naeonline 27 Posted April 26, 2016 Posted April 26, 2016 Quick questions, I will file any feature requests or followup with any troubleshooting needs in other posts as needed. 1) From what I've been able to determine, the chapter images and roku images are saved in the cache location, or if enabled and specified, the custom metadata folder location, correct? Are these ever saved with the artwork and .nfo files in the media location if that setting is enabled? 2) Where are the subtitles saved if the subtitle downloader is enabled, cache correct? what is the naming convention on those, are they hashed or folder hashed and the .srt is named the same as the media file?
Solution Luke 42186 Posted April 26, 2016 Solution Posted April 26, 2016 Chapter images always go into the metadata folder. The roku bif files go into the metadata folder as well but the plugin has a setting to store it in the media directory. Subtitles always go into the media directory. 1
