadata:title : Chapter 12Chapter #0:11: start 5281.317700, end 5900.644744Metadata:title : Chapter 13Chapter #0:12: start 5900.644744, end 6340.250578Metadata:title : Chapter 14Chapter #0:13: start 6340.250578, end 6675.126789Metadata:title : Chapter 15Chapter #0:14: start 6675.126789, end 7067.852456Metadata:title : Chapter 16Chapter #0:15: start 7067.852456, end 7478.679533Metadata:title : Chapter 17Chapter #0:16: start 7478.679533, end 7779.396622Metadata:title : Chapter 18Chapter #0:17: start 7779.396622, end 7990.774456Metadata:title : Chapter 19Chapter #0:18: start 7990.774456, end 8574.858000Metadata:title : Chapter 20Stream #0:0(eng): Video: h264 (High), yuv420p(tv, bt709), 1920x1080 [sAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)Stream #0:1(eng): Audio: dts (DTS), 48000 Hz, 5.1(side), fltp, 1536 kb/s (default)Stream #0:2(eng): Subtitle: hdmv_pgs_subtitle[matroska,webm @ 000000000049a8e0] sub2video: using 1920x1080 canvas[libx264 @ 00000000034249a0] using SAR=1/1[libx264 @ 00000000034249a0] using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2[libx264 @ 00000000034249a0] profile High, level 5.1[libx264 @ 00000000034249a0] 264 - core 148 r2665 a01e339 - H.264/MPEG-4 AVC codec - Copyleft 2003-2016 - http://www.videolan.org/x264.html - options: cabac=1 ref=1 deblock=1:0:0 analyse=0x3:0x3 me=dia subme=1 psy=1 psy_rd=1.00:0.00 mixed_ref=0 me_range=16 chroma_me=1 trellis=0 8x8dct=1 cqm=0 deadzone=21,11 fast_pskip=1 chroma_qp_offset=0 threads=12 lookahead_threads=2 sliced_threads=0 nr=0 decimate=1 interlaced=0 bluray_compat=0 constrained_intra=0 bframes=3 b_pyramid=2 b_adapt=1 b_bias=0 direct=1 weightb=1 open_gop=0 weightp=1 keyint=250 keyint_min=23 scenecut=40 intra_refresh=0 rc_lookahead=0 rc=crf mbtree=0 crf=23.0 qcomp=0.60 qpmin=0 qpmax=69 qpstep=4 vbv_maxrate=7886 vbv_bufsize=15772 crf_max=0.0 nal_hrd=none filler=0 ip_ratio=1.40 pb_ratio=1.30 aq=1:1.00Output #0, matroska, to 'F:\Transcoding\transcoding-temp\0b0494455564b7b2293e3d79827f00e3.mkv':Metadata:encoder : Lavf57.29.101Chapter #0:0: start 0.000000, end 482.440289Chapter #0:1: start 482.440289, end 709.166789Chapter #0:2: start 709.166789, end 918.834578Chapter #0:3: start 918.834578, end 1233.607367Chapter #0:4: start 1233.607367, end 1384.257867Chapter #0:5: start 1384.257867, end 1779.486033Chapter #0:6: start 1779.486033, end 2568.065500Chapter #0:7: start 3664.661000, end 4445.232456Chapter #0:8: start 2568.065500, end 3022.394367Chapter #0:9: start 3022.394367, end 3664.661000Chapter #0:10: start 4445.232456, end 5281.317700Chapter #0:11: start 5281.317700, end 5900.644744Chapter #0:12: start 5900.644744, end 6340.250578Chapter #0:13: start 6340.250578, end 6675.126789Chapter #0:14: start 6675.126789, end 7067.852456Chapter #0:15: start 7067.852456, end 7478.679533Chapter #0:16: start 7478.679533, end 7779.396622Chapter #0:17: start 7779.396622, end 7990.774456Chapter #0:18: start 7990.774456, end 8574.858000Stream #0:0: Video: h264 (libx264) (H264 / 0x34363248), yuv420p, 1920x1080 [sAR 1:1 DAR 