Guest plexman Posted April 27, 2016 Posted April 27, 2016 I would like to know where do I have to store my custom icons for 1080p/h.264/etc for the CoverArt plugin to read them, and also how I have to name them. I tried finding a naming pattern or a guide in the forum but I don't find it. Thanks in advance.
Solution ebr 16344 Posted April 27, 2016 Solution Posted April 27, 2016 On the Indicator Overlays config page there is a button you press to tell it where to look for your custom images. Codec images need to be named: codec_[codec].png e.g. codec_h264.png Resolution: hdtype_720.png Aspect: aspect_185.png aspect 133.png ... 1
ebr 16344 Posted June 22, 2016 Posted June 22, 2016 Hi, How should I name a 3D custom logo ? 3D.png 2
ajamils 1 Posted June 8, 2018 Posted June 8, 2018 3D.png I have 3d.png in the C:\Users\XXX\AppData\Roaming\Emby-Server\programdata\plugins\CoverArt\Custom-Overlays but CoverArt does not pick it up. Is there anything I need to do for it to see it? Restart server?
ebr 16344 Posted June 9, 2018 Posted June 9, 2018 Restart server? Perhaps. I would certainly try that.
Happy2Play 9814 Posted June 9, 2018 Posted June 9, 2018 Is the naming case sensitive? 3d vs 3D I have 3d.png 3D.png
ajamils 1 Posted June 9, 2018 Posted June 9, 2018 Tried it. No luck. Perhaps. I would certainly try that. Sent from my SM-G955U using Tapatalk