16:9], q=-1--1, 7886 kb/s, 23.98 fps, 1k tbn, 23.98 tbc (default)Metadata:encoder : Lavc57.32.100 libx264Side data:cpb: bitrate max/min/avg: 7886000/0/7886000 buffer size: 15772000 vbv_delay: -1Stream #0:1: Audio: ac3 ([0] [0][0] / 0x2000), 48000 Hz, 5.1, fltp, 448 kb/s (default)Metadata:encoder : Lavc57.32.100 ac3Stream mapping:Stream #0:0 (h264) -> overlay:main (graph 0)Stream #0:2 (pgssub) -> format (graph 0)overlay (graph 0) -> Stream #0:0 (libx264)Stream #0:1 -> #0:1 (dts (dca) -> ac3 (native))Press [q] to stop, [?] for helpframe= 14 fps=0.0 q=0.0 size= 0kB time=00:00:00.98 bitrate= 0.0kbits/s speed=1.81xframe= 37 fps= 35 q=19.0 size= 39kB time=00:00:01.97 bitrate= 162.3kbits/s speed=1.87xframe= 57 fps= 36 q=19.0 size= 86kB time=00:00:02.81 bitrate= 251.7kbits/s speed=1.78xframe= 76 fps= 36 q=19.0 size= 517kB time=00:00:03.54 bitrate=1193.8kbits/s speed=1.68xframe= 93 fps= 35 q=31.0 size= 1989kB time=00:00:04.25 bitrate=3833.2kbits/s speed=1.62xframe= 113 fps= 36 q=32.0 size= 3580kB time=00:00:05.08 bitrate=5770.2kbits/s speed=1.62xframe= 131 fps= 36 q=33.0 size= 4326kB time=00:00:05.81 bitrate=6090.0kbits/s speed=1.59xframe= 149 fps= 36 q=32.0 size= 5124kB time=00:00:06.58 bitrate=6373.0kbits/s speed=1.57xframe= 171 fps= 36 q=30.0 size= 6055kB time=00:00:07.48 bitrate=6628.4kbits/s speed=1.59xframe= 189 fps= 36 q=28.0 size= 6756kB time=00:00:08.25 bitrate=6708.1kbits/s speed=1.58xframe= 209 fps= 36 q=23.0 size= 7344kB time=00:00:09.08 bitrate=6623.1kbits/s speed=1.59xframe= 231 fps= 37 q=19.0 size= 7856kB time=00:00:10.01 bitrate=6428.7kbits/s speed= 1.6xframe= 251 fps= 37 q=25.0 size= 8500kB time=00:00:10.81 bitrate=6440.9kbits/s speed= 1.6xframe= 268 fps= 37 q=30.0 size= 9633kB time=00:00:11.54 bitrate=6833.9kbits/s speed=1.58xframe= 287 fps= 37 q=29.0 size= 10584kB time=00:00:12.31 bitrate=7040.4kbits/s speed=1.58xframe= 307 fps= 37 q=30.0 size= 11440kB time=00:00:13.14 bitrate=7128.4kbits/s speed=1.58xframe= 325 fps= 37 q=30.0 size= 12267kB time=00:00:13.91 bitrate=7221.5kbits/s speed=1.57xframe= 344 fps= 37 q=29.0 size= 13039kB time=00:00:14.71 bitrate=7258.7kbits/s speed=1.57xframe= 363 fps= 37 q=30.0 size= 13836kB time=00:00:15.51 bitrate=7305.5kbits/s speed=1.56xframe= 382 fps= 37 q=31.0 size= 14704kB time=00:00:16.31 bitrate=7383.3kbits/s speed=1.56xframe= 400 fps= 37 q=30.0 size= 15435kB time=00:00:17.05 bitrate=7415.6kbits/s speed=1.56xframe= 419 fps= 37 q=29.0 size= 16234kB time=00:00:17.81 bitrate=7463.5kbits/s speed=1.55xframe= 436 fps= 36 q=29.0 size= 16919kB time=00:00:18.55 bitrate=7469.9kbits/s speed=1.55xframe= 455 fps= 36 q=28.0 size= 17725kB time=00:00:19.32 bitrate=7514.6kbits/s speed=1.55xframe= 455 fps= 36 q=-1.0 Lsize= 18447kB time=00:00:19.35 bitrate=7807.7kbits/s speed=1.53xvideo:17379kB audio:1059kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.051388% http://192.168.1.97:8096/emby/videos/322da4391c4ed80e31d701358ad51fc6/stream.mkv?DeviceId=2017e89812470a8b&MediaSourceId=322da4391c4ed80e31d701358ad51fc6&VideoCodec=h264&AudioCodec=ac3&AudioStreamIndex=1&SubtitleStreamIndex=2&VideoBitrate=39552000&AudioBitrate=448000&MaxAudioChannels=6&Level=51&Profile=high&PlaySessionId=373e9166bacc42fd82d1215286b6df62&api_key=4b01e6d8907d4ab4bbc7ce245bf171f5&CopyTimestamps=true&ForceLiveStream=false&SubtitleMethod=Encode{"Protocol":"File","Id":"322da4391c4ed80e31d701358ad51fc6","Path":"F:\\My Movies\\Comics\\Marvel\\The Avengers\\The Avengers Age of Ultron (2015).mkv","Type":"Default","Container":"mkv","Name":"1080P/H264/DTS","RunTimeTicks":84788040000,"ReadAtNativeFramerate":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"RequiresOpening":false,"RequiresClosing":false,"VideoType":"VideoFile","MediaStreams":[{"Codec":"h264","IsInterlaced":false,"BitRate":6130552,"BitDepth":8,"RefFrames":4,"IsDefault":true,"IsForced":false,"Height":804,"Width":1920,"AverageFrameRate":23.97602,"RealFrameRate":23.97602,"Profile":"High","Type":"Video","AspectRatio":"2.40:1","Index":0,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"PixelFormat":"yuv420p","Level":41,"IsAnamorphic":false},{"Codec":"dca","Language":"eng","IsInterlaced":false,"ChannelLayout":"5.1","BitRate":1536000,"Channels":6,"SampleRate":48000,"IsDefault":true,"IsForced":false,"Profile":"DTS","Type":"Audio","Index":1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0},{"Codec":"pgssub","Language":"eng","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":2,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0}],"PlayableStreamFileNames":[],"Formats":[],"Bitrate":6130552,"RequiredHttpHeaders":{}}C:\Users\Media Server\AppData\Roaming\Emby-Server\ffmpeg\20160401\ffmpeg.exe -fflags +genpts -noaccurate_seek -i file:"F:\My Movies\Comics\Marvel\The Avengers\The Avengers Age of Ultron (2015).mkv" -map 0:0 -map 0:1 -codec:v:0 libx264 -force_key_frames expr:gte(t,n_forced*5) -copyts -avoid_negative_ts disabled -start_at_zero -pix_fmt yuv420p -preset superfast -crf 23 -b:v 6130552 -maxrate 6130552 -bufsize 12261104 -vsync vfr -profile:v high -level 51 -filter_complex "[0:2]format=yuva444p,scale=1920:804,lut=u=128:v=128:y=gammaval(.3) ; [0:0] overlay" -map_metadata -1 -threads 0 -codec:a:0 ac3 -ac 6 -ab 448000 -af "aresample=async=1" -y "F:\Transcoding\transcoding-temp\0553ce0a325e2d42eda1cffb777680c0.mkv"ffmpeg version N-79173-gbe746ae Copyright © 2000-2016 the FFmpeg developersbuilt with gcc 5.3.0 (GCC)configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libfreetype --enable-libgme --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmfx --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinger --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable-libzimg --enable-lzma --enable-decklink --enable-zliblibavutil 55. 19.100 / 55. 19.100libavcodec 57. 32.100 / 57. 32.100libavformat 57. 29.101 / 57. 29.101libavdevice 57. 0.101 / 57. 0.101libavfilter 6. 40.102 / 6. 40.102libswscale 4. 0.100 / 4. 0.100libswresample 2. 0.101 / 2. 0.101libpostproc 54. 0.100 / 54. 0.100[matroska,webm @ 000000000047a980] Could not find codec parameters for stream 2 (Subtitle: hdmv_pgs_subtitle): unspecified sizeConsider increasing the value for the 'analyzeduration' and 'probesize' optionsInput #0, matroska,webm, from 'file:F:\My Movies\Comics\Marvel\The Avengers\The Avengers Age of Ultron (2015).mkv':Metadata:title : MARVEL'S AVENGERS: AGE OF ULTRON - BLU-RAYENCODER : Lavf55.12.0Duration: 02:21:18.80, start: 0.083000, bitrate: 6130 kb/sChapter #0:0: start 0.000000, end 735.318000Metadata:title : Chapter 1Chapter #0:1: start 735.318000, end 1284.158000Metadata:title : Chapter 2Chapter #0:2: start 1284.158000, end 1982.022000Metadata:title : Chapter 3Chapter #0:3: start 1982.022000, end 2167.749000Metadata:title : Chapter 4Chapter #0:4: start 2167.749000, end 2520.977000Metadata:title : Chapter 5Chapter #0:5: start 2520.977000, end 3164.870000Metadata:title : Chapter 6Chapter #0:6: start 3164.870000, end 3542.581000Metadata:title : Chapter 7Chapter #0:7: start 3542.581000, end 4551.297000Metadata:title : Chapter 8Chapter #0:8: start 4551.297000, end 5228.849000Metadata:title : Chapter 9Chapter #0:9: start 5228.849000, end 5804.966000Metadata:title : Chapter 10Chapter #0:10: start 5804.966000, end 6875.452000Metadata:title : Chapter 11Chapter #0:11: start 6875.452000, end 7587.663000Metadata:title : Chapter 12Chapter #0:12: start 7587.663000, end 7868.152000Metadata:title : Chapter 13Chapter #0:13: start 7868.152000, end 8478.762000Metadata:title : Chapter 14Stream #0:0: Video: h264 (High), yuv420p(tv, bt709), 1920x804 [sAR 1:1 DAR 160:67], 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)Stream #0:1(eng): Audio: dts (DTS), 48000 Hz, 5.1(side), fltp, 1536 kb/s (default)Metadata:title : SurroundLANGUAGE : engStream #0:2(eng): Subtitle: hdmv_pgs_subtitle[matroska,webm @ 000000000047a980] sub2video: using 1920x804 canvas[libx264 @ 0000000002f61ec0] using SAR=1/1[libx264 @ 0000000002f61ec0] using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2[libx264 @ 0000000002f61ec0] profile High, level 5.1[libx264 @ 0000000002f61ec0] 264 - core 148 r2665 a01e339 - H.264/MPEG-4 AVC codec - Copyleft 2003-2016 - http://www.videolan.org/x264.html - options: cabac=1 ref=1 deblock=1:0:0 analyse=0x3:0x3 me=dia subme=1 psy=1 psy_rd=1.00:0.00 mixed_ref=0 me_range=16 chroma_me=1 trellis=0 8x8dct=1 cqm=0 deadzone=21,11 fast_pskip=1 chroma_qp_offset=0 threads=12 lookahead_threads=2 sliced_threads=0 nr=0 decimate=1 interlaced=0 bluray_compat=0 constrained_intra=0 bframes=3 b_pyramid=2 b_adapt=1 b_bias=0 direct=1 weightb=1 open_gop=0 weightp=1 keyint=250 keyint_min=23 scenecut=40 intra_refresh=0 rc_lookahead=0 rc=crf mbtree=0 crf=23.0 qcomp=0.60 qpmin=0 qpmax=69 qpstep=4 vbv_maxrate=6130 vbv_bufsize=12261 crf_max=0.0 nal_hrd=none filler=0 ip_ratio=1.40 pb_ratio=1.30 aq=1:1.00Output #0, matroska, to 'F:\Transcoding\transcoding-temp\0553ce0a325e2d42eda1cffb777680c0.mkv':Metadata:encoder : Lavf57.29.101Chapter #0:0: start 0.000000, end 735.235000Chapter #0:1: start 735.235000, end 1284.075000Chapter #0:2: start 1284.075000, end 1981.939000Chapter #0:3: start 1981.939000, end 2167.666000Chapter #0:4: start 2167.666000, end 2520.894000Chapter #0:5: start 2520.894000, end 3164.787000Chapter #0:6: start 3164.787000, end 3542.498000Chapter #0:7: start 3542.498000, end 4551.214000Chapter #0:8: start 4551.214000, end 5228.766000Chapter #0:9: start 5228.766000, end 5804.883000Chapter #0:10: start 5804.883000, end 6875.369000Chapter #0:11: start 6875.369000, end 7587.580000Chapter #0:12: start 7587.580000, end 7868.069000Chapter #0:13: start 7868.069000, end 8478.679000Stream #0:0: Video: h264 (libx264) (H264 / 0x34363248), yuv420p, 1920x804 [sAR 1:1 DAR 160:67], q=-1--1, 6130 kb/s, 23.98 fps, 1k tbn, 23.98 tbc (default)Metadata:encoder : Lavc57.32.100 libx264Side data:cpb: bitrate max/min/avg: 6130000/0/6130000 buffer size: 12261000 vbv_delay: -1Stream #0:1: Audio: ac3 ([0] [0][0] / 0x2000), 48000 Hz, 5.1, fltp, 448 kb/s (default)Metadata:encoder : Lavc57.32.100 ac3Stream mapping:Stream #0:0 (h264) -> overlay:main (graph 0)Stream #0:2 (pgssub) -> format (graph 0)overlay (graph 0) -> Stream #0:0 (libx264)Stream #0:1 -> #0:1 (dts (dca) -> ac3 (native))Press [q] to stop, [?] for helpframe= 25 fps=0.0 q=19.0 size= 12kB time=00:00:01.33 bitrate= 70.9kbits/s speed= 2.6xframe= 56 fps= 54 q=19.0 size= 84kB time=00:00:02.65 bitrate= 258.8kbits/s speed=2.54xframe= 87 fps= 55 q=20.0 size= 157kB time=00:00:03.93 bitrate= 326.7kbits/s speed=2.49xframe= 111 fps= 53 q=22.0 size= 1076kB time=00:00:04.92 bitrate=1790.4kbits/s speed=2.36xframe= 134 fps= 51 q=30.0 size= 2811kB time=00:00:05.88 bitrate=3913.9kbits/s speed=2.26xframe= 156 fps= 50 q=33.0 size= 3642kB time=00:00:06.81 bitrate=4381.0kbits/s speed=2.18xframe= 180 fps= 50 q=34.0 size= 4429kB time=00:00:07.80 bitrate=4650.0kbits/s speed=2.15xframe= 205 fps= 49 q=31.0 size= 5294kB time=00:00:08.82 bitrate=4913.0kbits/s speed=2.13xframe= 227 fps= 49 q=31.0 size= 6016kB time=00:00:09.75 bitrate=5051.8kbits/s speed=2.09xframe= 252 fps= 49 q=32.0 size= 6831kB time=00:00:10.81 bitrate=5176.1kbits/s speed=2.08xframe= 277 fps= 49 q=32.0 size= 7539kB time=00:00:11.83 bitrate=5218.2kbits/s speed=2.07xframe= 279 fps= 48 q=-1.0 Lsize= 8271kB time=00:00:11.93 bitrate=5679.0kbits/s speed=2.04x
Luke 42243 Posted April 29, 2016 Posted April 29, 2016 Both logs are burning in subtitles so if you're asking why it's transcoding that would be the reason. It looks like PGS support is going to be added to the player framework that we're using so as soon as it's available you can be sure that we'll take advantage of it.
Kramerika 18 Posted April 29, 2016 Author Posted April 29, 2016 So this is a function of the video player used by Emby on the Nvidia Shield TV? The Amazon Fire TV direct plays the DTS in those same files perfectly fine, but I am assuming that uses a different player.
Kramerika 18 Posted May 6, 2016 Author Posted May 6, 2016 (edited) I wanted to report back that these movies are now direct playing DTS. I noticed the note below in the latest update, and that must have fixed it. Thanks! Support direct play with PGS subs on Google platform Edited May 6, 2016 by Kramerika
